Question about Toshiba Satellite A135-S4527 Notebook
Connecting Toshiba Lap Top to NEC LCD TV
I purchased a Crest Platinum Component Cable to connect a Toshiba Note Book with Intel to a NEC LCD TV. The screen on the computer goes blank and I select Component 1 on the TV then press shift then F5 is this what has to happen? I don't get a signal on the TV can you let me know what I have to do.
    Sergeant:
  • 366 Answers
From user manual (page 68):
Your computer comes with a built-in display panel, but you can also
connect an external display device to an available video port, as
follows:
❖ An external monitor or projector via the RGB (monitor) port
❖ A TV, VCR, or DVD recorder via the S-video (TV-out) port
Before connecting an external monitor or video projector, configure
your computer for the type of device you are connecting. To do this,
refer to the documentation for your operating system and devices
So you have to use an RGB cable or a S-video cable : your cable should be plugged into 15 pin VGA port in your PC and plug it into a correspondent port in your TV.
Try also S- video and select correponding input in your TV set (Both connection type DO NOT carry sound: use your audio connector from PC to TV audio input.)
Configure your extended screen using your manual instruction:
Once you have connected an external display device, you can
choose to use the internal display only, the external device only, or
both simultaneously. The quickest way to change the display output
settings is to use the display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order:
❖ Built-in display only
❖ Built-in display and external monitor simultaneously
❖ External monitor only
❖ Built-in display and TV
❖ TV only
Posted on Jan 12, 2009
I have dell 1545 inspiron laptop. One day suddenly, the laptop's lcd screen shows colored vertical lines. I connected laptop to lcd tv and I could see desktop. I tried to enquire at various shops and
your LCD it toast its better to get it fixed. the cable only by-pass your lap top LCD thus allowint you to use your pc via another monitor sourse
Sep 27, 2014 | Dell Inspiron 15 1545 Notebook
Haier tv flashing green and red and does not come on
May be you have a faulty video cable from your cable set-top box or your DVD player--try changing the cable to see if it fixes the problem.
Also, is the video cable an HDMI cable or component (like RGB)? If it is a component cable, it may be they are connecting properly.
Aug 01, 2012 | Haier HL24XLE2 LCD TV
What's your problem?can not hook up lap top to tv
Connecting your laptop to your TV will require a HDMI cable. Attach the cable to the HDMI ports on the latop and TV, then change the source input from your TV to HDMI and your TV will now display your laptop.
Jan 30, 2012 | Televison & Video
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
Is there anyway that i can connect a nec vt695 to my tv
Hello.
Connecting the nec to your tv, I think you mean you would like to get the TV's picture out from the NEC instead of the TV.
You need to connect your digital cable box or dvd player or vcr system, where the picture goes to the tv, to the projector instead to get it to display the tv picture.
Can't guarantee that it would work without knowing more about your equipment.
If that is not what you wanted to do then I do not know.
Sep 19, 2010 | NEC VT695 LCD Projector
ON-LINE INSTRUCTIONS???
One of the most recognizable makers of TVs in the world is Toshiba. The company's TVs are found in every major electronics store at a reasonable price. Packed with features, they have a model for everyone, whether it be LCD or older, tube-based CRT technology. Toshiba T.v are fairly easy to operate. Basic functions
  • Before you do anything with your Toshiba TV, you have to plug it in to a wall outlet. After plugging it in, locate the power button on the front (or on the remote) and turn on your TV. Depending on if you have cable TV or not, you can use the channel functions to flip between your favorite channels. The "Menu" button is useful to access advanced settings, like channel detection, parental controls, closed captions and picture controls.
  • Using video inputs
  • You can connect a variety of devices to your Toshiba TV via its front, side or rear inputs. If you look at the back, you'll see a variety of audio and video inputs to connect virtually any kind of device. You should see a few kinds of video inputs: Composite and s-video (for connecting older technology like VCRs and cable boxes), component video (for connecting older DVD players) and HDMI (for connecting digital technology like receivers and Blu-Ray players). Audio inputs are analog (red and white) or digital (coaxial and optical). Use digital connections when possible to ensure the best quality.
    To connect VCRs and DVD players, simply connect the proper cable to their audio and video outputs, then match the cable to the proper inputs on the back of the TV. Make sure everything is secure and take note of which input you connected it to. Now, tune your TV to the proper input by pressing "Video" on the remote.
  • Maintenence and tips
  • Your Toshiba TV is a sensitive electronic device, so precautions should be taken to keep it in top working order. If the screen gets dusty, wipe it with a dry, soft cloth. If you own a Toshiba plasma TV, be aware of burn-in and ghosting problems. Avoid watching programs that have static images is left on the TV for hours at a time. If you have a flat-panel Toshiba TV, consider getting it professionally calibrated to get the best possible picture
  • Dec 02, 2009 | Cell Phones
    When connecting video or set-top box using composite video cable picture is black and white. If I use S-video I get colour. Video only has scart and tv only has composite/component/s video connectors so I...
    you really cant convert to component. it defeats the whole purpose of upgrading your tv. with your tv you should be using hdmi to connect all your devices your cable box should deffinatly have one. any time you connect component to something else you will get black and white hdmi is totally digital where as component is still analog pluse you dont need audio cables with hdmi its just one digital cable
    Sep 21, 2008 | Televison & Video
    I have just purchased a nec px-42vr5g plasma monitor and intend to use it as a tv connected to my sky plus, dvd and wii the guy i bought it from cant find the manual it has lots of sockets etc whats the...
    Get the Wii "COMPONENT" cable set. This set has white-red (sound) connectors plus the red-green-blue (component - video) connectors. You can get this cable where they sell the Wii. It will give you the best possible picture with this device.
    Plug the Red-Green-Blue connector in their respective sockets on the NEC display (upeer right-hand side). Switch the NEC display to the DTV/HD input (upper right button on the remote).
    Please note that this setup does not provide sound since the display does not have speakers.
    Use the white-red connectors and plug them into your amplifier or other sound device.
    Good luck.
    Sep 03, 2008 | NEC Televison & Video
    I have just purchased a Toshiba Integrated Digital LCD TV and I can't seem to run my DVD and Video player through the TV. I'm probably not connecting it right, but don't know what else to try. Thanks for...
    The DVD and video player have HDMI. Component, S-Video and RCA audio/video output connections that need to be connected to the appropriate inputs on your TV. You select the type of connector and cable to use.
    HDMI provides the best quality, if available and works for both audio and video.
    The TV's, DVD's and video player's manuals describe how in detail. Look at the connection instructions and diagrams. You then must select the correct input on the TV to play each source.
    Mar 09, 2008 | Televison & Video
    Toshiba 30HF84 and progressive scan
    check your connections properly there could be some thing that you are not connecting .or your cable are not compatible.good luck
    Jan 23, 2007 | Toshiba 30HF84 30" TV
    Toshiba Satellite A135-S4527 Notebook Logo
    535 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
