Question about Cell Phones
My I pod not working - Cell Phones
Try restoring it ?
Posted on Dec 05, 2012
Podhd400 not working
Try doing a reset as explained in this video-
http://line6.com/support/page/kb/_/pod/pod-hd300400/video-tutorial-pod-hd300-400-factory-reset-r214
May 09, 2014 | Line 6 POD HD400 Pedal Multi-FX Guitar
I have an I-Pod touch and all off a sudden CCS stopped sync with my facebook acc ,i have checked both fb + i-pod settings which both enable access for each other but it doesnt help , how can i fix this ?
try updating your I-pod on the iTunes software on your computer if that doesn't work back up your I-pod on the iTunes and then reset your I-pod to factory settings. now if you backed your I-pod up properly then log back into your I-pod with your iTunes account and plug it into your computer, it should automatically restore all your apps and music ect. then you should be able to sync what ever u want again the problembeing is u probanlypicked up a virus or something on your I-pod
Jul 31, 2013 | Audio Players & Recorders
Ball bearings are gone from one of the four holders inside
Use a flat head screwdriver and slowly work it underneath the pod and work the pod away from the body.
www.cpo2go.com
May 13, 2010 | Hayward Navigator Pool Cleaner
Hang-up
Hi, when a apple i pod freezes and refuse to function, it means that the i pod memory has stop working due to an application you installed in the i pod.
To rectify this problem, you will need to flash the i pod for the memory to start working properly.
Flashing an i pod helps you restore lost memory. After flashing the i pod, you can now start using it again as normal.
Take care.
Apr 14, 2010 | Apple iPod nano 3rd Generation
I have the Keurig Gourmet Deluxe Home Brewing System #B60 When the pod is in place with the cover down the water won't come out while brewing. It will not make a brewed cup of coffee. If I remove the pod...
Check that pod has a punctured hole on BOTH ends.. If the bottom or to wear not punctured this will happen with most Keurigs.
Replace the pod holder if defective.
May 18, 2017 | Keurig Coffee Makers & Espresso Machines
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
Bose Control Pod won't work
Try changing the plug on the control pod, those plugs are fairly weak and prone to breakage. Does there appear to be any strain at all on the plug itself? if so then that is where I would start. If you have a series 2 then I can help you, or if you can find out if the 2 control pods are the same, that would be fine too, but I have a series 2 system companion 3 and if needed I will cut my cable to trace the wiring and then replace your plug for you. my cost for this would be $40, that includes return shipping with priority mail.
Oct 03, 2008 | Bose Companion 3 Computer Speakers
Chinese I pod not working
try to use itunes software
Mar 06, 2008 | Audio Players & Recorders
5500 d Control pod
Hi Hlth501
So far, is better to get a new control pod. Call the company and see if work for buy it
Nov 25, 2007 | Audio Players & Recorders
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
