Question about Fuji FinePix S2980 Digital Camera
Turn off camera and turn on again - Fuji FinePix S2980 Digital Camera
Suddenly I keep getting the message "please turn camera off and back on again" but nothing happens when I do I just get the message again. I can turn the dial to view pictures but if the dual is turne
did you try to wait several seconds before turning the camera back on?
When it happens again, after turning off the camera please remove the battery for a few seconds and put it in again. then switch on.
If the problem persists goto the repairshop or your dealer.
Dec 23, 2012 | Panasonic Lumix DMC-FZ20 Digital Camera
Camera will not turn on, says turn off camera and turn on again, but does nothing else
Click on the link below to fix the Camera issue. This link will be helpful for you in future too
Troubleshoot Camera Issue
Regards,
Suhail
May 16, 2012 | Pix Cameras
When I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's...
When I turn on sony cyber-shot camera I get a Problem with the Sony Cyber-shot DSC-W35 Digital Camera when I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's wrong??
Oct 12, 2011 | Sony Cyber-shot DSC-W35 Digital Camera
My sony Camera (DSC -W110) is showing "Turn the power off and on again" while switch on the camera,it appers again & again after switching the camera on and off
I'm sorry that the Camera is displaying the error message. "TURN THE POWER OFF AND ON AGAIN" displays on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset. Please follow the below steps to perform a power reset.
· Turn off the camera.
· Remove the battery pack.
· Press and hold the power button for 30 seconds.
· Allow the camera to remain without power for 60 seconds.
· Reinsert the battery pack.
· Turn on the camera.
Also tryinitializing the Cameraif you're able to access the Menu items on the Camera. The Initialize option will be available under Setup or Main settingsSub Menus.
If the issue persists again, service is required. Please click hear to locate the service center near your area.
Thanks for understanding. Please let me know if your require any clarifications.
Mar 21, 2011 | Sony Cyber-shot DSC-W110 Digital Camera
Have a Sony Cybershot DSC-W90 camera. After turning camera on, get message stating "turn power off and on again." Same message over and over again.
For these few days i have saw users asked this problem here again and again. Come to see my article in my blog, Maybe it will help: turn the power off and on again maybe something will helpful
Jan 04, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
When i turn my camera on it says to turn it off again
Usually a lens problem. 95 percent of the time it has suffered a knock or has grit/sand in the lens. will need to go in for service. Does the lens move out at all?
Sep 28, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
I formatted the lexar 48mb compactflash card
Hi there.
Take the card out of the camera while it is off, then turn it on again, if the camera works fine turn if off again and insert the card, (make sure that the write protect is off) and turn the camera on again, it may let you format the card again.
Good luck and thanks for using FixYa!!
Mar 16, 2009 | HP Photosmart 315 Digital Camera
Please turn camera off & then on again
off the camera again and try to open the menu and try to reset it .if the problem persist send it to the survice center
Feb 03, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
"turn off and on again"
a few weeks ago i dropped my camera in the sea and i thought, ****. i was in the same boat, so i opened the shutter myself and turned on the camera and it works and takes pictures but the shutter wont close again so if you can make sure you have no dirt in your lense and you can manually open the shutter yourself it may work and if it stops turning on all together keep charging it and once it goes green turn the switch off and on again until it always turns green then it should work again.
Jun 22, 2008 | Samsung NV3 Digital Camera
Fuji FinePix S2980 Digital Camera Logo
26 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
