Question about Boston Acoustics TVee Model 25 Sound Bar and Wireless Subwoofer Blac
Programming time warner remote to boston tvee volume
How do I program my time warner remote control to adjust the volume on boston acoustics tvee model 25 sound bar with subwoofer?
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Posted on Dec 21, 2012
  • Robb Fulker
    Robb Fulker Apr 17, 2014
    I forgot all about the programming from the Soundbar! I had a small issue that may be important to note...some how I hit the off button and pushed the down arrow for the volume button so what happened was I pushed volume up and it worked great (nice and loud) then when I tried to turn it down, the soundbar shut off! LOL!! so be careful which buttons yo push on the soundbar before pushing the button on the remote :-)
3 Suggested Answers
  • 3 Answers
SOURCE: Trying to synch my remote
I had this same problem and it was due to their instructions which do not adequately explain the setup procedure.
On my own, I was successful in programming volume up but that was all. I assumed that for volume down I would hold the power button and the VOLUME DOWN button and wait for the flashing light just as I had for volume up. Problem is, you never get a flashing light.
Today, I spoke with a rep from Boston Acoustics who patiently explained that step one of the instructions has to be done the same way each time as it is the step that puts the soundbar into programming mode.
It is only at step 2 that things change.
The solution is to hold the power button and the Volume Up button every time in order to get the system into programming mode. Once the light is flashing, in order to program Volume Down, you then hold the Volume Down button until the light goes solid. Once the light goes solid, then press the volume down button on your remote 4 times slowly. Works like a charm.
Works the same way to program the mute button. Follow step one to get the unit in programming mode. Once the light is flashing, hold down only the mute button until the light goes solid. When the light goes solid, press the mute button slowly 4 times.
OBTW, this was programmed with a Logitech Harmony 650 remote unit.
Posted on Oct 07, 2011
SOURCE: tvee model 25
Have you checked all your wire connections? To make sure thier not loose.
Posted on Aug 05, 2012
Boston Acoustics TVEE 26 factory reset
Reprogram the remote to function with a different brand of equipment that you do not have. The remote can't affect the receiver if it is not talking to it.
Feb 23, 2014 | Boston Acoustics TVee Model 26
Tv volumn
Are you using another remote for the guide? Like the cable box remote? If that is the case then the remote could be sending a signal to the cable box that is the same as the signal used to adjust the volume on the television.
Apr 30, 2013 | Boston Acoustics TVee Model Two TV...
Trying to synch my remote to the new tvee model 25 sound bar and can't get the orange lights.
Sep 05, 2011 | Boston Acoustics Audio Players & Recorders
Have a BA TVee 25 Soundbar. Only able to program Volume Up on my remote. Cannot program Volume Down or Mute. Nothing happens except to turn the Soundbar off and on. Don't tell me to follow...
Jul 26, 2011 | Boston Acoustics TVee Model Two TV...
Got the Boston Tvee 25 and was able to program the volume up ok, but not able to program the volume down or mute functions. The process is the same but ive tried 100 times with no luck! Any help?
Jun 05, 2011 | Boston Acoustics TVee Model Two TV...
Can program up volume but not down or mute
To program the down button, after step 1 of the programing sequence, you must press the down button of the speaker system and then press the down button on the remote four times. This goes for the other buttons (i.e. after step 1 of the programing sequence, press the mute button on the speaker system and then press the mute button on the remote four times).This is a weak point in the programing instructions.
May 25, 2011 | Boston Acoustics TVee Model Two TV...
No sound in sound bar and subwoofer
It could be that the unit is bad, it could also be that the device providing the input is bad. I doubt the cables are bad, but that could be also. Could it be possible that your television has a menu setting that turns the outputs off and on?
Even without the sub, you still get sound through the Bar.
Only way to test it is, different cables, alternate device to provide input for sound.
Dec 14, 2008 | Boston Acoustics TVee Model Two TV...
Not enough IR range to use remote
Get yourself a very thin and small screwdriver. The type that comes in the eyeglass repair kits. Remove the cloth/plastic grill from the front of the sound bar. Locate the IR sensor in the center of the bar. Pry the dark red filter off the IR sensor and leave it off.
Problem solved, greatly increases range. I have read that there is a clear replacement cover you can buy but whats the point?
Nov 15, 2008 | Boston Acoustics TVee Model Two TV...
Suround sound dvd
Get a Boston Acoustics Tvee Soundbar System.
Dec 06, 2007 | Boston Acoustics TVee Model Two TV...
Boston Acoustics TVee Model 25 Sound Bar and Wireless Subwoofer Blac Logo
1,091 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
