Question about Life Fitness 9500HR Next Generation Remanufactured Treadmill
How do i get the hours info from a life fitness 9500 hr elliptical
  • Anonymous Mar 14, 2014
    E6 error
    Top Expert:
  • Life Fitness Master
  • 12,223 Answers
Go to the MENU, and see the details.
However your must read your instr. manual and see how to enter.
God bless you
Posted on Dec 05, 2012
maxtreadmill
  • 832 Answers
SOURCE: I was cleaning life fitness 9500 hr with an acid
I'm sorry to say that using the acid base solution destroyed your function pad and will need to replace. Any clean must be done with simple green or warm gentle soapy water. Contact Life Fitness1-800-351-3737 or Nation Gym Supply 1-800-496-7278 give Model and Serial Numbers. Either company will help you.
Posted on May 10, 2010
maxtreadmill
  • 832 Answers
SOURCE: replacement console
Unplug unit then remove the upper console, their are 4 allen bolts holding it udder the console their is a panel held by 4 phillips head screws also remove them . Look inside the compartment and their should be two connections, disconnect them. Now pull console off its tower. Lay it upside down on a thick towel remove all phillip head screws you'll notice where the emergency stop button is connected. I have found that this connection 7 out of 10 times is causing the problem. Buy cutting the lead connector stripping the wires and soldering back on the male connection will resolve the problem. If not their is a emergency stop kit may be purchased and replace. The only other thing that may cause the problem is the function key pad itself. Try the first solution if your not good in soldiering go to a computer shop , t v shop they should be able to do this very quickly for while your at let the check the switch itself.
Posted on May 18, 2010
Testimonial: "This guy really does know his stuff. I am very pleased I was able to fix the treadmill with absolutely no expense. I simply followed the clear instructions and the machine was up and running in an hour. I would rate this expert 10/10 but actually he warrants 11! maxtreadmill yo da man !"
  • 208 Answers
SOURCE: life fitness 9500 is shocking users? help?
Hi, there is a service bulletin for this problem.
1) perform a continuity test on the power cord between the earth pin at the plug and any exposed metalwork of the treadmill (say an exposed bolt). If you get a reading of less than 1ω - that is good. If higher than this, try another part of the treadmill or trace the cause.
2) Ensure the Power outlet has a good ground - Your electrician could verify this for you.
The most common problems are static buildup on the Striding belt caused by users wearing polyester and scuffing their feet as they are running. This causes static buildup which gets discharged through the user when they come into contact with the treadmill frame.
Happy hunting
Posted on Jul 07, 2010
jyackle5
  • 8197 Answers
SOURCE: How to adjust the tracking
Please read the link below.
http://www.ehow.com/how_5148912_adjust-belt-treadmill.html
Posted on Feb 15, 2011
ercupa190
  • 12223 Answers
SOURCE: What's your problem?I have a life fitness 9100 hr I have a problem how do I clear the message waxer tank empty?
see this step and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
  • Posted on Oct 16, 2012
    How can I convert from kgs to lbs?
    You should be able to find this info in your manual. Thee are several versions of this model. You will need to give a serial number or just look at your manual.
    Here to help 877-805-1030
    Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly...
    Apr 19, 2016 | Life Fitness 9500 HR Crosstrainer Rear...
    I changed the 6 volt battery when i connect the battery leads and used machine i press clear/pause button it will start again. I have to disconnect the battery to turn it off
    If no key is pressed for 15 seconds, and the user stops pedaling, the console shuts down. You can also do the same when starting the machine, just step on the pedals to get them moving and the console should light up.
    Dec 13, 2014 | Life Fitness 9500 HR Crosstrainer Rear...
    9500 hr elliptical
    Sounds like you have a Life Fitness machine, not a Precor. If it does not light up, check the battery - should be in bottom front of the machine.
    Jan 14, 2014 | Precor Exercise & Fitness
    Where is the battery on the life fitness 95xi
    The battery is located in the front of the rear drive mechanism. It is mounted just below the alternator control board. The following video shows the battery location along with the battery replacement procedure. Battery 6 Volt 2 5 Amp Hr LifeFitness 0017 00003 0685 SPORTSMITH net
    Dec 29, 2013 | Life Fitness 95xi Elliptical Crosstrainer
    Eliptical 9500 HR lifefitness lights then stos
    Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
    Start by checking your battery for the proper voltage output. The following are some helpful videos.
    Nov 10, 2013 | Life Fitness Remanufactured 95Xi...
    Life fitness crosstrainer 9500 HR just shut down few second after start
    see the video and fix it. This happen because the lack of maintenance schedule.God bless you
    Apr 04, 2013 | Life Fitness Crosstrainer, 9100, 9500 Rear...
    Finding total mileage and useage hours on a Life Fitness 9500 Treadmill
    unfortunately, is NOT possible, Not miles or kms in treadmills.
    You have to buy the eagle eye.
    God bless you
    Oct 07, 2012 | Life Fitness 9500 HR Treadmill Next...
    Life Fitness 9500HR Next Generation Remanufactured Treadmill Logo
    159 people viewed this question
    Top Life Fitness Exercise & Fitness Experts
    Howard
    Howard
    Glenn Mayer
    Glenn Mayer
    Craig Butler
    Craig Butler
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
