Question about Nordic Track NordicTrack Elite XT Treadmill
Remove front roller nordic track elite xt
Remove front roller
  • 16 Answers
SOURCE: Need to put together a Nordic Track Elite 2900 treadmill.
Type into the serch, icon health and fitness, then click on the customer service, then click onto the manuals and the instructions should be in the owners manual.
Good luck.
Posted on Jun 29, 2009
  • 40 Answers
SOURCE: My Nordic Track Elite XT's belt will not start.
most likely the little plastic cover on one of the motor brushes popped off.
it's curved, but rectangular in shape and about the size of a quarter.
Posted on Nov 01, 2009
maxtreadmill
  • 832 Answers
SOURCE: what do the distance numbers represent on the
If no distance goal was set, this display will show the distance that you have pedaled, in total revolutions. If a distance goal was set, the display will show the distance still to be pedaled during your workout.
Posted on May 10, 2010
maxtreadmill
  • 832 Answers
SOURCE: manual for a Nordic Track Personal Performance
Go to iconservice.com click on to manual Input manufacturer : Nordic Track then model # NTL349050 and you manual await you.
Posted on May 15, 2010
maxtreadmill
  • 832 Answers
SOURCE: My nordic track treadmill's walking belt stops
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
Posted on May 18, 2010
How do i remove the weights to facilitate moving the treadmill?
see the video attached. and proceed according.
God bless you
Sep 27, 2013 | Nordic Track NordicTrack ELITE XT...
Belt off center on front roller
see the video and proceed according. God bless you
Jul 19, 2013 | Nordic Track NordicTrack A2750 PRO...
When running on our treadmill the belt slips.
Hello, It sounds like you have aslipping front roller pully. Remove the motor hood and watch the front roller while you are on it. Once the belt is moving slowly, try to stop the wlak belt by planting your fett for a second, if the walk belt stops, but the drive belt and motor continue to run, the plastic pully is slipping and the whole front roller will need to be replaced.
Hope this answers your question.
Jan 16, 2011 | Nordic Track NordicTrack A2750 PRO...
Replacing the drive belt Nordictrack 2900
basically you will be just about to take your treadmill, almost totally apart. But the are not many nuts and bolts to solving your problem, first Lay treadmill on its side and locate the rear roller bolts, on mine their are 2, most tread mills are all the same, remove them 2 bolts, Now locate the front roller bolt, 1 bolt,remove bolt, your belt is going to be very loose now, on the side that you would be walking on, Is a board, 6 phillips head screws, Hold the board to the metal frame, remove them, remove the board, then go back to the rear roller, And remove the plastic end caps that hold the rear roller too the metal frame, by gently tapping them off, remove old belt from rear roller, Now go to front roller, and remove belt from front roller, and its time to Install new Belt, AND AJUST NEW BELT, Put belt on front roller and reinstall roller, put plastic end caps back on frame, and then reinstall rear roller threw the belt and reconnect to the plastic end caps on the rear of the frame, Now reinstall the board with 6 phillip screws, to the metal frame, Now turn treadmill upright again, Its time to AJUST YOUR NEW BELT 1st Center your New Belt, Then tighten rear roller bolts, ( Pay Attention ) Count even amount of turns for both Rear roller bolts, Then Ajust front roller Alignment, Their is only 1 bolt on most treadmills, So if your belt is pulling to one side when you turn the treadmill on,it means you still have to ajust the front roller ajustment screw, What I Do Is , I USE A small leveling tool, For the front roller ajustment, It KEEPS the pitch EVEN on both sides of the front roller, and this is HOW YOU REPLACE YOUR BELT AND AJUST THE NEW BELT, and save your self some money, enjoy, in you need to contact me, kjosr@cox.net
Oct 24, 2010 | Nordic Track /proform Treadmill...
I have a NordicTrack Elite zi treadmill. While running I hear a ratcheting click coming from the front housing area. When I hear this ratcheting click the belt is slipping a little bit. Any ideas of...
This is more than likely a loose drive belt, which would explain the slipping as well as the sound. To tighten this take off the plastic cover that covers the motor. You will see where the motor connects to the front roller with the drive belt. To tighten it there are two bolts that hold the motor to the machine, loosen those then pull it tight and retighten them, This should eliminate the problem.
Aug 17, 2010 | Nordic Track NordicTrack Elite zi...
Squeaking when i run on nordic track 5100r
My treadmill (American Motion Fitness) squeaks when only when  it warms up. I spray CRC oil onto the front roller bolts which bolt it to the swivel housing and onto the bolts which bolt the swivel housing onto the main frame also onto the rubber bushings which allow the front roller to bounce every time my foot hits the deck. I seem to have to do this 1 per week but it is easy to get at and takes 2 minutes. cheers johnO
Apr 29, 2009 | Nordic Track Nordictrack Apex 4100i...
I just bought used Nordic Track Elite ski machine. It is stuck in the highest position. The owner said she never figured out how to lower it, but a friend walked up to it a did something and it lowered. I...
Stand on the back of it, facing the front of the skis. You might have to push the button that helps you raise it while you are staning on it. It is a very elegant ride down! Hope this helps.
Apr 17, 2009 | Nordic Track NordicTrack Elite zi...
Nordic Track NordicTrack Elite XT Treadmill Logo
27 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
