Question about Troy Industries Battle Ax CQB Stock 71821 SBUT-SW1-00BT-00
Troy cqb buttstock removal - Troy Industries Battle Ax CQB Stock 71821 SBUT-SW1-00BT-00
Where is the serial number located on the gun model 70
Serial numbers are stamped on the gun's receiver, most often on the left side of rifles 7 shotguns. Some shotguns will have them on the top of the receiver where the buttstock mates to the receiver. Some lever action rifles will have them on the bottom of the receiver underneath the lever.
Dec 18, 2016 | The Optics
Any idea where I can obtain a replacement plastic buttstock?
Hi Wyman:
Sounds more like a firearm than a car or truck.
I was given a pellet rifle with a broken (plastic) stock and fabricated a custom one from bondo and aluminum mesh as was unable to purchase one.
My guess is that they really are not interested in selling parts, just in getting you to buy a complete replacement.
Jan 18, 2016 | Cars & Trucks
How to remove tire on Troy Bilt chipper shredder
there is either a clip or a cotter pin that needs removed , then slide the wheel off .
Nov 19, 2013 | Troy-BiltĀ® Briggs and Stratton Chipper
I have a conti cqb 250 s quad bike. where do i put the transmission oil
look where the chain go into the motor there should be a place where you should put your oil in
Mar 23, 2013 | Motorcycles
What do the terms 3x40 mean
The first number specifies the magnification. The second number is the size of the front lens. "3x40" means a three-power magnification with a front lens 40mm across.
The lens size is given because a larger lens collects more light and thus produces a brighter image. A 7x50 will be usable longer after sunset than a 7x35, for example, though neither should be considered as night-vision glasses.
Nov 13, 2012 | Leapers Accushot 3X40 Cqb Retical...
How do you disassemble a Winchester model 37?
rtest the buttstock on your thgih, hold on to the barrel tightly and then strike the side of the fore-end in a downward direction with the edge of your hand and it will unlock and come off. You have to rap it pretty hard to do this. Hope this helps you, Jeepfxr
Dec 12, 2009 | Tools & Hardware - Others
Do you guys make scopes?
A scope on a shotgun are you funny in the head? Its a Cqb weapon not a marksmens rifle. You wont find a scope for a shotgun ever.
Sep 15, 2008 | Crosman (4032)
Troy Industries Battle Ax CQB Stock 71821 SBUT-SW1-00BT-00 Logo
42 people viewed this question
Top Troy Industries Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Troy Industries Optic Expert? Answer questions, earn points and help others
