Question about RCA Audio Players & Recorders
Is there an adapter for the RCA CD player/
Mine uses an impossible number of batteries
  • RCA Master
  • 1,258 Answers
There is always a way to figure something out. Is there a plug to plug a unit in? The polarity and size of the plug should be determined and the voltage and current requirement. Then Go to Marlin P Jones and Associates and order the power adapter that would fit your needs.
In Radio Engineering people from the station would come to me with this question often, I always found them the answer and in a cost effective way.
Posted on Dec 11, 2012
  • sylvia watkins Dec 13, 2012
    yes it was helpful, thanks
How do I connect my Yamaha RX-V733 to a CD Player?
I don't see a RX-V733 on Yamaha's site. However, look for a stereo audio input on the receiver. Then use the appropriate audio cable or adapter for the CD player audio out.
Depending on the CD player, you should use either an RCA M/M to RCA M/M (red/white) audio cable or a 3.5 mm headphone to RCA stereo audio cable. (If you don't have a headphone to RCA stereo audio cable, you can use adapters on either side. Examples: 3.5 mm M to RCA F/F adapter to RCA audio cable as above or 3.5 mm M/M cable to 3.5 mm F to RCA M/M audio adapter, depending on which cable you want to use and where you connect the adapter.) After making this connection, turn on the CD player, select the appropriate input.
The connection for an external audio device (like a CD player) is shown on page 31 of the manual for the RX-V773. Even if this is a slightly different model, the image may help. The manual is available from Yamaha on the product page: http://au.yamaha.com/en/products/audio-visual/av-receivers-amps/rx-v773_g/?mode=model . Click on the Support tab. The direct link to the manual is http://download.yamaha.com/api/asset/file/?language=en&site=au.yamaha.com&asset_id=54075 .
I hope this helps.
Feb 21, 2017 | Yamaha Audio Players & Recorders
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
May 07, 2015 | RCA Televison & Video
6 AA Batteries generate how many amps
If this is a battery powered CD player,
we are talking mA not amps.....6 x 1.5volt batteries give you 9 volts
I would recommend something like this:-
http://www.ebay.co.uk/itm/New-AC-DC-Universal-Travel-Adapter-Input-110-220-Volt-7-Output-500mA-/251316939793?_trksid=p2054897.l4275 This will have more than enough power for the CD Player.
Feb 06, 2013 | Sharper Image Audio Players & Recorders
When input my 3.5mm jack to my audio input port on my face-place, my sound goes to my left side. However when i pull out very slightly on the jack, it goes to stereo, but i have to hold it there to keep it...
Try reversing the cable and see if one end fits better. Or buy a new cable. Also some aftermarket car cd players have RCA inputs on the back or cd changer inputs too, which can be changed to RCA input style connectors with an adapter. Then you will need a 3.5 mm to RCA adapter. You just need the RCA to 3.5mm adapter if you have RCA inputs on the back of your cd player. then run your 3.5mm wire from behind your dash to an accessible and convienent area. I ran mine into the glovebox in my car. My deck had RCA imputs so I just ran a long RCA cable into the glove box, put the 3.5mm RCA adapter on that, then hooked my iPod 3.5mm wire up to it. Now it's hidden and easy to store out of sight, plus with the extra long RCA cable to 3.5mm setup anyone in my car can have the iPod and change the songs. Hope that helps.
Sep 19, 2011 | Car Audio & Video
Where can I buy a RCA Cable and/or adapter for my Dual XD6210 so that I may have it installed in a 2001 Hyundai Elantra?
RCA cables like these can be brought from any electronic shop, no special rca cables are required ..
you do mean RCA right ?? this is what is looks like (below),, and can be brought from any electronic shop.its the same kind used to connect your dvd player to your tv. BTW these cables are only necessary when connection to an amplifier. other than that,, you have all ther wires you need on the unit, 2 power and 8 speaker wires. yellow is connected to the battery, red to the battery or ignition, black is the ground, and the pair colored wires are connected to the speakers. The unit ships with these wires so there is no need to buy them seperately. If you seek an adapter to convert the units electrical to your vehicles electrical you will not find it, It has to be connected via the wires. Simply clip the wires out of the old units adapter.
Mar 21, 2011 | Dual XD6210 CD Player
Alpine CDA 9827 using aux mode with ipod shuffle via rca inputs
Unfortunately, the rca outputs are to control an amplifier or crossover. They do make an ipod adapter for that radio, which allows you to control the ipod through the radio. Best Buy or any Alpine dealer should carry something for around $25.
Jul 05, 2009 | Alpine CDA-9827 CD Player
Want to know if I can use the line-level inputs from the CD Chgr
Your alpine unit is the old "M-BUS" the other adapter you are talking about is an "AI-BUS" adapter. (Hence the model numbers beginning with CD"M" or CD"A" ...)
Look for an Alpine M-Bus to RCA Input adapter.
heres one on eay for less than 10.00 including shipping.
http://cgi.ebay.com/For-Alpine-M-Bus-to-stereo-RCA-adapter-cord-cable-8-pin_W0QQitemZ310117370938QQihZ021QQcategoryZ60208QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Feb 09, 2009 | Alpine CDM-7857 CD Player
Battery compartment disconected by the AC adapter
That could be any number of things. Broken solder joint on the board where the battery terminals connect, dead batteries, and now that I think about it, if the connection is broken or loose in any way inside the hole where the ac adapter goes, it's not going to work with batteries. It needs that completed circuit regardless if there isn't an ac adapter inserted.
Jul 14, 2008 | GPX CDPW8806 Personal CD Player
M202e
I use mine in the car, but i run one of those tape player adapters to the headphone jack of the rca.
Apr 28, 2008 | RCA M2000 MP3 Player
Need new car adapter for RCA portable DVD player DRC630N
mine broke when it was new. i opened the cig lighter end and found broken wire. soldered it on and taped up the missing chunk of plastic. worked ever since.
Jan 14, 2008 | RCA DRC629N Portable DVD Player
46 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
