I have an olsen hds 90t furnace.i replaced the 50a50-216 control with a new 50m56-843 control.everything seems to function normally except that the heat delay to fan off is 30 sec. Instead of what it's supposed to be (150 sec) .what could be the problem? Is something wired up wrong?
boanhtgclg
  • 34 Answers
SOURCE: New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Posted on Nov 12, 2008
boanhtgclg
  • 34 Answers
SOURCE: Auto fan does not turn my furnace fan on-I have to use manual on
with the fan in the auto position, the fan only comes on during a demand for heat.  does it not come on during a demand for heat?
Posted on Nov 24, 2008
  • 189 Answers
SOURCE: Old mercury thermostat, New furnace wiring issues
Two wire hookup on the old thermostat tells me that it was set up for heating only. You will most likely need a modern thermostat. But in the meantime try this with the old one. The two red wires on the furnace are probably Rh & Rc. If so these can be put "together" on the R terminal on the old stat. The two W's on the new furnace are probably W1 &v W2 This is for first and second stage heat. You can put the two "together" on the W terminal on the old stat. Do not hook up the greens (blower fan wires). Do not hook up the blue wires (They would go to the Y terminal on a modern stat for airconditioning.
Who ever sold you the furnace should have offered you a new thermostat.
Good luck....
Posted on Apr 10, 2009
wcrawf11
  • 52 Answers
SOURCE: Honeywell 7600. When the setpoint is reduced to
Go to http://www.honeywell.com/ look up your therostst model No RTH7600D
Posted on Oct 24, 2009
  • 66 Answers
SOURCE: Goodman gmp075-3 gas furnace and the flame cycles
you need the same board. the one you have is not compatible with your unit
Greg
Posted on Dec 15, 2009
I have an Olsen Ultra Max Furnace. The diagnostic indicator is a steady light, which according to the code sheet means replace control. What does Replace control mean?
In most of the industry, the control means the main control board. Most systems out there have indicator lights right on the main control board. This may be the case for you.
Dec 29, 2017 | Heating & Cooling
Coleman evcon furnace
How old is your furnace? Does it have a circuit board that controls everything, or are there separate controls for each function?
Nov 19, 2013 | Heating & Cooling
I have an evcon furnace that was put on brand new about 5 years ago. I have noticed that it doesn't seem to be kicking off and it doesn't seem to be heating my home either. A line was kinked last year...
This going to be little lengthy. The fan can be on from two reasons. If your thermostat has a fan switch, it will say ON or AUTO. Put it to AUTO. Turn your thermostat to its lowest setting and wait 3 or 4 minutes. If the fan stays running, the problem is in the furnace. Newer furnaces have big circuit boards that control all its functions. The fan automatically starts after a factory set period of time (about 45 seconds). Try a HARD reset to get all the furnace functions back to normal. Turn your thermostat as low as it will go. find the breaker or fuse that serves only the furnace. Unscrew the fuse or turn off the breaker for a good minute and replace/reset it. If the fan starts right away, the board is probably bad. PC relays often arc together and the entire board will need replacement. If the fan is off, turn your thermostat way up and see if the furnace lights. The fan will probably restart in a minute or so as a normal function, heat or no. If the furnace does not fire, Let me know and I'll tell you how to check that switch that was replaced.
Oct 24, 2013 | Heating & Cooling
Coating from water panel pad clogging furnace filter
I know of no answer to this except to remove the coating manually to prevent it clogging you filter.
Jun 22, 2017 | Aprilaire 600 Humidifier
Goodman furnace model # GMNT100-4B On vacation, neighbor checked house, house filled with gas. He shut off main and furnace. came home turned on gas to everything except furnace. All good. Furnace will...
Solid red typically means bad controller. Try unplugging the furnace, wait about 30 secs, then plug it back in. The possibility that the controller was sending voltage to the valve even when there was no flame is a bad sign. If the controller starts the furnace, watch it very closely and see what it does. If the solid light comes back on, it's time for a new board.
Mar 24, 2010 | Goodman GMS90703BXA Heater
Combustion Chamber hot air oil furnace
it is down to cost how old is it , is it worth it over the cost of a new heater you will neede to speak with a plumber to see what is best to do with this heater as they can look at the heater and advice you .
Jan 29, 2010 | Heating & Cooling
Intertherm Furnace - Blower cycles on and off (varies in length)
Its still hard to say from your info...does it seem that the furnace is running a normal cycle except for the fan???...could be a wiring problem , circuit board/relay problem , or fan control problem....really the make and model of the furnace and age would help ....could be several things....does it heat your house to the correct setting??
Oct 29, 2009 | Heating & Cooling
Ruud uprl-036jez is tripping on high head pressure. Indoor coil seems to be clean, filter is clean. ref charge is good. Indoor txv was replaced. Fan is on high speed. Hooked up to a 10yo olsen direct vent...
Check your TXV outside just like you do inside. Strap temperature sensor to outlet of TXV, disconnect the bulb.and let run 5 min, Get temperature reading, then put the bulb in your hand and watch the bulb open up. Next stick in a cup of ice water and watch close.
Check your 4 way valve for proper operation.
Do not hit accept unless you can give 100% good feed back.
If you need more help Please post back.
Let me know how it went.
Dec 01, 2008 | Heating & Cooling
Heating & Cooling Logo
128 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
