Pen calibration needs resume on 3050 HP printer
Need to resume pen calibration on HP 3050. I use Ubuntu Linux.
Postalsusie
  • 40 Answers
SOURCE: need 2 calibrate my hp 1210 printer
Hi *s*
(bottom left corner windows START)
got to;
start/settings/printers/ and click
right click your printer and select printing preferences
click on the tab that says SERVICES
then click on the services icon button (picture)
you will see three choices;
align,
clean
print a test page.
Aligning is what you want.(calibration is just a different word)
You can also remove the ink cartridges as you usually do and then put them back in, this triggers and automatic printed page and then walks you through scanning and the alignment.*s*
if by chance you still have blurry printing and know your machine should be ok, try cleaning.( same procedure, different last choice- you clean the heads)
You can also check to see if the proper paper is selected. For instance, if you are trying to print heavy greeting card paper it must be set to that or it will not print properly. *s*
If you have thrown up your hands and tried all this, and nothing works. Go through your printer preferences and select SET DEFAULT SETTINGS buttons.
It will knock everything back to the way it left the factory *S*
Thank you and good luck. Please remember to give my answer a rating *S*
Posted on Oct 28, 2008
  • 102 Answers
SOURCE: multifuction hp laserjet 3050 conflict with hp laserjet M1522N
After installing the printer software you need to program scanning software.
Below are the steps to program scanning software:
To program the Scan To button:
Select Start/Programs or All Programs (Windows XP)/HP/HP Laserjet 3050, 3052, 3055, 3390, 3392/Scan
Click the Setup to open the Scan To Setup Wizard.
Select the Change the destinations that show up on the all-in-one control panel when I press the <Scan To> button and then click Next .
Check the Allow me to scan by pressing the Scan To button on the all-in-one check box.
Choose the destination by moving them from the PC window (the left window) to the All-in-one window (the right window).
NOTE: The All-in-one window might contain items set up by other computers that are connected to the all-in-one. You cannot make changes to these items.
Click Update .
To Create a destinations:
Follow steps 1-2 from the above steps.
Select Create a new destination with settings that I will specify and then select Next .
Select the Save it to my computer and then press Next .
Select the scan preferences and then select Next .
Select the scan destination folder and file format type and then select Next .
NOTE: If you wish to use a custom folder for your scan destination, you will need to create the folder prior to this setup wizard in order to browse to it.
Select the quality level you would like the file to be saved as.
Name the new destination on the computer, check the Send this new destination to the all-in-one check box, and enter a name for the display on the all-in-one. Then select Next .
Confirmation allows you to verify your settings. Select Save .
Once the new destination has been saved, the new destination will be configured as one of the Scan To destinations on the printer.
Posted on Jul 04, 2009
SOURCE: I am new to Linux. How do I instal an Epson SX210
Try this:
http://blog.sadhill.net/impresora-epson-stylus-sx210-en-ubuntu
Posted on Feb 22, 2010
  • 142 Answers
SOURCE: need ubuntu linux ppd driver for workcentre 385
It doesn't look good. The following web-site called it a paperweight.
http://www.openprinting.org/printer/Xerox/Xerox-WorkCentre_385
If you have good windows drivers for this, then you might be able to share it off another system and print via Samba.
You'd be better off trading it, donating it, ebay-ing it, or keep it as a fax/ copy system.
Brother, on the other hand makes good multi-function printers and they have very good linux support for their printers. If you're casting around for a replacement, take a look at the MFC-4800.
Posted on Mar 04, 2010
SOURCE: looking for linux drivers for Epson SX215 printer
get the Epson Linux drivers from the Avasys site and install them
http://www.avasys.jp/lx-bin2/linux_e/spc/DL1.do
Posted on Jul 20, 2010
Download drivers under Ubuntu for HP ENV 4500 e-All-in-One Series?
Hi Frank,
HP is one of the most supported printers for Linux. I run Mint (based on Ubuntu) & have had support for even older models for years now. Have you tried installing it w/o bothering w/drivers at all? Basically, you turn on the printer, open the printers dialog>add new>then click network printer (assuming you're using the wi-fi on the printer). In Mint, I usually wait 1-2 mins. & it comes up with the printer listed by IP automatically. Now, I'm speaking of Mint- not 100% sure on Ubuntu but it ought to be very similar...
