Question about Vizio VF550M 55 in. LCD HDTV
Sound comes in strong and weak at different times
Most of the time my sound is not good. Then sometimes the sound comes in very good. Then it goes out again. Sounds like maybe only one speaker is working most of the time
    Top Expert:
  • Vizio Master
  • 14,553 Answers
It could be that or a loose wire to one side of the speakers in the set. If it does it often enough locate where the actual sound for each side of the set is located---when it does it get close and listen---if one side is low or distorted you know it is either a connection or speaker on that side OR since most sets have a left and right channel for sound--the issue is in one side.(circuit problem)
Posted on Dec 05, 2012
2 Suggested Answers
  • 68 Answers
SOURCE: The picture goes off; but, the sound continues. If
the problem must be on the video I.C because the sound and video I.C of a TV is separated.Try to check for the video I.C you can check the value of the I.C in alldatasheet.com, just type the num. of the I.C you want to check.hope this may help you
Posted on Jul 26, 2011
1993 crown victoria no spark no start no voltage to ICM
You have dis ignition? The red wire to ig module is voltage, comes from pcm power relay. Check the fuses. Also, use a test light and check voltage on fuses. As you can see, one fuse is hot all the time, the other fuse goes hot with key on.
May 13, 2018 | Cars & Trucks
BUICK LESABRE 2003 . FIRST START GOOD THEN RAN A SHORT TIME ,TURNED OFF .THEN START UP SOMETIMES IS SLOW JUST ENOUGH TO ROLL THE ENGINE TO BARLEY START .
Have the battery, charging system checked along with a battery load test. Ck battery voltage when strong & weak & ck for electrical shorts.
Aug 02, 2017 | Buick Cars & Trucks
My red color is not coming in very good. i think i need to replace the bulb. how can i get a replacement bulb?
Hi Misty,
I would reset or zero out all the colour/ contrast settings first.
You can access all these via the menu on the remote.
If the reds still seem a bit weak, you can purchase new lamps on the internet. Depending on how old the TV is, a new LED flat screen might be the go. The picture difference from rear projection to LED panel is significant.
I would strongly suggest you do not replace the lamp yourself, there are dangerous voltages inside the TV cabinet.
Also, if one lamp is weak there is a good chance the others will fail soon. If it has done more than 5000 hours, time for a new TV.
Oct 20, 2013 | Sony KP-65WS500 65" Rear Projection...
Heater fires 3 times then quits, light on control board quits blinking then minutes later it tries again.
It sounds like a weak pilot generator. They wear out after a number of years. It is trying to fire which means the safety loop is all good. Sometimes the pilot generator is strong enough to keep the pilot valve open, but upon call for heat the main gas valve isn't getting enough voltage to open (and a good voltage output from the generator drops to nothing). It's not too hard of a diy
Sep 12, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Power led light
You need not worry, it appears the LED light is a little faulty and your switch mode power supply is OK.
If you are worried then replace this LED.
Mar 04, 2012 | HP Compaq dc7600 Small Form Factor PC...
97 dodge pickup with 5.2 I have strong spark out
If you have a strong spark at the coil and plugs are not then it sounds like plug wires. They can degrade over time.
Mar 15, 2010 | 1997 Dodge Ram 1500 Club Cab
Gas smell coming from oven during preheat. once oven is warmed up, smell goes away. I have a Frigidaire FGF366EBC S/N VF6289284.What would cause this?
Typically, all gas operated appliances will get a "gas smell" from time to time. What you're really smelling is the odorant (rotten egg smell) that is added into both propane and natural gas, as these gases have no smell by themselves.
The smell will vary from normal to very strong as the "receipe" for how much ordorant is added into either your propane tanks or the gas supplied to your home. Typically, when tanks start getting low, the smell is more concentrated, while with piped natural gas, the smell can be very strong at different times, based on how and when the gas company adds odorant into the main supply lines.
Usually when a gas appliance is first turned on, the smell can be rather strong, until the gas ignites. So long as your oven is lighting properly, there is nothing to worry about.
However, if you're hearing a rather loud "whoosh" sound as the oven lights, it could be that your ignitor is getting weak and might need to be replaced. If you've got a weak ignitor, it could be allowing a little bit too much gas to build up in the oven compartment before it lights, hence the reason you're smelling the gas.
You can check for a weak ignitor by simply watching the oven when you start it, if the gas lights quickly, once the ignitor is glowing brightly and you've heard the "click" of the gas valve opening (in the oven), then everything is fine.
Hope you find this Very Helpful and best regards!
Sep 10, 2009 | Kitchen Ranges
Trooper will not excelerate. it only kicks in
the car will not accelerate, check distributor unit, wires, cap and rotor making sure they have clean contact between the pole. test coil making sure you have strong 12V. Check air mass flow sensor, this unit also connected to ECU unit and also control the shifting along with transmission rotation sensor, both work in sync with one another. Check fuel pump for proper pressure my disconnecting the fuel line from the fuel filter, cover the line with a pieces of clothes, using your thumb, apply it on top of the fuel line and have a friend turn engine over, make sure you have the fuel line pointing downward away from your face. feel the pressure of the fuel pump does get weak over time and loose some pressure. if changing replacing fuel pump good idea to also replace fuel pressure regulator. Check fluid in tran mission making sure it has proper oil level. being 1990 im sure it has over 100k, I would have the tranny flush and filter change with new oil. Its good idea to have tranny flush every 75-100k especially SUV. tranny pressure sensor may need replacing, sometime it get clogs up with wast particles from gasket and worn filter. Battery light come on one awhile, have your alternator check, weak or faulty alternator will also cause battery light to come on.
Sep 01, 2009 | 1990 Isuzu Trooper
Trouble shooting
Good Day;
More than likely if TV comes on some times, it sounds like you have a power supply problem, more than likely weak cap's , relay circuit to micro.
Good Luck, big IRISH.
Sep 27, 2008 | Televison & Video
Weak coffee
It sounds like you may have lost the sprayhead. It is under the brew basket (above the place where you put the basket with the filter and the coffee). Sometimes they get loose and you don't realize it and it can fall in the grounds and get tossed out after brewing.
Jun 13, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Vizio VF550M 55 in. LCD HDTV Logo
62 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
