Question about ASUS Google Nexus 7 Tablet
Nexus 7 will not completely turn on
Will not turn on completely,
    Filmmaker:
    Uploaded 5 video answers.
  • 39 Answers
The battery connector in the Nexus 7 (2012 model) is notoriously problematic. Sometimes dropping the device can cause issues that prevent the Nexus 7 from charging altogether. A hard reset may not work. Fortunately, it is quite easy to fix.
However this will void your warranty.
Pop the back of the Nexus 7 case open by pushing a credit card or guitar pick or small screwdriver under the edge of the black plastic case. Start from the top and gently pry the case open, working your way around. The back of the case will come off quite easily. The battery occupies the bulk of the left-hand side of the unit, and a group of six wires come out of the top of the battery to a connector on the circuit board. Gently push the plug out of the socket connector, wait 15 seconds, and push it back in. Snap the case back on and plug in your charger. You should now see the battery charge image appear.nexus 7 will not completely turn on - 17d253bb-4ba9-4ee2-99ca-91507603cc78.png
Posted on Dec 06, 2013
  • 5 Answers
Try hard reset: press and hold at the same time Volume Up + Volume Down + Power until the device powers on. You should see an image of an Android lying on its back.
Posted on Dec 19, 2012
How can I download flash player ?
  • Google is your friend in such cases :>)
  • How to Install Flash on the Nexus 7 and Other Jelly Bean ... www.howtogeek.com/120277/how-to-install-flash-on-the-nexus-7-and... 2012-07-29 · ... you can install Flash on your Nexus 7, ... it works flawless on Nexus 7. Thanks. ... Took the Flash Player 11.1 from my Galaxy Nexus and it works a ...
  • How to install Adobe Flash Player on Nexus 7 and Nexus 10 ... best-tablet-converter.com/.../install-adobe-flash-player-on-nexus-7-10 This tutorial will show you how to Download and Install Adobe Flash Player 11.1 on Google Nexus 7 and Nexus ... you can install Flash Player on your Nexus 7/10, ...
  • How to Install Flash Player on Your Nexus 7 Tablet to ... nexus7.wonderhowto.com/how-to/install-flash-player-your-nexus-7... Video embedded · There's no Flash Player or Flash plugin in the Google Play Store anymore, ... How to Install Adobe Flash Player on Your Nexus 7 Running Android ...
  • Nov 26, 2015 | ASUS Google Nexus 7
    Nexus 7 tablet flashing white light
    I am very familiar with this problem with the 2nd gens and it is almost always a sure sign that the tablet is not getting enough power to charge up and will not boot. Sometimes this can happen from the tablet not getting used for a while and getting completely drained. The other possibilities are A) the USB charging port is becoming worn out and won't charge or B) the battery is no longer holding a charge, much like a car battery in the winter. Get an original Nexus 7 wall charger and leave it charging through the wall outlet and not a computer, this has more power. If the light is blinking, it makes me think the USB is not the issue, so chances are after an hour or two it will have some life again.
    Jun 14, 2014 | ASUS Google Nexus 7 8GB Tablet Unlocked...
    Nexus 7 won't turn on after charging
    I found that if the Nexus 7 (or 10) is left on until the battery drains completely, then switches itself off, it doesn't switch on normally after a recharge. All you need to do is press the on button for several seconds and it will reboot. If that doesn't work then try a hard reset. Refer to user manual which should be in the file system.
    May 19, 2014 | Google Nexus 7
    How to put in sim card
    Assuming you mean the 2013 version but I'll try both,
    so for the 2013 version
    1. Turn your tablet off and place it on a flat surface with the screen facing up.
    2. Tilt the right side slightly up to find the SIM card tray near the bottom right and the small hole in the tray door.
    3. Insert a paperclip into the hole in the tray door, and push firmly but gently, the tray should pop out.
    4. snp_8a30b60eaed5a3a37f46a8c715167552992e_3271601_en_v0Remove the tray and place the micro SIM card inside it, the angle corner fits with the angled indent
    5. Push the tray it gently back into the tablet.
    6. snp_8a30b60eaed5a3a37f46a8c715167552992e_3271604_en_v0
    Activate SIM card
    1. Open the Settings app snp_2918920_en_v1 and turn off Wi-Fi after completing the set-up instructions. Once Wi-Fi is off, you'll see a notification at the top of your screen.
    2. Swipe down the notification shade and touch the notification.
    3. Follow the activation instructions provided by your carrier.
    For the Nexus 7 (2012) 3G use the same process noting that the tray slot and pinhole is on the left side of the device when its facing up.
    *Note* : Only the Nexus 7 (2013) LTE & Nexus 7 (2012) 3G can accept a SIM card. Wi-Fi versions of the tablet can't.
    Dec 10, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
    Google support
    Is this after serveral power-off and power-on attempts?
    If so, you may need to reset it to factory defaults by entering "recovery mode".
    Google "nexus 7 recovery mode" and follow the options within. All data on your nexus 7 will be lost.
    Dec 06, 2013 | ASUS Google Nexus 7
    Nexus 7 screen broken and back slightly popped
    It sounds like the device is completely broken after dropping it. You may find a local repair shop or a shop online to fix the device, but it may be cheaper to replace it with a new one.
    Hope that helps!
    Feb 24, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
    ASUS Google Nexus 7 Tablet Logo
    359 people viewed this question
    Top ASUS Tablets & eReaders Experts
    k24674
    Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
