Question about Motorola Mobility DRC800 Universal Remote Control
Code for DVD Digitalcity HPD 5239M
The DRC800 user´s manual was not useful to search the above code.
Best
How to program ONN (code?) urc with Motorola sat box
If you want the Motorola remote to control the TV or another device, then you should be looking at the instructions for the Motorola satellite box. You'll find a list of codes in the back of the book for the TV brands it supports.
If the code for your particular TV or other device isn't listed then there's a way to use the remote to search its entire code base. This can sometimes provide the answer where a certain TV chassis is sold under several different brands.
The Motorola DRC800 universal remote instructions can be viewed here
Motorola DRC800 User Manual
Sep 21, 2014 | Televison & Video
Dynex code
Here is a link to motorola for the manual/spec sheet for you remote
http://www.motorola.com/staticfiles/Consumers/Products/Home%20Digital%20Video/DRC800/_Documents/Static%20Files/DRC800-User-Guide-US-EN.pdf
you should find the codes on this document or instructions on how to set it up manually
Feb 17, 2011 | Motorola Mobility DRC800 Universal Remote...
I have a Denon DVM3700 that need to control with MOTOROLA DRC800
These are the only codes I could find. If they don't work you might have to call their customer service.
20490, 20634
Hope that helps!
Apr 10, 2009 | Motorola Mobility DRC800 Universal Remote...
No code for Polaroid LCD TV
Code Polaroid 1250.
if it does not work try SEARCHING FOR CODES
If none of the codes listed under
“Device Codes”on the back of this
guide match your device, you can
search for a set of commands that will
work. Your remote will sample all the
codes in its system for that device
mode to find one that will allow you to
control your device. 1. Press and hold a device mode
key (AUDIO, DVD/VCR, or TV) for
at least six seconds. The LED for
each device key lights up, then
the key for the device you
selected remains on. 2. Press a function key (such as
Power or Mute). The following
function keys are valid for
Searching (Power is
recommended):
• Power
• Mute
• Play
• CH +
• Stop
The device key’s LED blinks
three times, then turns off. 3. Press (up) The remote will send
the IR command for the function
you pressed in Step 2. 4. If the device performed the
function you pressed, press OK.
The remote will now control the
device you selected in Step 1.
If the device did not perform the
function you pressed, repeat step
3. Press (down) to retry the previous
code. rmarti Colombia
Apr 05, 2008 | Motorola Mobility DRC800 Universal Remote...
Remote control code
Please tell me the remote you are using. Brand, mod # of remote, etc
Feb 26, 2008 | Televison & Video
Emmerson lcd tv,onkyo reciever,and toshiba hd dvd player codes
i can't play dvd's in my receiver, need some type of code to unlcock deck
Jan 08, 2008 | Motorola Mobility DRC800 Universal Remote...
Durabrand dvd code
hi go here for the complete usermanual, and try this following.
Searching (Power is
recommended):
• Power
• Mute
• Play
• CH +
• Stop
3. Press !. The remote will send
3. Press " to retry the previous code
I hope this helps
Please rate accordingly
Thank You
sserpentio
Dec 25, 2007 | Motorola Mobility DRC800 Universal Remote...
Motorola DRC800
Try this site -> http://www22.verizon.com/ResidentialHelp/FiOSTV/Remote+Controls/SetUp/QuestionsOne/84901.htm
Nov 16, 2007 | Motorola Mobility DRC800 Universal Remote...
Televison & Video Logo
Top Motorola Mobility Televison & Video Experts
Are you a Motorola Mobility Televison and Video Expert? Answer questions, earn points and help others
