Question about Samsung DLP HL-P5663W 56" TV
HLN507W picture is in black/white what componet or board is bad
Picture shows up in black and white from all sources. disconnected dvd and ran it direct to TV same problem. Any help would be greatly appreciated.
Turns out wife bought a 5 yr service plan...I didn't know about...it expires in march...WoW; what luck. Tech is 90% sure it's the color wheel
Posted on Jan 13, 2009
Turned my tv on and for some reason the DVD source is in black and white and controller not workin for it, TVs colour for other outputs and controller works only DVD that doesn't .
If you're using component cabling (red, green, blue cables) a black and white picture will occur when only the green cable is plugged in.
If you're using HDMI cabling, try a different HDMI port and see if your color comes back.
If not, unplug the set from power for a few minutes, plug it back in and see if problem persists.
If you still have the same problem, check the DVD player on another TV. If it shows color on a different TV, then your TV will need a replacement digital board which we can check availability on once we have a specific model number. If it's black and white on a different TV, then you have a problematic DVD player.
Dec 15, 2012 | Televison & Video
The tv on;y shows a small pip window in color if it is a large picture the picture is in black and white how to fix?
Whatever input video signal you're using, PIP should be in color. What are you using out of your dvd for the second video input source, composite or component? Composite you should always have color, Component, if you have a bad red or blue, and just the green is working, you will get black and white. The green is the luminence signal.
Nov 23, 2011 | Televison & Video
Hello my Phillips 42" model
HI:
Check your componet connections to the TV, Componet cables use green,red, blue and red and white for audio, check the green cable go see if it came loose, because if it is the picture will be B
&W.
May 23, 2011 | Philips 42PF9630A 42 in. Plasma Television
Toshiba dvd when plugged to componet to tv picture balck and white... The picture is fine when plugged to composite or s-video... Component from sat box plugged to tv works fine too..
Sounds like either the cables you are using are bad or the component out on the dvd player is bad. Try using a different set of cables and make sure there are no loose connections on the dvd player
Aug 21, 2009 | Televison & Video
My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
Mar 16, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Black and white picture for DVDs not tv
Make sure you don't have a componet plug in a A\V hole or the other way around.
Mar 15, 2009 | Bose Lifestyle 18 System
Magnavox mwd7006 dvd player hookup
if you are useing componet output and the pic is black and white you have them hooked up in the wrong order
The Cableguy
Oct 17, 2007 | Philips Magnavox MWD7006 DVD Player
Color
Have you tried to hook up a DVD player or any other source? If so does the color come back? If not then I recommend you call for warranty service if the set is in warranty, sounds like the vidoe processors are bad on the main board
Feb 18, 2007 | Maxent MX-42HPM20 42 in. Plasma HDTV
Samsung DLP HL-P5663W 56" TV Logo
142 people viewed this question
Henry  Thomas
Henry Thomas
