Question about Watches
I put a battery in a seiko 8f33, the time and day are working fine.The date will not work. I have been thru the process of reprogramming. What have I done wrong???
  • 25 Answers
Your watch has a perpetual calendar which can only be set from inside the watch using the touchpads around the edge of the movement.
This link is for the instructions
http://www.seikousa.com/support/ib/pdf/SEIKO_4F32_8F32_8F33.pdf
Posted on Dec 06, 2012
5 Suggested Answers
escapement
  • 2334 Answers
SOURCE: Resetting a SEIKO watch
You may can find instructions here:
http://www.seikousa.com/#FAQ
Go through the watches till you find the match.
Rate me, please.
Posted on Mar 14, 2009
  • 122 Answers
SOURCE: My whatch Seiko 8F33 finished the battery
try to clean very well the contacts of the battery.
Posted on Mar 15, 2010
  • 101 Answers
SOURCE: Hi, I am a seiko
If your watch stopped working while changing the time it can be for a couple of reason . One is i never set the watch between the hours of 11 pm and 4 am or else your movement can be damaged. The main reason is usually that the watch crown was not pushed all the way in to the first set . If the watch crown and stem is pulled out and not in the start position the watch will not run. Also after setting time you might need to reengage the watch by pressing on the jumper buttons on the top side of the crown they look like push buttons.
Posted on Oct 18, 2010
  • 125 Answers
SOURCE: The date on my Seiko
Welcome to Fixya. Can you please provide the caliber number of your Seiko SWZ054 Wrist Watch for me to be able to check the manual and give you the information on how you can update the day on it?
Thank you for using Fixya,
seancarlisle
Posted on May 13, 2011
I'm trying to find a battery to a Seiko watch, serial # 152635. The case # 8f33-0010.
Take it to a jeweller, $6 to $8 and takes 10 minutes. Most have a screw back. They have the batteries, the tools and the know how.
Jan 05, 2017 | Seiko Watches
How to set day/date on an 1968 DX automatic Seiko watch
Seiko watches from this period should have a setting stem that pull out half-way and fully. Pulling the stem out fully permits you to set the time. Pulling the stem out half-way should let you set the date by moving the crown forward/clockwise and set the day of the week by moving the crown backward/counterclockwise.
However, for this to work correctly, the watch must have the correct set stem. I have worked with a number of watches, including Seikos, where a generic stem was substituted after someone accidentally pulled out the crown and stem (Seiko replacement parts can be tough to find in the U.S., especially for discontinued models). If an incorrect stem has been installed, the day/date setting procedure I've just described may no longer work correctly. At that point, setting the date involves advancing the hands to get to the right date; day of the week may not be able to be set at all.
Mar 09, 2012 | Watches
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
  • THE CROWN
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
  • 12 O'CLOCK POSITION
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
  • FINISH
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
Dec 18, 2010 | Seiko SNA304 Wrist Watch
Hi, I am a seiko 8f33 perpetual calendar watch. I just got it back from Seiko...had the battery changed and new band. the problem is that I tried to set the date and the watch stopped working. Does...
Oct 17, 2010 | Seiko SKA192 Wrist Watch
I have a Seiko Premier Kinetic Watch SNP005. The problem is that the date is supposed to change around midnight. Now the date changes around 9-10 in the morning. I have read the manual and the only...
Thank you for contacting FixYa.<br /> You will have to contact Seiko on this one. I would tell you to just change the date to the day before and then forward the time, but I think I would just contact them as it is such a delicate timepiece.<br /> <a href="http://www.seikowatches.com/technology/kinetic/index.html">http://www.seikowatches.com/technology/kinetic/index.html</a><br /> Best regards.
Aug 25, 2010 | Seiko Premier Kinetic® Perpetual Watch for...
Pulsar watch, how do you set the day of the week and month?
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
Jul 08, 2010 | Seiko Watches
Setting time/date on old Seiko
With our 10 year old grandson's help, my husband was able to figure it out. Took a while, but he is now wearing his watch again!
Thanks for the follow-up.
Feb 08, 2009 | Seiko Watches
Setting Date. Seiko SGF204 (w/ 7N43 Band) French & English Days.
If you pull out the stem 1/2 way, you set the date one direction, and the day the other. If you pull it out all the way, it moves the hands and sets the time.
Dec 01, 2008 | Seiko SGF204 Wrist Watch
Here is the manual for your watch.
Hope this helps
http://www.seikowatches.com/support/ib/pdf/SEIKO_4F32_8F32_8F33.pdf
Jul 12, 2007 | Seiko SKA192 Wrist Watch
Watches Logo
141 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
