Question about Amana AOES3030 Electric Single Oven
Oven beeps and flashes F1 Glass top burners work but oven doesn't.
I have had what the repair man calls the relay switch replaced due to the same problem. In less than a year the problem resumed. I would like to know how to purchase this switch as well as repair it myself. I can't afford to have a repair man replace this every year.
    Top Expert:
  • Amana Master
  • 9,472 Answers
F1 is for the ERC failure and it will need to be replaced. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Posted on Dec 06, 2012
Testimonial: "Thank you so much for the info. I really appreciate your help! Diane"
Krazytech
  • 725 Answers
SOURCE: F1 error on SS Amana Convection wall oven
F1=Electronic range control failure
It is telling you may have a fauilty control...need to replace control or EOC
Posted on Jun 04, 2008
SolutionGuy
  • 331 Answers
SOURCE: AOCS 3040WW convection oven
F1 Error code for Amana indicates a failed electronic range control (ERC)... that's the main computer behind the keypad. Post back with the exact model number and I'll assist with part number and replacement procedures.
Posted on Aug 29, 2007
docjohn174
  • 943 Answers
hi in the amana fault codes it says to replace the clock.its faulty thanks
Posted on Oct 16, 2008
pride applia
  • 232 Answers
SOURCE: bottom oven won't turn on;
85% of these are usually the ignitor getting week and not allowing the gas valve to open prideapplianceser@sti.net
Posted on Jan 01, 2009
jumptrout51
  • 3361 Answers
SOURCE: The oven burner will not ignite.
Because the glowbar is glowing does not necessarily make it good.
Turn off the gas to the stove. Remove the oven racks. Remove the bottom oven pan. Remove the flame spreader. This gives you access to the glow bar and gas valve.
Put a clamp on amp meter around one wire of the glowbar. Turn the oven control on to BAKE.
If the glowbar reads 3 amps or less,replace the glowbar ignitor.
If the glowbar reads good,check the burner tube for a white ash buildup. It can be cleaned with a wire brush. Look closely near the glowbar section of the burner.
Check all the wire connections for the gas valve.
If the glowbar is good and the ash deposits are gone and the oven still will not ignite,the next step is to replace the gas safety valve.
Posted on Dec 01, 2009
The digital controls on my frigidaire stove do not work. It beeps continually and it flashes F1 on the screen. The oven doesn't work but the burners do. I've tried what it says in the manual to...
F-1 is a sub-code for a few different issues. A button could be stuck, oven cavity getting too hot, or the control has a memory failure. Any of those three failures would require a new control. But first, what happened to the range when it first failed? If you unplug it and try again, what happens?
Aug 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Bake pre heat isn't working broil and top burners
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 07, 2011 | GE Ovens
Amana self cleaning oven Model ACS7270AS, Seril 10924419AT F1 And F5 code come on control panel and continuous beep. All burners and other oven controls seem to come on ok. How do we clear the beeping...
Both F1 and F5 are the code for a board failure; it would need to be replaced. What you could try is disconnect the oven for a few minutes and then turn the power back on. If that does not do the trick you would need a board
May 24, 2011 | Ovens
Oven "bake" burner wont ignite on a gas oven.
heatman101
Dec 27, 2010 | Whirlpool Ovens
Error Code -F1- and Broken glass door
Welcome to fixya.com f- 1 is the electronic key pad a key is stuck and usually you will need to replace the key pad site to obtain parts is partsselect.com but before you do disconnect power to unit for 15 min then re connect power to see if unit reset its self. And at Parts select.com you can order the glass you need, Regards, Lee Davidian
Apr 19, 2010 | GE Profile JTP56 Electric Double Oven
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
F2,F5,F7 message
MAYTAG
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Feb 07, 2009 | Maytag MEW5527B Electric Single Oven
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Dacor cps130 wall oven f1 error
According to the manual, this is an element relay circuit failure. Call the tech.
Dec 04, 2007 | Ovens
Amana AOES3030 Electric Single Oven Logo
142 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Ismael Rodriguez...
Are you an Amana Oven Expert? Answer questions, earn points and help others
