Question about Toshiba Satellite A665 Notebook
My usb ports stopped working
I'm unable to print or use any of my USB ports.
    Problem Solver:
  • 10 Answers
May be there some problem with internal wiring. Did you check the drivers?
Posted on Dec 05, 2012
sandrew
  • 2961 Answers
SOURCE: Toshiba Satellite 5005-S504 3 USB Ports not functioning
I don't think a wire is the problem as they are soldered to mobo. It is more than likely a power problem. If you go to the hardware tab in device manager and go down to usb root hub>right click and properties then look at the power tab and you will see a 500MA allowance on usage. You can easily go above these if you are using them, so check that they are all active. Also go to control panel>admin tools>services and look down list for 'plug n play' and make sure it is set at automatic and 'universal plug and play' is set at manual
Posted on Jan 29, 2007
  • 146 Answers
SOURCE: toshiba a135-s2356 usb ports stopped working.
Check your Device Manager
XP
my computer right click
go to properties
then go to device manager
then go to usb
Check to see if it has an x on it if it does try new softaware
by right clicking on the USB and Update
Posted on Aug 13, 2009
  • 10 Answers
SOURCE: USB port kills usb
please format your pendrive or anything esle you connect through usb port.
Posted on Dec 06, 2009
jagojay
  • 200 Answers
SOURCE: I own a Toshiba Laptop L500D .Plesae can anyone shed some light as to why my USB ports to the right are not functioning?
Not sure why the usb ports are not working, could be a number of reasons. You could try removing the usb controllers from device manager and then reboot the machine. Windows should then install the controllers again. Another thing you could try is to download the chipset driver from the support website: http://eu.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp and re-install that. Otherwise it may be due to a corrupt registry value in the O/S which will need a fresh install of windows.
Posted on Mar 26, 2012
herwinpradan
  • 177 Answers
SOURCE: can't read usb port com
it might be that your USB driver is troubled,in order to fix the software,you must reinstall the software using Device Manager
Right click on My Computer and select properties,then click on the Hardware tab and click Device Manager, expand the Universal Serial Bus Controllers by clicking on it,and see if there are any USB device that has "?" sign on it. If there are one,right click on the device and select uninstall,uninstall it and then restart your computer,when the computer turned on,the driver will reinstall automatically
Please let me know if it's works or not
Posted on Aug 29, 2012
Cp1525nw appears offline
If the system is unable to detect the printer, it will put the printer in offline mode. In this condition you won't get any print outs..
1. chk usb cable
2. un plug the usb cable, un install the drivers, plug the usb cable & chk new hard ware found?.. if not there is usb port issue, chk system usb port/s are working or not.. if yes
3. Replace printer formatter assmbly...
This printer network unable printer, why cant use through network? instead of replacing the formatter assembly...
Jan 02, 2014 | HEWLETT-PACKARD CP1525NW Laser Printer
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
TSP 700 printer on 32 bit windows 7. It doesn't stop printing and the paper just keep coming out. I've tried to reinstall driver and swapped the printer with the same model with another comput
Check if interface at the back of printer is interchangeable to the type of port your computer will support it. Direct USB to USB or direct connection is recommended to avoid future issues.
Oct 04, 2012 | Star Manufacturing Star TSP700 Receipt...
My printer HP psc 1210 sys it is
When the system is unable to recognize the printer "offline" appears on printer icon. 1. Ensure that printer should be on condition.
2. Check printer USB cable both ends are properly connected or not, remove & re-fix .3. Insert in another USB port. 4. Replace with another USB cable.5. Replace Formatter assembly.(only professionals can do this activity)
Nov 29, 2011 | HP PSC 1210 All-In-One InkJet Printer
Hi - I have an Acer Aspire 5735 that is 2.5 yrs old. The USB ports have now all stopped working. I saw a post about locating the drivers on the manufacturer's website & downloading them but I was...
If they stopped all at once you may be able to uninstall and reinstall the drivers. If they failed one at the time there is no reasonable repair as they are a part of the Motherboard and the replacement and labor is more than the PC is worth.
NOTE: There site does not offer a USB Driver update:
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=556
Jul 28, 2011 | Computers & Internet
My HP OfficeJet J6450 stopped working after getting a paper jam. It is connected with a USB cable. I have tried deleting the printer and reinstalling the software without success. The software...
When installing the printer click on local printer and uncheck the box below it. I think it says something like locate my device. then on next screen click create new port, you should see USB001 in there.
Jun 09, 2011 | HP OfficeJet 6310 All-in-One Printer...
Unable to print in windows7 it connects put it in q but don't print
Check you print driver, see if you can print when the printer is attached directly to the computer USB. If you can, then try it through the print server again, but instead of reinstalling just change the port under the ports section of the print properties to the IP of the print server. Should work fine.
Mar 11, 2010 | SMC 54 MBPS WIRELESS USB PRINT SERVER...
Printer port configuration and Zebra trouble
When you connect a printer to your pc the operating system adds a virtual port. Your pc will typically have 3 physical usb ports but can have as many virtual ports as you have devices to connect to it.
1: Ensure that your printer has media loaded and is powered up and ready to print. Connect the USB cable. You should get a message on pc screen saying device (printer) found.
Open printer driver ( double click on the zebra printer icon - Start/control panel/printers & Faxes/) Click print test page. If it doesnt print you will see a printer icon with a red question mark.on your toolbar, double click on this. This will bring up a small window showing status of the print job, Click printer/properties/ports. Select the next free usb port and click apply. Drag the print status window so that you can see the message in the status window change from Error print to error Restarting. repeat trying each of your usb ports until printer works. start with the higheat usb with highest number and work your way down.
Jul 15, 2009 | Zebra LP 2844-Z Thermal Label Printer
Toshiba Satellite A665 Notebook Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
