Question about Toys
Arrow hawk 3.5 ch gyro metal helicopter parts
Helicopter blades
SOURCE: need spare part for double horse 9086 helicopter part, main rotor
Hi, you can get all the parts you need for this model from Hobby-Field.com.They come from Australia but it is quick and a lot cheaper than anything you can get here if you're lucky.
good luck johna4941
Posted on Jan 10, 2009
SOURCE: i have an apache 3 channel helicopter.the top
Same problem I had. There are two motors. One to spin the top blade and a second to spin the bottom. My motor was defective out of the box to spin the top blade. Very poor quality as my AH 64 had a bad circuit board. I had to take parts from one to fix the other.
Posted on Sep 12, 2009
SOURCE: we have two gyros S107G remote control
Had the exact same problem. Found the solution on an Amazon posting:
1. To enable this function make sure both remotes and both helicopters are off.
2. Set the first remote's channel switch to the leftmost position (it says A, B, and C, but the s107 only supports 2 channels). Turn the remote on.?
3. Turn the helicopter that you would like to bind to the remote on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the helicopter should respond to this remote.?
4. Next, to enable the second helicopter, set the second remote's channel switch to the rightmost position (it says A, B, and C, but the S107 only supports 2 channels). Turn the remote on.?
5. Turn the second helicopter on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the second helicopter should respond to this remote.?
This worked for us.
Posted on Dec 26, 2010
Testimonial: "excellent help. thanks a ton. now we'll just hope for no mid-air collisions. appreciate it!"
  • 26 Answers
SOURCE: I have a UJ 420 infrared remote control helicopter
Have you checked for any hairs or debri trapp-ed on the rotar shaft
sorry have to ask the silly questions check for voltage at wire terminals
some of the controls have automatic kill switch should they become binded up with something check that rotor is not installed to deeply on the shaft
could also be a short circuit in the remote itself good luck James
  • 3 Answers
SOURCE: i just got an r/c helicopter ( gyro s032 ) i've
couple of things possible. 1) change outlet. 2) call customer service for the helicopter (should be on manual in contact section) 3) the helicopter has a loose cable connected to the battery inside the helicopter so you probably need to sodder it.
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
My S031 when powered up floats backwards and drifts sideways, just put on new blades did not fix the problem can anyone help
Helicopters are not easy to fly, they are not naturally stable. New blades do not solve the problem, this can only be achieved by training and very delicate movements of the cyclic pitch control. I recommend to use a larger skid (broader) or some light device that enlarges the skid surface (to avoid tilting and damage). But be sure that a coaxial helicopter is easier to fly than any conventional model with just one main rotor and anti-torque tail rotor.
Jan 28, 2015 | Syma S031 Gyro 3 CH RC Helicopter Orange
Syma s031
Make sure the battery is connected and the Helicopter and remote are both turned on on the same channel. Antenna is secure and extended.
May 11, 2014 | Syma S031 Gyro Metal Frame 3.5 CH RC...
How could i use my iphone 4g to control my toy helicopter
Instructions
    • 1 Remove the main rotor blades, throttle up the helicopter while holding it in your hand and twist the helicopter from side to side to determine if the gyro is working. The gyro should make the tail rotor spin faster when the helicopter twists; you will be able to hear a difference. If the gyro does not appear to be working, replace it. Some gyros have a sensitivity adjustment screw; try making small adjustments if possible.
    • 2 Check the tail rotors and see if they are connected correctly. If the tail rotor blades are not pitched correctly they will not be able to hold the helicopter still.
    • 3 Test the tail rotor motor and see if it seems strong and responsive. Brushed motors, like those commonly used to drive tail rotors, can wear out in a relatively short time. Replacing the motor may solve your problem if the gyro seems to be working.
    • 4 Check the trim on your transmitter. Ideally the trim should be in the center of the stick movement. You may need to dial in some extra right trim or you may find the trim is set too far to the left.
Jan 20, 2013 | Toys
I recently purchased a Fast Lane Hawk 4 rc helicopter. After a few small "crashes", it shakes and doesnt fly well. Does the top rotor need replacing, and if so, can I get the parts for it?
I have the same one, i have searched long and hard for parts for this without much sucsess, allthough i have found this on ebay, the blades and rotor look very simular
http://www.ebay.co.uk/itm/Metal-3-Ch-RC-Mini-Helicopter-Main-Tail-Blade-SET-G-/140315300745
Its slightly diffrent but i think the blades should fit the hawk 4. In the mean time i shall keep looking.
Sep 20, 2011 | Toys
I get no signal. i have checked everything. the batteries, the on/off switch, and charging it. WTF?
same thing happened to me i think somethings wrong with the antana in the helicopter take it to a electronic shop like redio shake or something
Jan 03, 2011 | xheli Double Horse 9074 3 CH RC Metal...
Crashed blade 400 repaired it unsure of servo settings helicopter tilts forward and tends to spin around
Try setting gain on Gyro (use small plastic screwdriver) to a straight up and down position.
Set Gyro setting in Transmitter to 75%. NOTE: before turning on helicopter, be sure to center all adjustments on transmitter
Side switch on GYRO to DS and make sure the servo is moving in correct direction. If not. reverse direction with switch on side of Gyro. You may need to reverse the controller of Rudder in settings on transmitter.
This worked for me on my Blade and using the same Gyro on a self build 450 heli.
Helimangler
Apr 20, 2009 | E-Flite Blade 400 3D RTF Electric Mini...
Need blade for world tech skyhawk helicopter
Syma DragonFly 9093 or 9083 rc heli... has the same exact size tail blade... just put one on myself... works fine..
Dec 23, 2008 | Toys
Toys Logo
85 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
