Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
Frigidaire dishwasher fdb 750 timer sticks - Frigidaire 24 in. FDB510LC Free-standing Dishwasher
2 Suggested Answers
futureloginn
  • 734 Answers
SOURCE: Frigidaire Dishwasher won't start
hi there,
as u said that u have already replaced the timer u may also try the following:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Posted on Dec 10, 2008
Wash cycle knob
It's a quirk of the cycle timer. You can replace the timer ($) or live with it. Besides, a replacement might have the same quirk
Jul 15, 2013 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire dishwasher fdb 750 stops during cycle
Hello - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may also prevent the unit to start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Dec 05, 2012 | Frigidaire 24 in. FDB510LC Free-standing...
STICKS on cycle, wash, etc. If manually moved
Do you mean the timer or control dial sticks. If so then it may be the timer mechanism itself.
Make sure that when you are skipping a turn on the timer that the machine is actually performing that particular task of the cycle. For example if the timer gets stuck before the drain cycle, and you manually skip forward to it, that it actually drains the water out.
If so then it is most likely a worn timer mechanism which sticks.
Ash
Oct 23, 2009 | Frigidaire Dishwashers
Dial sticks in two places until dial is moved slightly
HI. this Timer mechanism will need ot be replaced soon. the timer motor is defective. this will continue to affect the performance of this unit. replace asap.
Jun 20, 2009 | Frigidaire 24 in. FDB750RCC Stainless...
Causes interference with radio, tv
You could possibly add a metal shield around the electronics in the dishwasher and ground the shield with a wire to the dishwasher chasis. Don't know if this would reduce the EMR enough to stop the interference with the radio, but there's a chance it would.
Apr 14, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Can't find the model number on Frigidaire dishwasher
The nomenclature should be located on the left side on the inside of the tub right by the front when you open the door. It is most likely an fdb series example fdb1050. however the drain hose pn 154606701 is the factory replacement for most frigidaire dishwashers ten years or less.
Mar 31, 2009 | Frigidaire Professional Series 24 in....
Frididaire FDBs956cc0 sticks on wash and makes a loud click
Hello melissia_gre
Welcome.
Your timer is faulty.
time for service to replace it and all will be well again.
Please remember to leave a solved rating
Thank You Huum
Dec 19, 2008 | Frigidaire 24 in. FDBS956CC Stainless...
Frigidaire FDB710LCS0 Dishwasher dial seems to stick?
I had the same problem. Turn the HIGH TEMP buttons off. Simply turning them off corrected this problem for me. Mine got stuck in two places and I had to manually turn the dials or the washer would run all night.
Nov 21, 2008 | Dishwashers
Frigidaire dishwasher dirty & sticks in cycle
First, check the holes on the upper spray arm. They should be clear of food and debris.
Next, There's a check valve (ball) built into the motor unit. Either it's stuck, or the motor isn't pausing at the appropriate time to switch from bottom spray to top spray. You can test the check valve by opening the door momentarily while it's running. The spray noise inside should sound distinctly different. Pausing longer will switch back to the lower spray arm.
If the check valve works, you'll need a new timer.
Mar 10, 2008 | Dishwashers
Frigidaire p/n 154457601
could be a heater, or a bad thermosta stalling your timer, check heater for continuity
Feb 10, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
41 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
