Question about De'Longhi ESAM6620 Gran Dama Super Automatic Beverage Center w/ Automatic Cappuccino
DeLonghi 6620 wont pump water
New start up, keeps saying insert water spout, i'm thinking an air lock.
Coffee comes out fine, wont deliver milk or hot water from spout
Sounds like milk steam apparatus is clogged. Try to disassemble this portion and clean thoroughly. Descaling will not help this section.
May 04, 2016 | DeLonghi Magnifica Coffee Makers &...
Empty circuit fill circuit insert water spout press ok
when inserted the water spout if the water is delivered,that means you have an issue with the flow meter and you have to tack it to maintain,
how ever if the message (fill circuit ) turned off after the posses of filling the circuit and when you are trying to brow coffee the message shows, that means the grinder is too fine adjust it and try ones more
Apr 12, 2015 | DeLonghi PrimaDonna S Deluxe Super...
"GROUND TOO FINE ADJUST MILL! Insert water spout
  1. Insert steam spout and push OK.
  2. Fill your tank and add descale solution.
  3. Go to program settings - Descale.
  4. Follow the prompts on the readout.
  5. After descale and rise are complete refill your water tank.
  6. Your system should now work as normal.
Note: If you do not have a descale solution, run the above with just water. Remember to descale when you obtain a descale solution.
Sep 27, 2013 | DeLonghi Perfecta ESAM 5600 Espresso...
Flashing coffee and descale
Identical problem, descale light doesn't extinguish despite descaling correctly. Coffee continues to be made as normal though ! Any solution ideas please ?
Mar 04, 2013 | DeLonghi Coffee Makers & Espresso Machines
Delonghi Perfecta won't froth milk or allow hot water to come out from waterspout
Aug 20, 2012 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Initial set up of delonghi ESAM6700 and it will not go past insert water spout stage. Even when spout inserted it does not recognise and we cant continue setting up the machine as it simply reads insert...
OK, I can answer this one... the same thing happened to me. It would not recognize the water spout. No beep when inserted, but it would beep if you inserted the milk container. Looking into the receptacle, I saw that the switch for the milk container is offset to the right, and the switch for the water spout is offset to the left. All I had to do was carefully bend the lower tang on the water spout that activates the switch to the left a little bit. It looked perfectly straight, but was just offset to the right enough to miss the switch.
Hope this helps someone.
May 08, 2011 | DeLonghi Prima Donna Avante ESAM6700...
Delonghi Magnifica 3500.. error message says "grind too fine, adjust grinder, insert water spout, press ok" message never goes away. I called the Customer service.. she said try again.. to...
Try removing the beans from the hopper and use a vacuum to CLEAR/REMOVE any grounds and then adjust the grinder 4 clicks clockwise. If this works Re-adjust grinder to where you get nice crema.
You can try using all ready ground coffee by following the instructions in your manual (if you don't have a manual let me know) to test it.
Jan 12, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
De'Longhi ESAM6620 Gran Dama Super Automatic Beverage Center w/ Automatic Cappuccino Logo
54 people viewed this question
Top De'Longhi Coffee Makers & Espresso Machines Experts
ray gallant
Tom Chichester
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a De'Longhi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