If that somehow doesn't work, then go here & follow the excellent walkthrough:
http://hplipopensource.com/hplip-web/install/install/index.html
Please report back if it solves it for you.
Cheers from Australia!
Feb 09, 2015 | HP Envy 4500 e-All-In-One Printer, Copier,...
HP Deskjet 1000 use with Linux operating systems
Question is old, but just in case:
installing HP printers in Ubuntu is very easy:
https://sites.google.com/site/tipsandtricksforubuntu/printer-info/hplip-driver
I am copying instructions here just in case site would go down:
  • open a terminal (Applications > Accessoiries > Terminal)
  • type the following command: sudo add-apt-repository ppa:hplip-isv/ppa
  • press Enter and if needed, type the required password
  • type the following command: sudo apt-get update
  • then type the following command: sudo apt-get install hplip
HPLIP is mentioned on official HP support pages as solution how to get HP printers working on linux.
Jan 19, 2012 | Office Equipment & Supplies
How do i create and calibrate my HP printer
Calibrate required for Color laser printers only, not for mono laser printers..
Dec 12, 2011 | HP LaserJet 3050 All-In-One Printer
Im looking for a linux recovery disc for my acer aspire one zg5 netbook
I don't think you will find a recovery CD but Linux is free to download is suggest using pen drive linux (link bellow) to get the OS you want and the tools you need to make your boot media
http://www.pendrivelinux.com/
If you are looking for a simple install and a easy to use version of linux I suggest Ubuntu (link below) the website comes with simple steps to create a boot CD/USB
http://www.ubuntu.com/desktop/get-ubuntu/download
Mar 17, 2011 | Acer Aspire One Netbook
At a startup performing calibration initialization long HP Color Laserjet 4600dn
Calibration bypass
During certain diagnostic procedures, you will need to bypass the automatic calibration that is
performed whenever the printer is turned on.
To bypass calibration
1 Turn the printer on and watch the control panel display.
2 When the display begins showing the memory count, press and hold until all three lights on
the control panel are lit.
3 Press .
4 Press PAUSE/RESUME. The display should show SKIP DISK LOAD.
5 Press until SKIP CALIBRATION is highlighted.
6 Press . The printer will skip calibration and then continue its power-on sequence.
Please refer here for further details if required
Let me know if any further clarification is required. Hope this helps!
CreativeTECH
Nov 26, 2010 | HP LaserJet 4600dn Color Printer
I am currently trying to uninstall my old HP printer. I don't have it anymore and a new one is on its way, but I can't get it to uninstall. I believe I need to reinstall it to uninstall it. The...
are you really running LINUX or did you join the wrong forum?
windows.
the drivers never need uninstalling
just the HP application programs.
so you do to Control panel
then click, programs.... bla bla.
unstall HP printer apps.
done
if linux tell the linux you are running ,its like 100s of distrubutions and times zillions of releases, like Red hat, or opensuse or Ubuntu, my fav.
tell the helper what PC is this. xw4600a
and what OS exactly.
Apr 27, 2017 | HP xw4600 Workstation Linux Installer...
Is there a linux friendly printer?
most people say that HP is most likely the work, while Canon is least likely. however, there is a list here http://www.openprinting.org/printer_list.cgi?make=Anyone that shows the printers others have had success with.
Jun 07, 2009 | Office Equipment & Supplies
Old printer w Ubuntu
unbuntu forums will lead you to a site with drivers for Linux hp might also
Dec 24, 2008 | Canonical Ltd. Ubuntu
Scanning with Laserjet 3050 on IMAC with leopard
Correct me if I am wrong but doesn't this printer come with mac drivers? But I am not supprised to head that HP is alienating you. They do the same for Linux users. Although there is a growing base of support coming from HP. Maybe you should switch to Linux.
Jan 10, 2008 | HP LaserJet 3050 All-In-One Printer
79 people viewed this question
k24674
