Question about MTX Car Audio & Video
I just recently bought a brand new MTX magnum amp and dual 10" enclosed subs deal off of amazon. They arrived today, and with the help of a friend who is good with car audio systems, we set the whole
    Master:
    Sergeant:
  • 447 Answers
The best thing to do is get in touch with amazon,and see what they can do about it,if you try to fix the problem yourself it will invalidate the garantee!
Posted on Dec 05, 2012
  • 1 more comment
  • xrockoutloud
    xrockoutloud Dec 05, 2012
    so should I just return them and get my money back?
  • xrockoutloud
    should I try contacting the MTX company and see if they have any suggestions?
  • Chris Harvey
    Chris Harvey Dec 05, 2012
    you can try MTX and see what they can offer,or get your money back and go for a different make,the choice is yours, but i would like to know the outcome of it if yoi wouldnt mind be lucky,.
Mtx surround sound sub is on but no sound or thump.
most electronics now days only last for about five to seven years
so I would get checked out by a technician.
Jan 27, 2014 | MTX Audio Players & Recorders
I have 4 mtx 9500 12in subs 2 of them is on a mtx 92001 and the other is on a mtx 4001d . would it be better to run all four on the mtx 4001d. for more power and a better sound or how should i run this set...
NEVER mix different power amps. Depending on the ohms of your subs, sell one of the amps, up to you. The 4001 has more power, but either amp will do the job, the amp needs to see a 1 ohm load, so your subs have to be dual 2 ohms, or single 4 ohms to do this. If your subs are dual 4 ohms then you will have to run your amp at 2 ohms which would be have the power, or a half an ohm, (Not Recomended) and be at double the power. You may be able to do a competion sound off and just "Burp" the subs, but at a half an ohm, dont expect to listen to it to long before it goes into protect and shuts down.
Sep 06, 2011 | MTX Thunder Elite TE4001D Car Amp
Need to know how to wire my system ...I have the infinity reference series 611a I was told it was a mono block but it has two channels on the exterrior...also I have two 12 inch MTX thunder dual voice coil...
it all depends on what kind of box the mtx subs are in as far as wiring the subs. The best way would be take the speaker wire from both sub boxes and run the positive into the right positive then the negative into the left negative. and run 8 gauge wiring kit to the amp because 10 might be to small and 4 is to big 8 gauge is perfect for this amp.
Jul 18, 2010 | Infinity Reference 611a Car Audio...
Can you help with my wiring?
The more amp you are pushing the better. Better too much amp then not enough. How many watts per speaker? less then the amp I hope. When you need decibles the more air you push the louder it will be. Enclose in a MDFB enclosure or plexiglass and feed towards each other and port the box to the sides. This will cause some annoyance. We ran 2 rockforts @1000 watts and abtained 137dc before the back windshield blow out,,lol
Mar 09, 2010 | MTX 6001 Car Audio Amplifier
How do i wire mtx 9500 subs 2 10'' down to a one ohm
THE T9510-04 SUBS ARE SINGLE COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-04.pdf
THE T9510-44 SUBS ARE DUAL VOICE-COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-44.pdf
SINCE YOU NEED A 1 OHM LOAD, I PRESUME BRIDGED AND ARE USING TWO SUBS, THEN HOPEFULLY YOU HAVE THE DUAL VOICE COIL TYPE, AS THEY ARE DUAL 4 OHM AND YOU WILL HAVE TO CONNECT THE VOICE-COILS IN PARALLEL WHICH WILL MAKE EACH SPEAKER A 2 OHM SPEAKER AND THEN CONNECT THE TWO SPEAKERS THEMSELVES IN PARALLEL AND THIS WILL PROVIDE YOU THE 1 OHM LOAD. IF YOU IN FACT HAVE THE SINGLE 4 OHM VOICE COIL VERSION, THEN IT WILL ONLY PARALLEL THE PAIR DOWN TO 2 OHMS. OK. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 08, 2010 | MTX T9510-44 - 10" 9500 Thunder Series...
My friend sold me his subs today and one sub doesn't work. they're mtx thunder 8000 will mtx fix the sub for me?
They probally would, but i just found that sub for 51.00 im sure it would cost that and more to have.it fixed
Nov 09, 2009 | MTX Thunder 8000 T8104 Car Subwoofer
I have this same problem
Check the power with a volt meter. The battery power, then the remote power. Also make sure it's grounded properly. bad grounds cause mayhem.
Sep 14, 2009 | Pyle BZDBP212 Car Subwoofer
Mtx 7500 sub
what amp are u usin?What enclosure 4 speakers do u have?Might not have enouigh voltage 4 the amp.How big are the wire for power 2 amp?what ohm are you playing ,is it compatible to the woofers.Need more info.Model and makes please,but 1st a rating.
Jun 16, 2008 | MTX Car Audio & Video
My car AMP will play for a few minutes, then just Turn OFF
Is your sub single voice coil or dual? If it's dual, is it wired in paralel or series? It's possible for an amp the heat up so fast, the outside is not hot to the touch. Also, the next time it happens, use a paperclip and short the 12+ to the remote wire on the amp and see if it comes on. Let me know, and be sure to leave feedback or I don't get paid
Sep 30, 2007 | Car Audio & Video
Car Audio & Video Logo
129 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
