Question about Husqvarna Viking 1
Viking Husqvarna 6360
I just inherited this machine. The cam in the back does not work (it falls right out). All I need it to do is a basic straight stitch (which it's doing a lovely job on) and a zigzag stitch. The dial where it looks like I can set it to zigzag just makes it go in reverse. I'm very familar with Singers, this is my first Viking I've ever worked with.
  • 192 Answers
SOURCE: feed dog switch
Did you turn the handwheel? The feed teeth will not come up until the machine is operated. Run it a few stitches and they will come up.
Posted on Nov 01, 2008
  • 13 Answers
SOURCE: I am looking for a husqvarna viking stitch
As I wrote earlier, I also needed one. I purchased one today from The Stitching Post. Located at 101 E. Alex Bell Rd. Suite 176 Dayton,Ohio 45459 937-436-9200. I was told 170.00 but when I got there they were $64.00 and I got half off so, with tax it was $34.24!!! Maybe you could call and have them mail you one with the use of a credit card. They are used but they no longer make these. Hope this helps.
Posted on Feb 27, 2009
  • 371 Answers
SOURCE: viking husqvarna 5530 what do the dials mean?
Assuming you now have the manual. Your local authorized Husqvarna Viking dealer can order a user manual from Husqvarna Viking. A list of authorized dealers is available at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Posted on Sep 26, 2009
SOURCE: repair and opertors manuals?
The cheapest manual I have found for the model 6440 is at http://gotoes.org/sales/VikingSewingMachineManuals/ViewInfo.pl?Viking=1&Sewing_Machine_Model=6440
It is a downloadable version also sent by email.
There is a free threading diagram including bobbin info at www.sewusa.com. Repair manuals are available on ebay and run ten dollars or more.
Posted on Oct 23, 2009
Zenqi
  • 208 Answers
SOURCE: I cleaned my Husqvarna Viking 6690 and now it
I hate to say it, but the 6690 was plagued with circuit board problems. That machine cost Viking a lot of heartache. I'm a bit surprised to see one still working. You didn't specify exactly what you did when cleaning or whether you took the covers off and disturbed the wiring. Check all the connections and plugs, but it might be dead. You can take it to a Viking dealer with experience with the 6690 for an evaluation.
Posted on Feb 21, 2010
How do I set the dials on husqvarna viking 6000 sewing machine
The "dial" in the back is for decorative stitches which require a "programmer" to be inserted with the stitch formation you want to form. For a straight stitch no cam is required in the back of the machine. The three dials on the front:
Upper Left: Stitch selector
Upper Right: Stitch lenght
Lower: Stitch width
Using the upper left dial select the straight stitch picture
Using the upper right, choose your stitch lenght
Using the lower, choose your needle position, left/center/right
Dec 13, 2014 | Husqvarna Sewing Machines
How do sew a straight line on a viking 6360?
You may need to service the machine. One thing to check is the feed teeth are at least 1mm above the needle plate on the highest setting. You can remove the needle plate and check if there is lint keeping the teeth from rising. The upper right knob controls the stitch length set it at 3 for normal sewing. 6 would be a longer stitch.
Jan 19, 2014 | Husqvarna Viking 1
Hi I have a Viking Husqvarna 6360, and although
Dead right, the part you can see is a suppressor which on most machines you don't need these days, snip it off, id the machine does not work when you have taken it off you can get the part from most sewing machine shops
Oct 21, 2013 | Husqvarna Viking 1
I have a Viking 6370 sewing machine. I can not get the stitch selector to turn to select a new stitch. Actually the knob will turn but the outer dial doesnot turn and the stitch does not change. It sews...
Hello
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
Jul 12, 2011 | Husqvarna Viking 1
I have inherited a Husqvarna 4500 from my mother. Everything was working beautifully until I ran out of cotton on the bobbin. I read the instructions and did as directed. When starting to straight sew...
This is not a solution but I am actually looking for the instructions/manual for a 4500 Husqvarna Viking sewing machine. Would appreciate any help. Thank you.
joli.harrington@gmail.com
Jan 05, 2011 | Husqvarna Huskystar 207 Sewing Machine
Viking Husqvarna Model 6020 stitch selector will not turn.
Apr 23, 2010 | Husqvarna Viking 1
Husqvarna Model 6360 reverse button stuck
This problem comes about due to lack of useage usually. If the machine has been sitting for some time the grease inside hardens. The stitch length regulator, the pattern selector and the buttonhole mechanism could all be contributing to your problem. To fix it properly all three dials should be remove from the machine, disassembled cleaned, assembled and oiled lightly with a teflon lubricant. Since so much is removed from the machine doing this job, every setting in the machine is checked and or reset. It's a major overhaul and costs about $350 and only a handful of Viking Techs in the country can do it.
Sep 19, 2009 | Husqvarna Sewing Machines
How to thread my sewing machine? Husqvarna Classica 95
Suggest you contact an authorized Husqvarna Viking dealer. They can order you a user manual. Authorized dealers can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Brief description of probably how to thread from looking at a picture of a Classica 90 machine which should be similar -
Thread sits on spindle on backside. Pull thread straight across to upper left backside and fit in the metal guide. It should pull easily with only a little resistance. Pull thread forward across top toward you. Let thread fall between the metal disks (doesn't matter which one if more than one) and pull thread straight down. Pull thread slightly to the left to fit under a hook of some type and back up to fit through the large hook that moves up and down when the handwheel is turned. Come straight back down to needle and thread through eye of the needle. Just above the needle should be a thread guide (sideways hooking looking metal piece), slip the thread through it to hold thread close to needle. Hope this helps. Otherwise a local authorized Husqvarna Viking dealer will be glad to help you. Good luck.
Sep 19, 2009 | Husqvarna Viking 1
Sewing Machines Logo
369 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
