Question about Sharp LC70LE640U 70-inch LED/ LCD TV
I'm getting sound from my sharp tv when hook uo to my blu-ray player
    Top Expert:
  • Sharp Master
  • 14,553 Answers
If I understand when the blu-ray player is connected to the set you get the TV sound or what? If properly connected by way of a set of rear audio/video or component jacks to the same on the TV--you should if change the TV input to that location see the blu-ray and hear sound it sends out.
Component, composite, or what is the hook up between the two units?
Posted on Dec 05, 2012
  • 3422 Answers
SOURCE: Sharp Aquos LC42d64u has blurry picture...
Is it slow and blurry? if yes then return it to warranty immediately. The video processing circuits are malfunctioning and the repair cost is prohibitive if you must pay for it on your own.
I hope it is still under warranty. So, do not delay getting it into the Sharp Authorized facility or back to the retailer you purchased it from.
The connection cable you use could have something to do with it, but is should work on all formats. The best for reliability and absence of blocking is just analog composite - but that is also the lowest picture resolution. S-video is okey too, but it is analog as well. Component is the highest grade; going to hdmi is just another way of receiving the signal - I don't think it will effect the error correction problem in any way. My opinion.
Goodluck..
Posted on Feb 25, 2008
  • 10 Answers
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Posted on Jan 08, 2009
moorah1
  • 181 Answers
SOURCE: when I set my blu-ray player, that is hooked up
did you get thru the menu? it might have an option to switch between resolution or the auto mode.
Let me know what you found out.
good luck.
Posted on Jan 26, 2010
SOURCE: Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Posted on Apr 25, 2011
  • 81 Answers
SOURCE: My Sharp Aquos LC-40E67UN is plugged into a Sony
Wow it seems as though you've pretty much done all of the applicable troubleshooting for this issue. The only other thing I can advise in this case is to consider purchasing a SD card. Some Blu Ray players require a little extra memory to function properly so they come with an SD card slot. Of course no one tells you this when you buy the player but it may be the solution to your problem.
Posted on Jul 18, 2011
I have a 39 inch Emerson hdmi led tv and it is hooked up to Directv. I'm trying to hook up my daughters DVD player it is a Sv 2000 DVD CD player e everything is hooked up we get sound no picture.
hi try using RCA cables to make sure youre connections r not the problem..plug the rca cables n the output of dvd then into tv input & set tv input to AV .good luck
Sep 02, 2015 | Emerson Televison & Video
Hookup Blu ray player to Onkyo pre-amp for speakers
If you have audio out jacks from your tv, you would be better served hooking that up to the preamp. If you hook up the blu-ray player separately to both the tv and amp, the audio probably will not sync with the video correctly. The tv takes longer to decode the hdmi input and the audio will be ahead.
Jan 22, 2013 | Onkyo Audio Players & Recorders
IS THERE A WAY TO HOOK ETHERNET TO A SHARP BR MODEL BD-HP20U
You can connect it by any way to your BDP. There are cables to connect in between. HDMI, S-Video & AV. After connecting these cables with your TV, select the appropriate selection to video by TV.
Jun 01, 2012 | Sharp AQUOS Blu-ray Disc Player
Hi, I just bought a blu ray home theatre system and hooked it up, the surround sound sounds great but it only works when my watching a movie with the blu ray player... I hooked the blu ray player to my tv...
If you want everything to have surroud sound, it all has to run through your system and you select which function to use. Yes it sounds like improper connections.
Sep 03, 2011 | RCA Audio Players & Recorders
My Sharp Aquos LC-40E67UN is plugged into a Sony Blu Ray home theatre system BDV-IZ1000W. It is hooked up with an HDMI cable. I get sound but no picture on the TV. If I unplug and replug the HDMI cable...
Jul 18, 2011 | Sharp Televison & Video
Just hooked up our Panasonic Blu Ray and we have picture but no sound?
Hi, some tv's and some blu ray players have an option in the settings for HDMI or Sound, usually says something like 'Sound Through HDMI' - 'Yes' or 'No', you would need to select yes in the menus for both if this applies.
Some tvs & blu rays don't output or receive sound through the HDMI lead (check the specs to see) in which case you will have RCA inputs near to your HDMI socket on the TV and RCA outputs from your Blu Ray player....., you will need to connect a stereo RCA lead to get sound from your player through your TV.
Hope this helps? (I don't know the models so cant help any further than this)
Feb 20, 2011 | Televison & Video
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
Not getting a picture on my sharp 37' lcd 1080p tv
Not sure if you still need help but I will suggest a few things if you have not solved the problem or returned the unit.
Have you tried connecting it to one of the other HDMI inputs?
Have you also tried using the component video out from the Blu-Ray to one of the RCA inputs on the TV to see if the player is working at all? Is there another TV that you can connect it to, to test the player?
Without knowing the model of TV I am limited to solutions I can suggest. Try those and if you need more help, let me know.
Cheers
Dec 27, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Vsx-94txh
If I'm not mistake, it's dependant on you monitor's ability to display 1080p. I believe the defaul setting on the 94TXH is to read the TV's max resolution and anything above will not feed.
Dec 22, 2007 | Pioneer VSX-94TXH
Sharp LC70LE640U 70-inch LED/ LCD TV Logo
173 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
