My mobo has 4 memory card slots
How do i install two different sets of memory cards on my motherboard
  • Computers & ... Master
  • 5,387 Answers
1) All of your memory must be compatible with your motherboard (DDR, DDR2, or DDR3 and speed and latency). For best results, if you have dual channel capability, each pair of memory sticks should be matched. (Usually consecutive serial numbers indicate pairs from a given manufacturer.) Both sets of memory should be rated at the same speed (or the slowest speed will be your memory speed). Some motherboards may not work with all 4 slots occupied unless the memory was certified to work as a set of 4.
2) Which motherboard do you have? The motherboard manufacturer and memory companies often will have lists of compatible memory. The motherboard manufacturer will also have information on the dual-channel pairing.
My current and previous motherboards have had memory slots in color pairs (blue, black). For my boards, I put the sticks in the blue slots (A2 and B2) first. (Preferably these should be the largest memory capacity.) Then I put the second pair of memory into the black slots (A1 and B1). DIMM slot A1 is closest to the CPU; B2 is the farthest away from the CPU.
Depending on your CPU cooler, you may need to remove it or modify it to use all 4 DIMM slots.
Observe the appropriate steps to avoid static discharges while handling your memory and when inside your computer. For actually inserting the memory, make sure that the locks (white on my motherboards) are fully open (hinged away from the slot). Line up your memory so that the slot in the memory is on top of the key in the slot and the memory is centered in the slot. It will only line up one way; the wrong memory type will not line up. Push your memory stick down fully until the locking clips rotate up and fully engage the memory. (You may need to push down at multiple places to get it fully seated.) You will then repeat the procedure with the rest of the memory.
Note: if you get a memory error, three beeps (on many boards), you will need to remove the memory and test one stick at a time in the A2 slot (for example). Then test pairs of slots. It is not unknown for either one stick to be bad or one slot to be bad. Look at the total memory your OS identifies, if you manage to boot in spite of any issues. Running Memtest may be needed but even that may not identify which specific memory segment is bad.
I hope this helps.
(who has installed or replaced memory since giving an 286 computer a full megabyte of memory. DIMMs are a lot harder to mess up as long as you have the correct memory. Note: most of the different DIMM types have different number of pins; thus sometimes it's very easy to tell that the wrong memory is being used. This isn't always the case.)
Posted on Dec 05, 2012
melnavz
  • 1226 Answers
SOURCE: gateway sb-4100-b won't recognize new memory
REmove all the old memory and replace it by a new memory, you should test memory 1 by 1 .
first install the 1 memory in the first slot. then boot the computer using only 512mb. if this successful. shutdown and insert the second memory, then test again.
note: memory should be:
1. DDR SDRAM
2. the two 512 should be the same brand.
Posted on Dec 28, 2007
map9966
  • 2351 Answers
SOURCE: imstalling internal card reader
Hi jmarie, If you have the standared Dimension 3100 it did not come with a floppy drive. If so you can buy a Sabrent Internal 64-in-1 Multi Flash Media Card Reader - USB 2.0, Black, 3.5", Self Powered, SDHC Support, Vista ready reader that fits in your emty floppy drive. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1871218&CatId=962
Your dell does not have a free 5-pin male USB connector on the motherboard. So you'll also need a Sabrent SBT-FWPH USB 2.0/Firewire 1394 8 Ports PCI Card Internal Combo Hub.
Included, Free Standard Shipping. Here: http://www.meritline.com/3-port-firewire-5-port-usb-2-0-combo-pci-card.html
The card reader will plug into the internal USB 2.0 Sabrent. You will gain four USB plugs & two 1394 plugs. Once you see the pictures you will understand. Bottom line everything will be inside the PC.
Or you can use the external as computafixa suggested for half the cost. Click the link to see:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3603298&body=MAIN#detailspecs
It's up too you jmarie!
Posted on Feb 23, 2008
egadgetguy
  • 258 Answers
SOURCE: Have a dell Inspiron 1525
the MS pro may need an adapter if it's the mini kind. then that will plug into that slot. it still won't fit the same way as the SD card, so insert it carefully. there should be an indented area for the MSP card to insert.
Posted on Aug 18, 2008
Shdak
  • 23 Answers
SOURCE: I have an HP Pavilion 752n Win XP SP3 with ASUSTeK
The motherboard can support 1GB of memory, Window XP can manage up to 2GB fairly good maybe more with other setting applied. I would recommend using two 512 memory chips to fill the slots to prevent any memory conflict issues.
