Question about Sony Resistance 2
Just got resistance 2.  loaded and got the "tones" when system started, but no sound after that.  picture is fine
    Sniper:
  • 62 Answers
Hi, and welcome to FixYa!
Go to settings. Sroll down to system settings. Enter system settings and scroll down to restore to factory default settings. Once you restore the factory default settings, power down the unit and unplug it for two minutes. While it is unplugged, reset your router. Then after the router restarts, restart your PS3. This should fix your problem. You may have to reconfig your audio/video settings. If this doen't fix your problem, on your XMB go over to the saved game data. elete any resistance 2 files. Also delte the resistance 2 savedgame progress. Re-install the game. If this doen't fix the issue, then you have a faulty copy. Just take it back for an exchange! Let me know if this helps by rating my solution! Good Luck, and Happy Gaming!
Posted on Jan 13, 2009
1978 Wurlitzer tone arm
Your cartridge may need cleaning and reinstalling....remove the tone arm and check you wires for any kind of damage or wear.. ..you can use a multimeter to check for resistance in each wire..(ohm's)..you should get ZERO resistance...
Jul 09, 2017 | Wurlitzer Audio Players & Recorders
Dryer only runs when I hold down Start button works fine only if I hold the start button down This is a gas dryer
souds like the door switch is broken or malfunctioning . unplug the dryers power cord , locate switch by removing top cover no need to remove switch just yet. locate two wires coming from switch . and check function by means of a continuity tester or multi tester. touch the red test lead to one wire termial and the black test lead to the other , now set your meter to resistance reading . with switch normaly open ie; (door open) youll have high resistance reading and with dooor closed or switch held in youll have no resistance. or an audible tone on your tester. if no tone or high resitance reading occurs with door closed or switch held in the switch is bad. hope this was helpful.
Feb 11, 2013 | Dryers
Hi, I have a Panasonic Cordless phone with 2 bases. I have moved one from upstairs to the phone jacket downstairs. Our third phone worked fine until I switched two of them around. Now only the plugged...
You could plug your non-cordless phone into suspicious phone jack to see if you have dial tone-if you dont have dial tone, the line maynot be connected and you should open the jack to see if there is more than 1 cable attached. If there is more than 1 cable attached and you dont have dial tone at other end of cable the cable might be cut or shorted somewhere inbetween. You can test continuity by tying 2 wires together and test with a multimeter on resistance to see if it is open circuit or maybe even short circuit. To test for short circuit, untie the cables and you should not get a reading. If you do have dial tone when you plug in non-cordless phone the distance might be to far for receiver to pick it up(ie..greater than 10 metres). I hope this has been helpful.
Aug 26, 2011 | Panasonic Lands Phones
I have a Yamaha Electric Guitar - AES 800, the guitar technician needs a wiring diagram as the tone controls are not working but it is not the pots as they have been replaced. Where do i get a wiring...
Unable to find a diagram, however, makesure the pots were replaced with identical units as not only does the resistance have to match, but the taper of the resistance MUST match the original ones. There is a letter designator on the pots as part of the part number and this MUST be the same on the replacement.
There is very little to go wrong other than the pots and the capacitors and the switch and of course the pickups.
The AES-820 control system has a user manual at the Yamaha website and that one does NOT have a "tone" control, but instead has controls for the two pickup mix. This is not reaally a tone control as is commonly thought of, but changes the sound in a different way. Not sure if your unit has the 820 system, as that system has two mix pots, a rotary selector, and another switch.
Aug 26, 2009 | Yamaha Music
PT4231 have picture no sound, Selection is on internal speakers.
you can go to your menu and select the test tone just to see if your speakers are operational, if not replace the speaker. If you have test tone, then check your input connections. If everything is connected correctly then you need to replace your main board and that should resolve the problem.
Jun 22, 2009 | Norcent Technologies PT420 42 in. HDTV...
Kenmore 90 Series Model 11060912990 Dryer won't start
check motor (you have 2.4 Kohm ) very high read
for motor must be lower.Check capacitor if hawe.
Feb 15, 2009 | Kenmore 62602 Electric Dryer
DECT 225 - Ring tone etc. no longer works on 1 phone
Use your screw driver, open the handset, maybe the speaker wire is broken. Or use multimeter to check the dc resistance of speaker. Generally ,it is 8ohm or 4 ohm.
Oct 18, 2008 | Philips DECT 2252S Cordless Phone
Steady tone coming from ghw9150pw0
could be problem in control bd not necessarily a problem with function but something in sound circuit ck for a sound control button on keypad it may say something like alarm volume or on off try holding it down after turning power on if you notice any change in volume or tone of sound shows you're on right track only thing is solution may mean new control bd
Sep 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
UPS constantly sounding an alarm tone
http://www.apcc.com/resource/include/techspec_index.cfm?base_sku=SUA1500&tab=documentation Above is the site for your operators manual and troubleshooting guide. Not knowing how load the sound is makes it hard to tell you what to do. You may have a damaged UPS.
Jan 15, 2007 | APC Smart-UPS UPS System
Sony Resistance 2 Logo
375 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
