The power light is on on my monitor, but i cant see any images
  • l_gnau Jan 12, 2009
    i have disconnected and reconnected all connections. still no images. different monitor works. could it be connector cable?
    Scholar:
  • 170 Answers
Its possible that your monitor is plugged into the power outlet but not connected to the back of the computer.
Hope this helps, and don't forget to rate my answer.
Posted on Jan 12, 2009
  • Stephen Jan 12, 2009
    Its possible that the cable is no good, but I suspect your montior is no good if another works.
    Monitors are a dime a dozen these days. Count your losses and move forward.
    You could take it apart and look inside for anything susipcious. Monitors are not worth the time and effort to repair these days. You can pick up a second hand monitor probally for $20.00
    Let me know if this helps, and please rate my answer.
    Good luck.
Samsung syncmaster 2220 blinking blue light and no image display
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Samsung SyncMaster 2220WM 22" LCD Monitor
Cant display images just blinking
is the power light good.
is the OSD working?
Sep 27, 2013 | LG FLATRON L1950B-SF 19" LCD Monitor
Monitor green light is on but no image what's the problem?
Pretty good bet that your monitor power supply has bad caps. There are about 6-10 caps that age and "bulge". The fix is simple. Google it. Total cost to fix (if you know how to solder) is probably less than $2.00.
Jun 09, 2012 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor power light is blinking and no image is displayed.
The problem is in the power supply board, there are one or more capacitors that open, causing the power to stop. Sometimes they will bulge at the top making it easier to spot.
Apr 17, 2012 | Samsung Computers & Internet
Monitor comes on and goes right to a black screen like the power was turned off but the power light is still green.
hi,
You have to check the back light of your lcd monitor. All lcd screen have a back light to illuminate the pixels. you can conform is the back light is faulty or not by watching the lcd screen nearby. Watch can you see any image (negative image) on the screen. you have to look very closely. if you see any image on the screen then the back light or the back light inverter is faulty.
You have to check the back light inverter board. Normally in lcd monitors you can see three circuit boards. power supply, mother board, and the inverter board. If available then try to replace the inverter board. There are high voltage transformers in this board. There is a chance for its winding get short. You will not get the transformer in open market. Try for the inverter board .
ok
May 06, 2011 | LG Flatron L1511SK (Black) 15 in. Flat...
My LG monitor blacks out intermittently when warm, I have tried it on another computer so it is a fault with the monitor. It blacks out every few seconds, sometimes it takes longer. It is 2 years old.
after blackout, check the screen as that. look in to the monitor in side angel,
and if you can see darken live image in that and its working. in that condition, your
LCD panel is working and the problem is no light.
in that case you need to repleace or repair the " inverter unit " in that monitor.
that unit makes the high voltage for back light.
after blackout , you cant see any darken image like as that, and or totally power
goes off , that is different problem. for solve that need advance trouble shooting
and can be need advance repair.
Jan 03, 2011 | LG Flatron W2243SPF Widescreen LCD Monitor
The screen shows image for like 3 seconds then goes black but the screen is still on
-you can check the cables on the monitor have it disconnected and reconnected
-if it still does it try another monitor cable
-one way you can check is to use a flash light by shining it on the screen and look closely to see if you can see any images .
-try touching the menu screen on remote to see if you can see image, if you can then the lcd screen is bad and would need to be replaced. the same would be if you cant see any image =
Nov 22, 2010 | Gateway FPD1975W 19" LCD Monitor
My sdm-hs73 moniter the power is on but screen is blank, what could be wrong
First check brightness and contrast settings.
If all good could either be your lcd back light has gone or the inverter. To check if its the black light shine a torch through the back of the screen to see if you can see a slight image on it, if you cant see anything the inverter board is faulty and to repair needs to be changed.
Jan 21, 2010 | Sony SDM-HS73P 17" LCD Monitor
Multisync lcd1760nx This monitor powers up and works fine as far as I can tell. I set my notebook screen to show on this monitor as a clone screen(same image as my notebook screen). I cant see the image on...
Hi frnd.. there is a test known as Monitor self test to perform this just power on the monitor and unplug the flex cable.. U will see a logo bouncing up and down.. if this happens then it means the monitor is fine...
Sep 29, 2009 | NEC MultiSync 1760NX 17" LCD Monitor
VA1930WM monitor turns on, displays normal for one second then goes black. Then it turns on again after a minute or so for one second and goes black. This keeps repeating over and over. Is there a known...
If it was the power supply, the light would change to amber (orange) and then turn green again when it comes back on. Look closely at the screen when the it looks to turn off. See if you can still see an image. It may be hard to see, but when the backlights go bad or fail, the actual lcd screen itself still functions and you can see a very faint image. Maybe moving the mouse in circles might help you to be ablt to see. If you cant see anything at all, then it may be a bad board inside the unit.
Just a thought....
Sep 18, 2009 | Computers & Internet
Computers & Internet Logo
19 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