Posted on Apr 08, 2009
  • 202 Answers
SOURCE: Total amount of RAM not recognized by computer
are the modules the same specs? you may have some incompatibality between them. the board may be reading the ram right it may be you have four 256 sticks instead of 2 of each. read the motherboard manual it might shed some light here.
Posted on Jul 13, 2009
New motherboard GA-p67x-ud3-b3 no video on boot
  1. 1 x PCI Express x16 slot, running at x16 (PCIEX16)
    * For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
  2. 1 x PCI Express x16 slot, running at x8 (PCIEX8)
    * The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
  3. 3 x PCI Express x1 slots
    (All PCI Express slots conform to PCI Express 2.0 standard.)
  4. 2 x PCI slots
Apr 29, 2012 | Gigabyte Computers & Internet
Foxconn a6vmx motherboard , just installed but no vga output?
Check the Motherboard to make sure that the jumpers on the motherboard are not set to disable the slot. Try the card in a different pc. Try a diffrent card in the same slot. That should tell you if it is
1.motherboard
2.slot
4.or card......
Good luck, hope this helps,
James.
PLEASE VOTE 4 THUMBS UP 4 ME!!!!!!
Apr 26, 2010 | Foxconn A6VMX Socket AM2+ AMD Motherboard...
System will not boot
Do you have any pci devices installed? Bad PCI deviced, especailly modems, will cause a PC not to post. Did you try swapping the memory for a different module? It could be the stick and not the slot. Also, are there any blown capacitors on the MOBO, you would know this if they are puffed up at the top.
Aug 05, 2009 | Soyo SY-7VBA133U Motherboard
I need to solvthe problem of my new install memory
According to the specs of this motherboard, it supports DDR 333/400 and DDR2 533/400 memory modules. It does not support DDR2 667 memory modules.
DDR 333/400 memory modules can be installed in the yellow slots, whereas DDR2 533/400 memory modules can be installed in the blue slots.
Only one type of memory modules (either DDR or DDR2) can be used. Mixing of different types of memory modules is not supported.
Jul 11, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
P4m800pro-m478 "No video"
if you have another pci slot install the card there
if that does'nt work
your card has probably gone
please rate me
thanx
Feb 02, 2009 | EliteGroup ECS P4M800-M Socket...
So..
Hi tmomonet, did you install you're PCI-E video card in the correct slot? Open you're manual to page 2-18. Once you have gone over that part of you're manual you will need to enter the bios to check some settings so you're video card boots with the system. (Please make sure you're PCI-E video card is installed fully into the PCI-E blue slot). (Some PCI-E cards also need extra power, if youre's does it will have a power connector on the rear of the card).
Once into the bios, open you're manual to page 4-20. Open PCIPnP. Than go to page 4-26. At the bottom of the page you will see, Primary Display Adapter. Change to PCI-E & not to PCI.
Save & exit the bios. You should gain video display. Once windows finishes loading, install your video card software.
Good Luck!
Mike
Jun 03, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
System not starting
The problems which can cause a MoBo to fail are many:
1. You might have shorted it. In most cases you'll smell something.
2. Video card not picking up. Check its position in slot and cable to screen. 3 beeps indicate video card not peoperly installed.
3. Memory may be out of position or in wrong slot.
4. Power supply to mother board connection-- check
Feb 18, 2008 | Intel D102GGC2 Motherboard
P4VMM2 - what graphic card to use?
Any current brand/model of an AGP video card would work with this motherboard (NVidia or ATI). The only limiting factor would be how much you would want to spend for it.
Not a preference but an observation dito sa tin, mas matagal buhay ng ATI compared sa NVidia.
Hope this be of some help/idea. Pls post back how things turned up or should need additional information.
Good luck and kind regards.
Jan 10, 2008 | EliteGroup P4VMM2 Motherboard
CANNOT SET UP SLI MODE
So it sounds like you are able to enable SLI mode, but once you do, you have no video output (upon reboot). The most likely problem is that it's now in SLI mode, but your monitor cable is hooked up to the wrong video card; try changing it to the other video card, and see if you have output from that one.
Sep 19, 2007 | Gigabyte GA-8N-SLI Motherboard
Sli 8600gts cards on mobo
maybe you need a higher wattage Power Supply. try decreasing the load like removing optical drives and extra HDD.
Sep 14, 2007 | Gigabyte GA-8N-SLI Motherboard
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
