Question about Dishwashers
The water in my GE potscrubber 700 wont drain
I cleaned out the traps in the bottom of the unit and it still doesn't drain. I hear the pause in the cycle where it should be draining but doesn't sound like the pump it sending the water to the disposal.
aborcass
  • 2651 Answers
SOURCE: dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
SOURCE: dishwasher
GE 720 Potscrubber I started with the water puddling in bottom now it progressed to leaking on the floor. I had a repair guy come to my home yesterday and he says a broken seal and my total cost to replace seal and labor is $165 plus tax.
What is the life expectancy? He did not sound too promising about the future of my dishwasher and said he is certain there will be another repair need shortly something related to the water saturating an area underneath the dishwasher?
He reccomended I call Sears and replace with a Whirlpool product. He claimed he put his kids thru college repairing GE products. My husband wants to repair and I dont because of fear of spending more money!
Posted on Apr 26, 2008
bigg t
  • 640 Answers
SOURCE: water not draining
For starters does it drain at all?If the drain line is connected to the sink drain and you have a garbage disposal,the drain hose could be plugged up.
Posted on Aug 06, 2008
  • 360 Answers
SOURCE: GE Profile PDW7300, Leaves 2 - 3 inches of dirty water in bottom
check for a clogged discharge hose where it connects to the plumbing under the sink...this is the most common area for a clog. if no restriction is found, the discharge valve will need to be tested
Posted on Feb 20, 2009
  • 1891 Answers
SOURCE: My old GE potscrubber 700 dishwasher stopped working
moter has probably locked up TAKE FRONT LOWER PANEL OFF AND YOU CAN ROTATE ROTOR/ if itis not free and rotates easly then the motor has failed / mm
Posted on Dec 07, 2009
I have a GE 1200 Potscrubber portable dishwasher it was running good until it started to drain then water started coming out the bottom is there a way to fix this? Please help me.
You can take the unit and lay it down. There will be some water leakage. You can then see the hoses and connections. Sounds like the drain hose is either cracked or loose.
Feb 08, 2014 | Dishwashers
WATER LEAK BOTTOM OF UNIT
If this is a central AC, the
condensation drips off the cooling coils into a pan. From the pan, it is suppose to either go into a drain directly or into a sump, which in turn pumps it into a drain. Dirt or mold frequently plug the drain out of the pan or the drain line itself. You need to clear the drain with a wire or forced air. If there is a trap in the drain line, it may be plugged. If there is a trap and the line is not draining from the trap into a sewer, then I suggest you remove the trap, which is intended to block sewer gas from coming up the drain line. If it doesn't drain into a sewer, there is no sewer gas to block and the trap is unnecessary. The credulous building code requires the trap, regardless of whether or not the unit drains into a sewer.
If you are talking about a window unit, the problem is similar - the water is being blocked from where it is supposed to drain. With a window unit the water is usually picked up by the fan that cools the
condenser (hot coils) on the outside of the unit. The fan sprays the water on the hot coils and evaporates it so it doesn't drip out of the unit.
Oct 04, 2012 | Goodman CKL49AR49 Air Conditioner
Asko 12505 fills with water, doesn't rotate, doesn't spin or drain.
Hello.
If your washer is indeed a WFL2066, than the not spinning is directly relatedto the unit not draining.
These machines by design cannot spin if the drain is inadequate.
Here is the first step in resolving the problem, you need to access the drainpump/filter to clean it.
To reach the filter and clean it...
**Unplug the washer from the dryer or wall, or turn off the 30amp breakerat the home service panel...safety first**
1) Open the small square plastic door at the right bottom of thewasher.
2) Via the small hose drain any access water from the pump...this is where awet/dry shop-vac comes in handy, or a shallow pan with a few towels works aswell.
3) Then turn the pump insert/button trap counter clock-wise and pull out.Clean the trap out thoroughly running it under hot water and mild soap or yourwasher detergent and inspect inside the pump for any other foreignobjects/obstructions.
4) Re-install the lint trap insuring it is good and snug/tight. Beforeclosing up the small access door, run a short rinse spin cycle to check forleaks.
Let me know how you make out, or if you require further assistance.
Thank you for visiting our site please take a moment to rate the infoprovided for you here.
Thanks.
Sep 30, 2011 | Washing Machines
Water inside unit, you can hear it when running. I know it's suppose to be normal in high humidity, but the unit was making a loud noise the other night so I had to turn it off. sounded like the fan
The unit is not draining properly. Make sure it is leaning back in the window. If you put a level on the top of the unit, it should be leaning back away from the window about a half bubble. If it still doesn't drain after this, the drain may be stopped up. The drain will either be in the bottom of the unit or on the back. If you try to clean the drain hole be careful not to use anything that will poke a hope in the rear coil. You can use compressed air.
Jul 03, 2011 | GE AEV05LN Air Conditioner
Dec 07, 2009 | Dishwashers
Bosch dryer warning sounder for container full will not stop
Hi
You need to remove the left side panel, this is the side where the drain container is, once removed you will see the drain pump with two pipes coming from it, remove the pipes and top cover, disconnect the wiring, remove the pump unit with the clip, clean the float unit and pump, also remove the congealed mess in the water trouth as this is what holds the float up and makes the machine think the drain container is full.
I bet you will find this will cure the problems you are having, it did with mine.
Sep 07, 2009 | Bosch Dryers
Water not draining
Aug 06, 2008 | Dishwashers
GE potscrubber 700
upc leaks when dishwasher is emptying
May 12, 2008 | GE Dishwashers
Dishwasher not draining fully
Remove and replace the motor / pump assy. Call technician. Big Job
Dec 02, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Not cleaning properly. Not Draining properly?
Don't Buy GE :)
pump may me clogged does it drain, can you hear water spray. is water filling into unit on start up? I had to take pump of bottom of mine had piece of tooth pick jammed in impeller + GE just stinks anyway. I will never buy again
Jul 04, 2007 | GE 24 in. GLD5860LSS Stainless Still...
Dishwashers Logo
204 people viewed this question
Top Dishwashers Experts
