Question about Samsung SyncMaster 2220WM 22" LCD Monitor
I have my syncmaster 2220wm hooked up to my laptop. How can I get the monitor sound? It is only using the speakers on my laptop...??
  • Samsung Master
  • 1,684 Answers
Hello a 2250wm is actually a Viewsonic monitor not a Samsung monitor. To get the built in speakers to work you will need to connect the audio cable from your laptop to the monitor audio jack. This cable should have come with your monitor, it will have a headphone 3.5mm plug on both ends of the cable. If you do not have this cable yo will need to get one before you can make the speakers work right. Here is a link so you can get the cable if you need one.
http://www.ccl-la.com/catalog/product_info.php?cPath=83_86&products_id=176
Posted on Dec 07, 2012
Blu3Demon
  • 76 Answers
SOURCE: ghost images
Yes the images where left on the screen for a long period of time which burnt the images you see into the screen
Posted on Mar 10, 2009
budmrtn
  • 11361 Answers
SOURCE: Samsung Syncmaster 2220WM Smells and Does Not Stay On
I would leave it unplug, look inside first and report back what you see, post the pictyres will help, see where I post the pictures here: http://s807.photobucket.com/home/budm/allalbums
Posted on Jan 27, 2010
  • 732 Answers
SOURCE: The Samsung Syncmaster 2220WM I have started to
blueangel617, If unit covered by warranty, use it first! It's free! Your next option is a possible ??? cash+dead unit swap-out for a same model refurbished unit from Samsung, if they have a program like that??? It depends on the AGE of unit! If you are not planning on doing DIY repair to your unit, or contracting out the work to local technician your next option for you as a consumer/user will possibly be trade-in for new! But, if you buy a new unit, the sales guy might drop the 2220WM on the computer tech's bench in the back room and say to the technician "here's another one to look at! See if you can do anything with it." Well, with a little bit of luck, (50/50 chance) the tech will open and inspect your unit and evaluate the condition of unit's "switch-mode-power-supply" and "CCFL inverter supply" make a decision to repair or not to repair. If the tech see's the "classic" common LCD problem, he just might invest less than $10 in parts and end up with a working 2220WM to give to his kid to use for another 1 to 3 years. Blueangel617, you and only you will determine what to do about your "black" or "black and blank" screen CCFL back-lit LCD monitor. I just hope I haven't confused you as to what to do!!! If you can access my fixya profile and those of other lcd monitor fixya tech's and do some reading, you might find out more options that will be a better solution for your 2220WM. Good luck and best wishes. 12fixlouie north of Windy City.
Posted on Feb 11, 2010
mcdevito75
  • 1970 Answers
SOURCE: The monitor turns off after
mcdevito75 here, Have your monitor tested at Staples, Radio shack. Sounds like your monitor has had it.
Posted on Aug 10, 2010
budmrtn
  • 11361 Answers
SOURCE: My Samsung SyncMaster 2220WM monitor
Louie is correct, ti may be in safety shutdown mode, but you should also try it with another PC to make sure it is not the video card problem. If you are going to DIY repair, please read and look at he pictures.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 29, 2010
The monitor is hooked up to the computer, but when the computer starts up it is black with this small box in the left corner flashing analog or digital... how do I fix this?
Hi!
That can happen if the monitor is not getting a signal from the computer.
Try to unplug and replug both ends of the cable that's connecting the monitor and the tower.
If that doesn't fix it, check if the computer has a graphics card installed and you may have to re-seat it inside the computer.
Jan 03, 2011 | Samsung SyncMaster 2220WM 22" LCD Monitor
My Samsung syncmaster 2220WM will not stay on. It
The picture board on your monitor has been malfunctioning for quite the period but you did not notice it, since the screen goes blank, it means the picture board of your monitor has developed fault and will need to be replaced.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 25, 2010 | Samsung SyncMaster 2220WM 22" LCD Monitor
Feb 11, 2010 | Samsung SyncMaster 2220WM 22" LCD Monitor
Just hooked up computer and monitor and cant get any sound to play through moniter. do we need external speakers?
The Samsung SyncMaster 2233BW does not have built-in speakers, so yes, you need external speakers separately for sound.
Feb 06, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Jan 27, 2010 | Samsung SyncMaster 2220WM 22" LCD Monitor
How to hook up speakders?
The monitor does not have output sound since it is only an input device. You will have to hookup the speakers to your device (laptop, computer, gaming console) that you are connecting to the monitor. The speakers in the monitor are ready to receive a signal so that it can amplify it and let you hear it. If you hookup your speakers to the monitor it is the same as if you were trying to hookup two sets of speakers to each other.
Nov 04, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
My monitor is a SyncMaster 2220WM... the othe day
Your INVERTER has crapped out. Look on ebay.
Jun 26, 2009 | Computers & Internet
Samsung SyncMaster 2220WM 22" LCD Monitor Logo
175 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
