Question about Cell Phones
Touch screen not working on lgl45c
Did factory reset now touch screen not working
How to factory reset my asks eee slate ep212
On the home screen touch the All Apps icon, touch Settings.
Under personal touch Backup & Reset.
Touch Factory Data Reset.
You will lose ALL DATA.
Performing Factory Reset on Your HP Slate 7 HD or Slate 10 HD Tablet...
Nov 28, 2016 | Computers & Internet
Motorola factory reset
Apps > Settings > Backup & reset . Factory data reset
To Perform a Reset
  1. Open the Applications Tray. (arrow pointing up located in the middle at the bottom of the display screen)
  2. Touch Settings
  3. Touch Privacy
  4. Touch Factory data reset
  5. Touch Reset Phone
  6. Touch Erase Everything
For older phones: Master Reset or Master Clear
Mark
Motorola Support
Jun 29, 2014 | Motorola Cell Phones
Touch screen is not responsive on LG Spectrum VS920. I performed a a hard factory reset but can't answer the menu questions b/c touch screen won't let me! How can I get through the I am not able to...
Even if you were able to get past the setup, you would still not be able to use the phone. Since you have already performed a factory reset, I would suspect the actual hardware to be faulty. Get it serviced at an authorised service centre
Apr 03, 2014 | LG Vu CU920 Cellular Phone
Reset hp slate 7 to factory settings
  1. From the Home screen, touch the All apps ?javax.portlet.sync=ada14e3e822cc03c3ab7f3e532a15c01&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01_ws_bi&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d&javax.portlet.rst_ba847bafb2a2d782fcbb0710b053ce01=wsrp-url%3dhttp%253a%252f%252f16.193.225.56%253a50002%252fsp4tssearch%252fimageservlet%253fdocid%253demr_na-c03678322-4%252fc03687853.jpg%26wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d%26wsrp-requiresrewrite%3dfalse&javax.portlet.begcachetok=com.vignette.cachetoken&javax.portlet.endcachetok=com.vignette.cachetoken icon, and then touch the Settings ?javax.portlet.sync=ada14e3e822cc03c3ab7f3e532a15c01&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01_ws_bi&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d&javax.portlet.rst_ba847bafb2a2d782fcbb0710b053ce01=wsrp-url%3dhttp%253a%252f%252f16.193.225.56%253a50002%252fsp4tssearch%252fimageservlet%253fdocid%253demr_na-c03678322-4%252fc03687854.jpg%26wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d%26wsrp-requiresrewrite%3dfalse&javax.portlet.begcachetok=com.vignette.cachetoken&javax.portlet.endcachetok=com.vignette.cachetoken icon.
  2. In the Personal section, touch Backup & reset . Figure 1: Backup & reset
    ?javax.portlet.sync=ada14e3e822cc03c3ab7f3e532a15c01&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01_ws_bi&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d&javax.portlet.rst_ba847bafb2a2d782fcbb0710b053ce01=wsrp-url%3dhttp%253a%252f%252f16.193.225.56%253a50002%252fsp4tssearch%252fimageservlet%253fdocid%253demr_na-c03678322-4%252fc03687855.jpg%26wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d%26wsrp-requiresrewrite%3dfalse&javax.portlet.begcachetok=com.vignette.cachetoken&javax.portlet.endcachetok=com.vignette.cachetoken
  3. Touch Factory data reset . Figure 2: Factory data reset
    ?javax.portlet.sync=ada14e3e822cc03c3ab7f3e532a15c01&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01_ws_bi&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d&javax.portlet.rst_ba847bafb2a2d782fcbb0710b053ce01=wsrp-url%3dhttp%253a%252f%252f16.193.225.56%253a50002%252fsp4tssearch%252fimageservlet%253fdocid%253demr_na-c03678322-4%252fc03687856.jpg%26wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d%26wsrp-requiresrewrite%3dfalse&javax.portlet.begcachetok=com.vignette.cachetoken&javax.portlet.endcachetok=com.vignette.cachetoken
  4. Touch Reset tablet .
Sep 21, 2013 | HP Tablets & eReaders
How do i root my lgl45c
Try z4root and Gingerbrake.apk search it on Google and a moblie hotspot look on google play and search Wifi Thether it has a yellow wireless icon.
YOUR WELCOME I HAVE THE SAME PHONE
Jul 08, 2012 | Cell Phones
The vibrate setting has stopped working. Vibrate doesn't work at all. Is there a way I can fix it?
Please try resetting the phone but this will reset all the settings to factory default.
Steps to Reset Settings
This resets the phone to factory default settings.
  1. Unlock the screen by touching Lock or pressing the Unlock Key on the left side of phone, then touch Menu to access the menu .
  2. Touch the Settings & Tools icon.
  3. Touch Phone Settings.
  4. Touch Security.
  5. Enter lock code. The default lock code is the last 4 digits of your phone number.
  6. Touch Reset Default.
  7. Touch OK after reading the warning message.
  8. Touch Revert. A confirmation message is displayed briefly before the phone resets itself.
source: http://www.resetcellphone.com/solution/LG/vx9700-dare
Feb 22, 2011 | LG Dare VX9700 Cell Phone
Touch screen on my Verizon vx6900 is not working
Try resetting the phone (hard reset - see manual) back to factory defaults. If still isn't working, and you are sure that the little ribbon cable from / to the touch screen matrix is good, then you are looking at a failure of the touch screen interface on the main board.
Jun 29, 2010 | HTC Touch Cellular Phone
EnV Touch VX11000 Cell Phone: I am having problems with my touch screen. It work...
once again try to calibrate if that won't work then restore your setting factory setting but before resetting it to factory setting take backup of your data
May 07, 2010 | LG enV Touch VX11000 Cell Phone
Touch Screen not responding
KIng LeO>> Try re-calibrating the screen, settings>screen> then select "Align Screen". If after you do that, it still doesn't work, try a factory reset.
neldie>> Do a factory reset.
Use a program like PIM Backup (http://www.pocketpcfreewares.com/en/index.php?soft=1806)
Save the backup to your memory card, or back it up and copy it to your computer, the do the Factory Reset. You can then reinstall PIM Backup after the reset and use it to restore most of the stuff on your phone (contacts, call logs, text messages, etc.)
Factory Reset instructions:
•Hold down both soft keys (both above the send and end key's) and use the stylus to push the reset button in between the volume key and micro sd slot. Then the screen will turn on and tell you something to the extent of press "Send" to perform a factory reset. Hit send, and your good to go.
May 11, 2008 | T-Mobile Wing™ Smartphone
Cell Phones Logo
163 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
