Question about ProofPronto Smarty BX1500 HD Dashcam w/GPS
Smarty bx1500 software
Need to download the software
One drive wheel does not turn. If you pull the release lever,it still does not turn.
There are TWO release levers on the Smartie. (Link to specs and manual below) Please make sure you are engaging both levers. If you find both levers and are still having issues it is likely that you have a broken or frozen (rusted/oxidized/clogged) brake disk. This issue is common to all power chairs and scooters in high humidity areas.
A frozen brake disk require disassemble of the brake on the end of the motor, cleaning with super fine sand paper or an emery cloth and then careful alignment and re-assembly. This is a pain and requires skill and patients.
THe issue may also be a bad motor or gearbox. If the motor or gearbox will not turn once the brake has been removed then it is a bad motor/gearbox.
Many dealers will not invest the time to replace or fix the brake and will opt for replacing the motor/brake assembly as it is a sure fix and not time intensive. Shoprider Smartie Power Chairs
Feb 27, 2014 | Shoprider Smartie Power Wheelchair ()
Apc 2000 series even without load is going on overloadinverter
Hi Grant,
May be an inverter issue, it's a common issue for UPS's that are 7 years or older.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Jul 27, 2013 | APC 1500VA BX1500 8 Outlet UPS UPS System
BX1500 APC not charging batterylight blinking
You should check if the battery is connected the way it should or do a health check on your battery. Most likely the battery is disconnected or has reached the end of its life.
Regards,
Ron
Feb 17, 2013 | MGE Galaxy 3000 UPS System
Our BX1500 cycles between "On Battery" and "On
This sounds like a battery issue, test the battery by itself....
Apr 02, 2011 | APC APS BackUPS CS 650VA 400W 230V DB9...
I need a serial number for Studyworks! Mathematics.
i suggest to buy a legit copy and use the serial that comes with that
Oct 19, 2009 | Mathsoft StudyWorks! Mathematics Deluxe...
ProofPronto Smarty BX1500 HD Dashcam w/GPS Logo
32 people viewed this question
Top ProofPronto Video Cameras Experts
Are you a ProofPronto Video Camera Expert? Answer questions, earn points and help others
