make sure your firewall settings are disabled or changed to allow messenger...........then click on <messenger> before sign in then click on <connections and preferences> there you have to mark an option <use no proxy> and thats all........if dont work then remove that messenger through control panel and add/remove programs and download through the add below.
The best attempt to unlock your ID is, try
to login not by yahoo messenger, but by mail of yahoo which has a same
user name and password that been locked. Sometime, this step worked,
but make sure after your login to yahoo mail and success, you have to
change your password with new password, and then you can login to yahoo
messenger with new password that you just been created.
If you
try to send a complain to the contact of yahoo messenger, It will
useless. Yahoo doesn’t care what happen to your if you go locked.
To
protect your ID or to prevent Lock ID, you must have a strong password.
I will suggest you to not chat with your primary email in yahoo
messenger. Sometime yahoo makes a prohibition to some of ID. This mean
your ID can be banned by yahoo and your ID never be join to yahoo
messenger or yahoo email again.
To create a strong password you
must use all character who listed in your keyboard. Such as uppercase,
number, and symbol. You must be create password which have not less 8
character or more.
Here I give you an example a strong password: H4rP3
^&* (with 3 space on it). To make a better password work well, you
have to change your password frequently: 3 week or 3 month, depending
how strong and important your password i
This is because your internet connection is not constant.. Check your internet connections... If that doesnt solve...Select..PROXY in yahoo messenger settings.. This should help you..
Offhand, a couple of possibilities you can try to explore, check or perform:
clean your cache and temporary internet files;
re-install Yahoo Messenger;
verify your account by checking your Yahoo email.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
