Question about GE WBSR3140DW Top Load Washer
Removing agitator from GE ADORA 5250
Clothes are jammed under the agitator
rickzilla
  • 706 Answers
SOURCE: drawstring tangled under agitator on an older GE washing machine.
You should be able to unscrew the top cap of the agitator ( may be left hand thread ) and lift off the agitator once the cap is off... They sometimes stick so you may have to muscle it to remove that cap..once lifted off..you should be able to untangle the string that is caught..
Posted on Sep 21, 2008
  • 1214 Answers
SOURCE: GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Posted on Jan 26, 2009
jumptrout51
  • 3361 Answers
SOURCE: I need to remove GE topload washer agitator
Pull up hard on the agitator. It will come up.
Posted on Mar 22, 2009
dniro592006
  • 121 Answers
SOURCE: how do you remove the nut under the agitator?
theres nothing under your agitator, first take cover off your agitator there should be a small bolt
holding it down, take that bolt out then grab agitator from bottom and pull up it should come off easy.
Posted on Jun 09, 2009
  • 18 Answers
SOURCE: my GE Adora front loader- our clothes stink!
Clothes washing rules for mildew stink: 1) never leave clothes in machine for more than a few hours 2) never add too many detergent or clothes 3) clean the machine itself. Also if your fabric softener port is gummy there is a good chance you got some funk from that so clean all places where you have fabric softener contact. After all that, if this doesn't help you may need to run an empty load of strong hot bleach water and follow it with a hot empty rinse then a load of whites
to becareful not to ruin your colored clothes
Posted on Aug 09, 2009
Clothes getting twisted around agitator
That does not sound good. New dogs sound great, but you must get to the bottom of why the clothes are becoming twisted on the agitator. Usually not enough WATER. Think loose flow of clothes submerged.
Long story short, you cannot jam pack this machine. Less clothes, more water, will equal long life.
Be sure that the mating teeth for the dogs, is not damaged. Slipping here would make loud noise.
More water, less clothes.
Apr 04, 2018 | Kenmore Washing Machines
Clothes & sheets get wrapped in agitator and it makes a loud noise in my Whirlpool wtw4800xq1
Here is a video on how to change a part that could be part of the problem, the video shows how to remove the agitator so that you can remove the clothing that is jamming the machine, http://www.repairclinic.com/PartDetail/Whirlpool-Washing-Machine-Agitator-Repair-Kit/285809/470910?modelNumber=WTW4800XQ1&ss=a11b5d956381&mr=1
Jul 30, 2016 | Whirlpool Washing Machines
Clothing gets caught under the agitator wings like sleeves on shirts, strings on clothing ie hooded sweatshirts.
This is something that happens with most top-load washing machines. As long as the agitator has wings, stuff will get under them. That is one reason that front-load machines are becoming more popular.
May 10, 2015 | Crosley Washing Machines
How to remove clothes stuck under agitator
the agitator should pull straight up, you may have to twist it back and forth as you pull upward. when you put it back on make sure its all the way down and in place, this may be the reason your clothes are getting stuck under it.
Aug 23, 2014 | GE WBSR3140DW Top Load Washer
Clothes stuck under agitator
I would try to get clothes out, even if destroyed first. Otherwise,
there is a plastic cover cap on the top of the agitator. remove
by unscrewing or prying off. Hold down nut is exposed and remove
carefully, gently and with a ballanced pry up from underneath to raise agitator.
Remove agitator from a GE G129 I think, it is model number gtwn4000m0ws
Agitator just snaps into place. If you can get your fingers under the bottom edge of agitator, one hand at 3 o'clock and the other at 9, quickly and firmly pull up. It should come off. It takes a little force to do it though, so be sure to pull up quickly and firmly.
Sep 06, 2017 | Washing Machines
My GE Adora dryer is ripping clothes
look inside the drum with a flashlight and look for broken or loose tumbler rib, can be fixed with epoxy, sand smooth surfaces first, let cure and use appliance paint to paint it
Jun 09, 2012 | GE Adora Super Capacity Dryer
Machine not agitating
The most common cause for the agitator not spinning is a broken drive belt. If you are able to turn the agitator by hand, the belt is likely broken. If the agitator cannot be easily turned by hand, there is likely a piece of clothing jammed underneath and the agitator will need to be removed to clear the jam. The video below will demonstrate the procedure for replacing the drive belt in most Whirlpool washers.
Dec 29, 2011 | Whirlpool WTW5500X Washer
GE WBSR3140DW Top Load Washer Logo
108 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
