Question about Kenmore Sewing Machines
Model no 117-959 kenmore sewing machine
Serial no. 506696 how old is the sewing machine that i have?
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: Kenmore 10 Sewing Machine
kenmore sewing machines relics
Posted on Jul 13, 2008
SOURCE: Kenmore Sewing Machine model # c877.15
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
Posted on Aug 09, 2007
SOURCE: Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Posted on Sep 17, 2008
clyde2j2
  • 137 Answers
SOURCE: replace belt kenmore sewing machine
Try this URL:
www.sewingmanuals.net
Posted on Mar 02, 2009
Manual for kenmore 38516221301 sewing machine
Sears carries manuals for most of their machines.
Jun 22, 2017 | Kenmore Sewing Machines
It's model no#158.10401.It just needs some care but would like a manual
If you scroll down the page, you will find a manual at this web site:
http://www.kenmoresewingmanuals.com/kenmore_158_manuals/kenmore_158_manuals.htm
Or, you might want to contact this company. They say that they have a lot of sewing machine manuals available:
http://www.sewingpartsonline.com/kenmore-158-10401-sewing-machine-parts.aspx
Here is some information about your Kenmore sewing machine model. It's probably a very nice basic machine and if properly maintained will last many more years.
https://stitchnerd.wordpress.com/2011/06/16/sears-kenmore-158-10401-model-1040-sewing-machine-a-review/
Jun 01, 2015 | Sewing Machines
How old is my sears Kenmore sensor sew 70 model# 3851950180? Iwould like to know if it can be repaired
Almost any machine CAN be repaired, but it may not be worth the money to get it repaired and with older machines finding parts can be a real problem.
If you call Sears and tell them the model and serial number they should be able to tell you the age of the machine, and whether or not they are still willing to repair a machine like it. They may not have parts though.. sometimes independent repair shops are a better bet. Ebay is often a good source for old machine parts too.
Nov 18, 2014 | Kenmore Sewing Machines
My Kenmore sewing machine is old and still works, recently the take up lever broke. Can it be fixed ? Model 158.1753 serial 0020858
Call a dealer and ask them. i would think they can fix anything, if they find the part. it may be time to get a different machine. Kenmores are often found are garage sales, etc, you could buy another just like yours, and keep the other for parts.
Sep 13, 2010 | Kenmore Sewing Machines
Availability of needles
Practically every machine made in the last 50 years uses a 15x1 needle also known as 130/705 universal fit.
sewman7
Jul 11, 2008 | Kenmore Sewing Machines
i have a kenmore10 model 1249180 ehwn i sew it squeeks i oil it i dont know where the squeek is coming from
Dec 05, 2007 | Kenmore 744-08BH Mechanical Sewing Machine
Sewing Machines Logo
268 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
