Question about Hitachi 53SDX01B 53" Rear Projection Television
Picture is black. sound went out a few weeks ago and now all that seems to work is the red power lamp turns on and I hear a click but that's all. I am not concerned about the picture since it is c
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
The click is a power relay on the main board and if the red light is on I would suggest looking inside to see if it has more than one relay--follow the power cord into the set----some of these sets have one relay but others have up to 3.
They are know for sticking open or shut. A tap on them can free them..A look inside even by a novice may also reveal something burnt or unplugged etc.
Picture is black. sound went out a few weeks ago a - 12_5_2012_3_12_13_pm.jpgview of relay bottom side is up.
Posted on Dec 05, 2012
SOURCE: Hitachi 60EX388 Rear Porjection TV
i think its the fan that needs to be replaced. or it could be the bulb.
Try to open the bulb assembly unit and take out the bulb and put it back in. If you have an extra bulb, replace it and see if works. This worked for me. The bulb i bought wasnt compatible
Posted on Mar 03, 2008
SOURCE: I have a 50 inch hitachi ultravision that has no picture or sound but power light is on
Probably a 'cold or detatched' solder joint on a component on that perticular circuit board you are 'wedging' with a plastic rod.
Posted on Apr 19, 2008
shaggyrat
  • 1224 Answers
SOURCE: Hitachi ultrascan hd- no picture, just makes clicking sound
wires are crossed over to wrong amplifiers when hooked up you might have blown completly
Posted on Dec 06, 2008
  • 1779 Answers
SOURCE: no picture/ no sound
Guest= Yours seems to be your lamp needs replacing, the buzzing is the lamp inverter trying to start the lamp and the lamp says NO.
Posted on Mar 21, 2009
  • 541 Answers
SOURCE: hitachi 51f59a lost picture
You may have a shorted horizontal output transistor. This transistor drives the high voltage transformer which in turn drives the picture tubes. High voltage can be dangerous so you may want to have a repair shop check it out for you. Also have them apply a bead of silicon around the anode caps on the picture tubes. This will prevent high voltage leaking out and causing the horizontal output to short again. Thanks
Posted on Oct 28, 2009
Okay, so my Panasonic PT-43LC14 went black in mid show last night. The bulb is approximately 18 months old. The LED indicators upon Power On are; Power LED blinks green for approximately 70 seconds; Then...
Check the bulb again and look at the root of where the main stem comes out inside and be sure you don't see any bubble like appearence around the stem at the bottom there. If you do see this then the bulb is bad. Otherwise try this: Hold volume down on front of unit and pip on remote for about 5 seconds. Message will come on screen that timer has been reset to zero. This sets the lamp timer to 0
May 17, 2011 | Panasonic PT-43LC14 43" Rear Projection...
Sound, but no picture.. :(
Could be lamp again since lamp light is on, Mitsubishi's are known to eat lamps. Unplug tv and remove lamp and give it a good looking over. Sometimes the lamp will give you a clue if the glass inside is broken or cloudy the lamp is worn out. But it's not accurate 100% of the time unfortunately. my guess would be the lamp is bad. It would be one of the cheaper fixes for sure.
Feb 23, 2010 | Mitsubishi WD-Y65 65" HDTV
My samsung hlr5067r went black no sound or
Tries reinstall ur lamp,check ur power supply for burn parts like capacitors burn,like it puffed up.
Sep 25, 2009 | Televison & Video
My 44in rca dlp picture is black and is making a humming sound
It sounds like to me theat the new lamp is faulty. If there is any pieces of glass in the lamp compartment, remove them so they will not travel and get wedged in places they should'nt be.
Hope this helps,
Skyassoc
Jun 16, 2009 | RCA Televison & Video
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I have Mitsubishi WD-62525. Last week I turned TV on and there was no picture, on green horizontal lines across the screen. The picture then went black and I only have sound. The lamp indicator lite turned...
that is a common problem with that model you will need the v26 power pwb repair kit and the V26 FMT pwb repair kit. You can get both kits at the following link which includes the replacement capacitors and instructions on where the capacitors are located. Heres the link.
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi Televison & Video
Xbox 360 problem
If you can still HEAR sound, but can't see. Check your Audio Video Cable.
It's the colorful one (red, white, yellow) (red, blue green, white, red)
Make sure the connections are secure into the back of the TV as well as the connection to the back of the Xbox 360.
Jul 18, 2008 | Microsoft Xbox 360 Console
We have sound, but no picture
could be the relay transistor or diode close to the relay in the power supply
Sep 29, 2007 | Toshiba 46HM95 46" HDTV
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Hitachi 53SDX01B 53" Rear Projection Television Logo
100 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
