Question about Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop
I update my bios in my dell e510 now all it does is restart over and over.
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    What BIOS version? Did you install by way of cold boot from removable media or from within windows?
  • 28 Answers
Try to download the bios and flash it once again. still if u see the issue probably it could be a improper bios flashing. replace the motherboard
Posted on May 30, 2009
My computer stays on bios and wont start
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Jun 17, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
I have a Dell Dimension E510 that has a Phillips DVD+RW DVD8801. Windows Media Player will not recognize my burner?
You can solve this problem by updating your driver firmware, dell even recommends it. i have posted a link to the appropriate dell page with the new firmware below. you may also have to restart your computer and/or re-install windows media player for this fix, but update the firmware first. I hope i was helpful.
Jun 17, 2011 | Dell Dimension E510 Dual Core 2.8 Ghz...
I need to reset a bios passwoerd on my dell dinention e510 desktop
There are 2 methods doing that (I assume you forgot this password).
1. Hardware (easiest one):
a. Switch off power (plug out power cable or switch off power supply)
b. open your PC box
c. locate CMOS battery on motherboard (the largest part)
it will look exactly like that (round)
d. Just take it out and wait 30 seconds
e. plug it in. BIOS data will reset (password as well)
#2. Sofware
You may use !BIOS to reset bios password. Download + instructions you will find on this website.
Leave rate if I helped you, thanks!!
May 09, 2010 | Dell Dimension E510 PC Desktop
Dell Dimension E510 - Keyboard compatibility
Hi, to find out if the “Keyboard is compatible with your system?” You can do the following: Shutdown the Computer, connect the Keyboard to your computer. Turn on the computer. If, the “Keyboard have a Power Button?”(Turn on) the keyboard. Go to, Control Panel; click on Device Manager. Click to open Keyboards, in the (Keyboard Properties) Click on Driver (Box), next click to Update Drivers! Click OK. Restart the computer. Check keyboards’ functionality. Thanks paul7of9
Jan 14, 2010 | Dell Dimension™ E510 PC Desktop
Just reformatted my dell dimension e510, prob connecting to net
Hi there.
Use the Dell tools system software CD to install the LAN (network) drivers, just pop the CD into the drive and install the CD, once it is installed a new window will pop up giving you an option to install drivers and/or utilities, just look for the LAN or network drivers and restart the PC when prompted the LAN drivers will be installed and you will be able to connect to the internet.
Post back if you have anymore problems.
Good luck and thanks for using FixYa!!
May 09, 2009 | Dell Dimension™ E510 PC Desktop
Bios problem on dell dimension e510
At first u need to remove the bios. wait for 5 minutes. then add the battery. start it
Jan 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell E510 Freezes during Bios Load
u haveto reset your bios wit juper settings it is near cmos set in it 2-3 position then again in 1-2 position .
ten clear all dust from circuit then reaatch all calwe and connectors.
Jan 18, 2009 | Dell Dimension E510 PC Desktop
Seagate 500 gig HD found in bios but not in my computer
Once windows has been updated to SP2 & all it's updates, than windows should show the correct drive size.
Jun 26, 2008 | ASUS P5RD1-VM Motherboard
Dell E510 Memory
One thing worth trying is taking out the cmos battery (only do this if you are confident you know what you are doing on a motherboard). leave the battery out for at least a couple of minutes and then reinstall the battery (ideally with a new one). restart and you may find you have cured the problem and that your old memory was fine. If this doesn't appear to help (definitely replace the battery even if you think it is fairly new)and jump the CLR CMOS pins. (ask again if you need help on this). second to try is see if you can update the bios drivers from the dell site onto a disk on another machine - use as a boot disk and see what you get. after that i would suspect the power pack, there is no real way to test this without connecting it to another motherboard and seeing if it is fine. alternative would be to just replace it with an equivalent unit, they are not too costly. After this i would suspect major motherboard or bios damage, which may be fixable but is usually cheaper to replace the whole board if you have inserted the wrong type(frequency/size/combination) of memory sets into the board it can often cause this sort of trouble, and often a CMOS clr and reset can solve the problem Please let me know if you need talking through the process - (it is not too complicated, but you can cause damage if you do not know what you are doing) Hope this helps :)
Mar 08, 2007 | Dell Dimension E510 PC Desktop
Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop Logo
79 people viewed this question
Alun Cox
