Question about GE Washing Machines
How to remove the agitator fron Ge Adora 5250
Agitator removal
grab the base of the agitator on equal sides, and pull very hard. try giving it a good yank to get it started. should pop right off. If you are replacing the agitator because of broken fins, when you go to put on the new agitator, don't force it. If it doesn't start to go back on fairly easy, try lifting it up just enough to rotate it slightly for it to line up on the coupling.
Mar 05, 2015 | GE Adora 3.9 cu. ft. Top Load Washer in...
GE adora side by side French door ice maker keeps freezing up and led light blinks. Have had repairman several times for same problem. Can I removed unit to thaw?
  • Possible solenoid fill valve failure
  • Possible failure of the mold heater, not allowing the ice to be removed from the mold.
  • Possible failure of the mold heater thermostat
Aug 30, 2014 | GE Adora (DSF25KGTBG) Side by Side...
I have a GE Adora front laod washer that I need help with. I have cleaned the pump filter, shop vac'ed the hoses, checked the hoses to make sure they are not clogged or pinched and I have hit a de
On the GE Adora machines, if the unit is not getting the correct power, the unit will not go beyond the fill point to wash. You will need to replace the "power inverter" on the unit. Here is the part you need to order.
Nov 01, 2012 | Washing Machines
Washer makes loud clanging noise when in use
Does it make noise all the time or just in agitate/spin mode?
Oct 13, 2012 | GE Adora 3.9 cu. ft. Top Load Washer in...
GE Adora JGBP87SEMSS Stainless Steel Kitchen Range too long to preheat
I need correct part numbers for GE Adora model JGBP87SEL2S LP to NG conversion
May 23, 2012 | GE Adora JGBP87SEMSS Stainless Steel...
GE Adora front load washer turns until water is added then won't turn or spin
You should contact GE or qualified appliance repair center to be looked at professionally.
May 06, 2012 | GE Wh12x10309 Heater for Adora Front Load...
Ge Adora dryer model#DHDVH52EFOWW started making a screeching noise in the middle of a cycle and does it again if I restart it.
remove door and check horse shoe shaped plastic guides located at the top of the door that the drum rides on for wear....replace if worn
Jan 03, 2011 | GE Adora DVM1850 Microwave Oven
How to convert oven from natural gas to propane on a ge adora gas range
i need the correct part numbers to convert a GE Adora model JGBP87SEL2SS from LP to NG,
Nov 02, 2010 | GE Adora JGBP87SEMSS Stainless Steel...
GE Adora QuietPower II Replacement Rack Wheels?
Model number is on a sticker on the left wall of the dishwasher, just behind the door, about mid tub level. Post your full model number and I'll list your part number(s) for you.
Sep 06, 2008 | GE Adora GHDA656LSS Stainless Steel...
Ge adora top load washer won't spin,
the water in my washer will not empty, and it keeps pausing its self.
Jun 03, 2008 | Washing Machines
Washing Machines Logo
49 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
