Question about Sceptre X7G-Naga 17" LCD Monitor
Sceptre 17" Naga monitor
My computer monitor usually has a solid light, now the light is blinking and the monitor is not working at all. Did it go to sleep, is there a reset button?
  • darlene carelli Jun 09, 2007
    we tried that first, the hard drive works when hooked up to a different monitor. I should have specified that, any other options?
  • Anonymous Apr 01, 2009
    I have a problem with my monitor. Black screen the power light FLASHES between red and blue
  • 883 Answers
Try another monitor on your pc. I suspect bad video source.
Posted on Jun 09, 2007
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
Aug 25, 2011 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
X7 G-NAGA VI POWER SUPPLY Transistors
do an advanced search on ebay for seller techtronsaver he should be able to supply you with the parts you need
Jun 04, 2010 | Sceptre 17" LCD Monitor
Sceptre x24 has suddenly stopped working. Monitor
if you are using integrated video, your integrated video is fried, done gone. if you have a pci or pcie or vga video card, its gone or blown or dead as a doornail. replace the video card and youll be up and running again
Jun 04, 2010 | Sceptre X24WG-NAGA Monitor
I have a sceptre x20g naga III screen goes blank
if you have the warranty, return it and get a new one free. ok
Feb 19, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
My Scepter LCD Monitor just blinks when it's turned on
Open it up and the first place to look will be the power supply section, look for bad caps with bulging top/bottomseal, post back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 12, 2010 | Sceptre X7G-Agama II (Black) 17 in. Flat...
Spectre x7, at startup, screen blinks on and off. blue light at bottom also goes on and off
leos343872, Black screen type of failure. Is anything still displayed even though screen is black when you hold flashlight 1 inch from lower left corner near start button??? Possible "switch-mode-power-supply" in shutdown mode. Tech or you will need to evaluate further!! Read more of my advice to other owners with BLACK screen monitor problems in my profile. or louie12fix profile. 12fixlouie
Dec 14, 2009 | Sceptre X7G-Naga 17" LCD Monitor
I have a sceptre x9g-naga III
Not an expert, but from what Ive read, this is a cfl inverter issue. I had the same problem on my Sceptre. Good luck finding parts. My solution: get another monitor.
Feb 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
17 inch flat screen monitor has trouble turning on
Make sure that the PC video output is set at 60 Hz. The LCD often will accept up to 75Hz but will not work correctly.
May 04, 2008 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Sceptre monitor x7g-nagaVI
Problem is 2 Capacitors on the power inverter board, at 1000 uf 16 volt. This one was on the model xg7-naga V 17 inch monitor.
Jan 14, 2008 | Sceptre 17" LCD Monitor
Sceptre X7G-Naga 17" LCD Monitor Logo
363 people viewed this question
Top Sceptre Computers & Internet Experts
Ben Slimene Aymen
Ben Slimene Aymen
Arnie Burke
Arnie Burke
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
