Question about Lenovo ThinkPad X220 42962WU 12.5 Tablet
Getting touchpad sensitivity to stay set.
I can change my touchpad sensitivity and apply it, but it always goes back to default after closing the lid and going to sleep.
  • Lenovo Master
  • 7,627 Answers
Try changing and reboot. then shut down the machine, unplug.
Posted on Dec 05, 2012
Touchpad too sensitive
Click Start/Control Panel and look for the mouse or touchpad. Go into the touch pad and you can adjust all kind of things. Don't worry about messing something up, you can always set it back to Default.
Apr 05, 2012 | Computers & Internet
How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
Touch pad is way too sensitve and any hint of accidentally touching it send mouse and/or characters all over the place. Makes this computer very difficult to use.
Try these steps:
1. Go to the Control Panel and double click on Mouse
2. Go through the tabs in Mouse Properties window & find the tab where you can set up your touchpad. This differs from laptop to another since it is based on the touchpad's drivers.
3. On that tab, find the "Sensitivity" setting. Try changing this setting to lower the sensitivity of the touch pad to the degree you find acceptable.
4. Click "Apply" to apply the changes, then close the "Mouse Properties" window.
May 16, 2011 | Sony 4-660-223-01 Touchpad Keyboard
My cursor moves as i type what can i do
You seem to be brushing against the touch pad while you're typing. You need to adjust the sensitivity of that touch pad:
Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers." Select the "Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "Apply." Pick the "Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings." Read the information provided in the next dialog box. It gives you options for tapping your touchpad, using the buttons, scrolling, pointer motion and sensitivity. Make any changes you want from the various topics. When you make a change, click "Apply." Click "OK" when you finish making all your changes. Do some work on your computer for a while. If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Jan 01, 2011 | Computers & Internet
How can I disable the mouse tapping function on my dell latitude e5400?
  1. Click Start.
  2. In the Search box type main.cpl, click main.cpl in the list of programs.
    • In Windows XP click Run, type main.cpl in the box next to Open, click OK.
  3. Click the Dell Touchpad tab.
  4. Click on the picture of the touchpad.
  5. Click Touchpad Settings.
  6. Make sure there is a check in the box to the left of TouchCheck, move the slider bar all the way to the right (this can always be adjusted back).
  7. Uncheck the box to the left of Tap to Click.
  8. Move the slider in the Touch Sensitivity area to the right until it is 3/4 of the way toward Heavy Touch.
  9. Click Apply, then click OK.
  10. Click the X in the upper-right corner to close the Dell Touchpad Utility.
Sep 23, 2010 | Dell Latitude E5400 Laptop
Touch pad too sensitive, it always messes me up when I'm typing
You could try adjust the touchpad settings. Sometimes there is a touchpad icon in the taskbar that you can right click on to adjust the properties. You can also disable the pad and use a USB mouse instead.
Sep 11, 2009 | Sony 4-660-223-01 Touchpad Keyboard
My touchpad is too sensitive
1. Go to the "Control Panel" and double click on the "Mouse" item.
2. Go through the tabs in the "Mouse Properties" window & find the tab where you can set up your touchpad. This differs from laptop to another since it is based on the touchpad's drivers.
Nov 26, 2008 | GPX D1816 DVD Player
Dell xps M140 laptop touchpad
I have the same problem and it sucks. Not sure how to fix it.
Feb 15, 2008 | Dell F3534 Touchpad
Sensitive touch pad
Hi, click on start and control panel. go to mouse properties. Try to look for a tab that says either touch or touchpad. you can change the sensitivity settings there. however if this doesnt work, this could only mean that this is a physical problem with the toucpad. try to apply pressure on the outer side of the touchpad. if it moves, you're gonna need a replacement palmrest.
Oct 02, 2007 | Dell F3534 Touchpad
Lenovo ThinkPad X220 42962WU 12.5 Tablet Logo
182 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
