Question about LG LFC23760 Bottom Freezer Commercial French Door Refrigerator
THIS REFRIGERATOR IS TOTALLY DEFROSTED HAS BEEN SITTING IN STORAGE. I PLUGGED IT IN AND THE COMPRESSOR KICKS ON, HOWEVER THE FANS DOES NOT MOVE. THERE IS NO AIR FROM EITHER THE FRESH FOOD OR FREEZER COMPARTMENTS. I RAN TEST 1 FROM THE MAIN PCB AND EVERYTHING WORKS FINE WITH EXCEPTION OF THE #2 LED FOR THE FRESH FOOD TEMPERATURE CONTROL IS NOT ILLUMINATED. WHEN IN NORMAL MODE NO FANS I REPLACE THE $188 MAIN PCB AND STILL NO FANS. CAN YOU HELP?
    Problem Solver:
  • 7 Answers
Sounds like you ay have forgot to plug one of the wire harness on to the PCB? Did you check for voltage at the evap fan motor
Appliance Repair
Posted on Dec 05, 2012
5 Suggested Answers
  • 306 Answers
SOURCE: Appears to be stuck in auto defrost mode
Your relay that is attached to the compressor is going bad. It is called a PTC relay. The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on Jan 24, 2009
rylee_smith
  • 8619 Answers
SOURCE: Freezer working but less cool in refrigerator
Hi
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt. Check for these: Evaporator coils You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Please revert for further assistance and Do rate this solution as "FixYa" if found useful.
Thanks
Rylee
Posted on Mar 16, 2009
SOURCE: Fresh food compartment not cooling. Freezer seems to be working
Evaporator coils iced up- either bad bi-metal thermostat,heater or board.Check resistance on thermostat/heating element.If reading resistance try and jump board into defrost mode by jumper wire from l-1 to defrost lead.
Posted on Sep 16, 2009
  • 330 Answers
SOURCE: freezer keeps defrosting up, thought
There is whats called a defrost termination sensor in behind the back panel of the freezer it has failed & needs to be replaced.Very common problem in electronic fridge's.
Posted on Feb 22, 2011
Model# 253.61821014 compressor keeps kicking off
Feel the top of the compressor is it hot? Usually when a compressor will start and stop this is called short cycling and it is caused by a defective start relay, overload and capacitor. Sometimes it it cause by a defective fan which when this happens all parts including a new fan must be replaced
241941004 Start Relay
218909913 Run Capacitor and a
242018301 Condenser Fan Motor
APPLIANCE911
It is not stuck in defrost mode with those symptoms
Apr 30, 2016 | Kenmore Refrigerators
Refrigerator not cooling.
No the evaporator fan not running has nothing to do with the compressor. I would suspect that you are freezing up over the evaporator because the fan is not running and when it ices up the air can not flow through properly therefore causing the refrigerator side to get warmer. Replace the fan and you should be fine. Take the back panel inside the freezer off and see if you are all iced up. If you bare then I would replace the fan . You also said the defrost heater did not come on. That will also cause a freeze up. Possible replacement of the defrost heater may be needed. Good Luck!
Jul 25, 2015 | Amana Refrigerators
I just moved the fridge to a new house and now the fridge and freezer won't get cold. It had been sitting in storage for over about a year, but worked perfectly before that.
Its possible that during storage a few things may have happened. There is a small fan under the back that keeps the compressor cool while running. Its possible that during moving something shifted or bent the fan area and its not running. Could also be a small critter built a nest in that same area stopping the fan from running. Without that fan--- the compressor will run a very short time and then cycle itself off on the heat safety when it gets too hot. It will keep short cycling off the heat overload until the fan runs again. It will not run long enough to get to proper temp. Just guessing but check this first.
Jun 18, 2015 | GE Profile PFSS6PKX Bottom Freezer French...
Maytag Refrigerator/freezer alarm will not turn off.
check that tha fan beside the compressor in lower back is running and that condenser tubing is lint free, also check for icing on frezer back panel if so you could have a defrost problem, if all is good you may have a freon leak inside the frig walls as tubing is all metal and will rust when sitting for a long time in storage due to moisture build up from been warm outside and cool inside during normal usage in which case you may need to change the appliance at that point you will need a service call to find if there's still freon inside your frig and of coarse your control may not read the properly..
Jan 25, 2015 | Maytag Refrigerators
Amana refrigerator SQD23VW
If the freezer is not freezing. I am guessing that the refrigerator is not cold also. Here is link to an Amana Refrigerator Not Freezing. You will need to narrow down parts that are working and are not working. I would first pull the refrigerator out to make sure that the compressor and the condenser fan are running(the condencer fan motor runs to cool the compressor down). This is a link to a GE refrigerator condenser fan motor problem. The compressor and condenser fan motor are in the same place. This can give an idea at least where it is at. Make sure that the evaporator fan motor in the freezer is running also. Make sure that the rear freezer wall is not iced over. This can be a defrost problem. See what a defrost problem is HERE. If your unit is sitting there with the lights on but you hear no noise from any fan motor or your compressor. Your unit may be in a defrost mode. Locate your defrost timer. It looks as tho it is either located in the front behind the kick plate or in the back by the compressor. Here is a link to your units diagrams http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VW-P1315302WW/1268/0165000/P9060266/00011?componentDescription=&brandDescription=&searchTerm= or http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VWP1315302WW/1268/0165000?searchedModel=sqd23vw&blt=11 . Hope this helps a little. This is my Appliance repair Contact. You can get a hold of me at http://www.apcoapplianceandair.com/contact.php anytime.
Apr 09, 2013 | Amana Refrigerators
Moved refrig. and compressor will not kick in
The unit may have gone into the defrost cycle. The fans and compressor will be off during the defrost cycle. Has the unit been plugged in for more than 30 minutes since you noticed it stopped? If so, you will see a round plastic knob recessed about 8" back in the console on the fresh food ceiling. Rotate this knob clockwise with a flat blade screw driver until a distintive click, louder than the tiny clicks made while rotating the knob. If the fans and compressor come on, replace the timer (68233-3).
If the fans and compressor do not come on after rotating the timer, you may have a bad cold control of loose wire in one of the molex connectors from the move.
Apr 29, 2009 | Refrigerators
I have a GE side by side.. When we got home last night I noticed some water on the the floor and the power was on inside the refrigerator but the cooling apparently stopped working. I moved the fridge and...
The defrost timer will turn off the compressor and its cooling fan. At the same time it turns on the defrost heater, and usually leaves the freezer fan running. Defrost can take half an hour, easy. As soon as the defrost thermostat is satisfied, the defrost heater is supposed to turn off, and the compressor may come back on. The defrost timer is about the size of a cell phone, with about five wires going to it in a plug. It has a small dial on it that only goes one way. You can mark it and wait a half hour to see if it moves.
Apr 14, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hotpoint FFA70 Freezer High Temp
sum fans only kick on if cold enough
if the whole evap is frosted up u have a defrost problem
if frost is only partial u need to throw it out cause it either has a bad compressor or freon leak
check your fan by compressor and make sure coil isnt filthy too
Jul 08, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerator not cooling at all but compressor is running
They'd at least be cool to the touch regardless i think. This seems dead, I had one that would clink alot. Try unplugging it, moving it away from the walla a bit and plugging it in with the freezer all the way to a 0 setting then work it up to full slowly hope this helps!
Jul 26, 2007 | Magic Chef CTB1722 Top Freezer...
LG LFC23760 Bottom Freezer Commercial French Door Refrigerator Logo
142 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
