Question about Toshiba Satellite C655-S5068 Notebook
My usb ports stopped functioning, I'm unable to print or use any of my usb sticks...any suggestions?
  • Toshiba Master
  • 2,878 Answers
MS Fixit site has a USB fix it tool, you can try.
http://support.microsoft.com/mats/Windows_USB_diagnostics
Posted on Dec 05, 2012
Cp1525nw appears offline
If the system is unable to detect the printer, it will put the printer in offline mode. In this condition you won't get any print outs..
1. chk usb cable
2. un plug the usb cable, un install the drivers, plug the usb cable & chk new hard ware found?.. if not there is usb port issue, chk system usb port/s are working or not.. if yes
3. Replace printer formatter assmbly...
This printer network unable printer, why cant use through network? instead of replacing the formatter assembly...
Jan 02, 2014 | HEWLETT-PACKARD CP1525NW Laser Printer
My usb ports stopped working
May be there some problem with internal wiring. Did you check the drivers?
Dec 05, 2012 | Toshiba Satellite A665 Notebook
TSP 700 printer on 32 bit windows 7. It doesn't stop printing and the paper just keep coming out. I've tried to reinstall driver and swapped the printer with the same model with another comput
Check if interface at the back of printer is interchangeable to the type of port your computer will support it. Direct USB to USB or direct connection is recommended to avoid future issues.
Oct 04, 2012 | Star Manufacturing Star TSP700 Receipt...
New SanDisk 16GB Cruzer not being recognized by computer
Check ur usb port with other devices.It they were not working properly,
ur usb port is damaged,then put ur device to another usb port.if is not working properly then,ur device is damaged,u can do nothing.
Jun 16, 2012 | SanDisk Cruzer Sdcz36-016g-b35 16 Gb Flash...
A couple times a week my HP Deskjet DI660 printer goes 'offline'. When this happens a message appears 'new hardware found'. And my printer will not work until I have disconnected the the...
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Aug 26, 2011 | Office Equipment & Supplies
Hello i want to use my motorola w270 to connect to an internet over pc i have installed motorola phone tools v4.5 as well as v5.0 but both version is unable to detect my phone. So please suggest me how i...
Try to plug your phone to other USB port in your PC I will recommend to plug it at the USB port at the back of your CPU. USB supply of power at the back of the CPU is sufficient to make your device function properly so it may be able to detect by the system..mostly device can't recognize by the system because they didn't function properly specially if they are plugged in a USB port who don't have enough supply of power to make them work properly..Hope it may help you..
Jul 11, 2011 | Motorola Mobility W270 Cell Phone
My laptop is simply not recognizing my futaba interlink controller via usb hub. i know the hub works because i plug something else in and it works fine...I'm thinking just bad controller maybe?
Well i'm having the same problem.
My mouse & keyboard work trough the hub, however when i plug an USB-stick in, it wont recognize it.
I've i put my USB-stick in another USB-port, it works.
So try putting your usb, in another USB-port, thats not from your hub.
Jun 19, 2011 | Computers & Internet
Unable to Print 50, not fixed
The 50 series errors have to do with the cleaning station on the right, any paper or foreign matter will stop them from functioning, also a mickey mouse spring loaded gear that likes to stick and give you that error.
Aug 06, 2009 | Brother MultiFunction Center MFC-440CN...
I added a 512mb stick to my ibm t30 think pad and one port is bad
You can plug a USB hub into the working USB port on the computer. The USB hub can have several ports so you can plug in several USB devices.
I suggest you get a powered USB hub because if all the devices that you plug into this hub exceeds 500mA then your computer's USB port will stop working because it could not supply enough current.
You will not need to plug in the power adapter into the hub if the device/s do not overload the computer's USB port.
Jan 08, 2009 | IBM ThinkPad T30 2366 Notebook
Toshiba Satellite C655-S5068 Notebook Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
