Question about Toto Aquia II Dual Flush Toilet
Flush Valve leaking
The toilet keeps coming on because of a slow leak in the flush valve. It may only be the flush valve gasket that needs replacing - 9BU064E. I replaced this part only a year ago from a local supplier who just happened to have one in stock. If I need to replace the entire valve THU224 where in Canada ( Vancouver Island ) can I buy one? ToTo USA does not ship to Canada. Where can I buy just the gasket? Thanks for your help.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 51 Answers
Replace the whole valve. It's cheap and easy to do. Probably you can install a universal valve. Look on e-bay or amozon
Posted on Jan 27, 2014
5 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: I purchased a Toto Aquia
If this is one of those models that most people have, the valve that shuts the incoming water off when the tank is filled is probably bad. It only costs about 8-10 dollars to replace. This valve is actually a stem or tree shaped device.
Posted on Jan 28, 2009
  • 17 Answers
SOURCE: The bowl on one of our Toto Drake toilets, after a
The small tube that comes from the Korky fill valve needs to go down the center of the tube in the tank. It should have come with a clip to clip it inside the fill tube. If the tube is running water into the tank it is just filling up the tank, not the bowl. The tank is filled with the Korky valve from the top of the tower, not the black hose. See the video below to see the black tube I'm referring to and where it should be attached.
http://www.youtube.com/watch?v=bfE8gBV0gHI&feature=player_profilepage#t=92s
Posted on Jan 10, 2011
  • 59 Answers
SOURCE: I have a one piece toto toilet that just started
if the flapper is on a chain, you just need to shorten slack on chain to handle.
Posted on Apr 10, 2011
tbirdfan1
  • 3051 Answers
SOURCE: the flush valve on my
hello there and welcome to fixya
Yes this will certainly fix the problem do not forget to adjust the new part a lotof people do not adjust it correctly
Posted on Aug 18, 2011
Leaky Seal
By leaking do you mean onto the bathroom floor, or is water escaping out the flush valve (the part that the Hydroright is seated in) into the toilet bowl. If the former 1) check toilet tank mounting bolts/gaskets for deterioration or looseness. These are usually 5/16"x3" brass bolts with rubber, plastic, and metal washers with a nut. They can be seen protruding through bottom of tank. 2) check flush valve and rubber gasket between tank and bowl. The flush valve is the one that the refill tube goes into and the hydroright seats into.
If you are only leaking water into bowl I would suggest the blue dome gasket ( part of Hydroright kit) is not properly seated properly into flushvalve, and you may have to re-install hydroright (the instructions explain how to remove and re-install) . I broke my existing/old flush valve at the base when trying to install my Hydroright so maybe it was fortuitous that it broke and I had to install a new one. Hope this helps.
Dec 15, 2013 | HydroClean Hydroright Dual Flush Converter...
Water leaks from tank to bowl all the time
It is most likely the flush valve gasket. This is the equivalent of a flapper on a normal toilet. You can purchase these seals at plumbingmall.com 750017 Outlet Valve Seal for M5 Flush Valve
Aug 06, 2013 | Caroma Sydney Smart 270 Elongated Dual...
It's leaking from the flush valve. I cleaned the top of the valve lip and replaced the flapper. This improved the problem but it still leaks alittle. The toilet is only two years old (...
You need to replace the flush valve gasket. It comes in a flush valve kit, it's a rubber gasket that goes between the tank and the bowl. You just pull the tank off and it's on the under side of it. Be careful the black stuff on the gasket doesn't come off your hands. Make sure you get the new one on there even and all the way on. This will fix your problem. Good Luck
Tool Belt Diva
www.toolbelt-diva.com
May 15, 2011 | Crane Plumbing 3755 Toilet-To-Go Metro...
A small intermittent water leak in the flapper flush valve unit which also causes "water hammer" in the copper piping in the basement. New flapper valves did not solve the problem Sanding...
Older Eljer toilets are good for this and yes you need to replace the complete flush valve assembly. I would recommend putting in a fluid master system as they in my opinion are the best. Their kits come complete with everything you need to do the job and provide excellent instructions and if that is not good they have videos on their web site. The site is slow to load but worth waiting for.
http://www.fluidmaster.com/
Mar 08, 2011 | Eljer Home
Can't install new Kohler rialto Flush Value
First things first, remove the fill valve, and the flush handle mechanism. This will give you plenty of room to work with the flush valve. Before installing flush valve lubricate tabs with plumbers grease. Now put on a pair of work gloves, pushed down very hard and turn the tabs should slide easy because of the grease. Remember do not alter the gasket, the gasket needs to be compressed to do its job. I know removing the fill valve and the flush handle seems like a pain, but there is no way to get your hands in the proper position to install the flush valve assembly.
Apr 25, 2010 | Kohler K-3386-0 Rialto one-piece...
Toilet tank looses water over time
As long as there is no water leaking from the tank to bowl connection, you are OK. You would know if it was leaking here, because you would have water dripping out onto the floor.
Verify that the water level in your tank is below the top of your new flush valve's overflow tube. If the water level comes to the top, it will overflow into the toilet bowl. This can be easily fixed with an adjustment to the fill valve.
If the water is not overflowing into this tube, then the only way you can lose water is through the flapper. You said you changed the flush valve, which would have come with a new flapper attached to it, but maybe buy a new flapper and see what happens???
Jan 19, 2010 | Eljer Aqua-Saver 12" Two-Piece...
Water leakage from the gasket under the flapper
You will need to replace or repair with new gaskets your flush valve mechanism. "To do that you need to take the tank apart from the bowl. Have new toilet bolts and flush valve or flush valve gaskets at the ready when you take the tank off. (you will also have to unhook the fill valve when you take the tank off.) Another possibility would be a cracked tank that is causing the leak in that area but that is rare.
Oct 07, 2009 | Eljer 111-1000-00 White Kindergarten...
Cheviot Wall hung toilet flush valve replacment gasket
try a plumbing supply co. they may help you
Jul 02, 2009 | Home
Champion4 leaks water through flush valve
You have replaced the flush valve completely? If so and the unit is still leaking, you may have a small crack in the tank or your just not getting the tank to bowl fittings tight enough. Also, they make two different thicknesses in the tank to bowl gasket. Make sure you are using the thicker of the two. You posted this under the American Std. thread, so if this is correct, give them a call. There could be a recall on this particular toilet due to a flaw.
Apr 04, 2009 | American Standard AMERICAN STD 12 RGH...
Toto Aquia II Dual Flush Toilet Logo
387 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
