Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
Frigidaire dishwasher fdb 750 stops during cycle
  • Official Brand Answer
  • 4,342 Answers
Hello - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may also prevent the unit to start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Posted on Dec 05, 2012
5 Suggested Answers
SOURCE: Hi, my Frigidaire dishwasher doesn't seem to clean
Factory Defect, where I was given full refund plus re-installation costs from Lowes...
Posted on Oct 17, 2009
  • 1382 Answers
SOURCE: frigidaire dishwasher does not complete cycle
Power from the house
Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch
The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring
Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch
Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Posted on Mar 22, 2010
SOURCE: I have a Frigidaire GLD3450RDS0
DISHWASHER GLD3450RD GIVE ME A FAULT CODE DE
Posted on Dec 07, 2010
SOURCE: loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Posted on Apr 16, 2011
Leaking in frigidaire model FDB 121RFR4
It sounds like the atmospheric switches stuff. You will have to pull the top off of the washer to get to it it's on the right side or the left side of the drum. As the water fills up the tub it pushes air up a tube to a switch that stops the water from flowing once the tub is full. It's not a hard thing to fix you just have to pull a few parts to get to it. It may have just stuck and needs cleaning. If not, the actual switch may be bad.
Nov 20, 2017 | Frigidaire Washing Machines
Fixing a Frigidaire Dishwasher (FMB33ORGCO)
Hello Paulus!
From what you have described your Frigidaire dishwasher is will not start and you have performed a reset. This could be a possible issue within your control panel or wiring harness. Since it could be an issue within the electric components I would suggest you speak with a professional technician, they would have the appropriate tools needed for proper disassembly of your dishwasher. Hopefully this is helpful. -Matt
Nov 29, 2015 | Frigidaire 18 Inch Dishwasher White ,...
Cycle time remaining isnt displayed on Frigidaire Professional dishwasher
From my research, this unit is not designed to show it while in use only if stopped during a cycle or if a problem persists within the unit to cause a pause or error code to display.
Dec 22, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire dishwasher model # FPHD2491KF
It seems like you are experiencing a faulty door latch and control board communication. This would need to be diagnosed by a technician and the correct part(s) replaced.
Aug 29, 2012 | Frigidaire FPHD2491KF Dishwasher
Dishwasher motor sounds like its struggeling to run. oR LIKE it's bogging down during washing cycles any and all cycles. there is water going into the washer but when washing it sounds like there is no...
Try pouring water from the front. The pump has got air traps inside. This will ease your problem.
Also check whether the spray arm turns freely without any obstacles.
Mar 30, 2010 | Frigidaire 24 in. FDB510LC Free-standing...
Loud squealing noise during wash and rinse cycle
Nov 24, 2009 | Frigidaire Dishwashers
Causes interference with radio, tv
You could possibly add a metal shield around the electronics in the dishwasher and ground the shield with a wire to the dishwasher chasis. Don't know if this would reduce the EMR enough to stop the interference with the radio, but there's a chance it would.
Apr 14, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Can't find the model number on Frigidaire dishwasher
The nomenclature should be located on the left side on the inside of the tub right by the front when you open the door. It is most likely an fdb series example fdb1050. however the drain hose pn 154606701 is the factory replacement for most frigidaire dishwashers ten years or less.
Mar 31, 2009 | Frigidaire Professional Series 24 in....
Frididaire dishwasher HO on display screen
If it is coming on during the cycle it means the dishwasher is heating the water. If it is after the cycle or the cyle is stopped it means it did not reach the proper heat temperature. As long as it is running through the whole cycle it is ok.
Jun 13, 2008 | Frigidaire Dishwashers
Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
136 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
