Question about Whirlpool Freezers
Modle evl201nxrq00 not cold enought to freeze food
Food inside freezer thawed but inside temperture was still cold but not enought to keep food froze.controles inside were turned up to number 4 didnot make difference when control was turned up.
  • John Tripp
    John Tripp Dec 05, 2012
    Just noticed you don't have a condenser fan. Your model just has an evaporator fan inside the freezer. JT
  • Whirlpool Master
  • 4,655 Answers
I need you to feel the top of the compressor and tell me how hot it is. Also tell me if the condenser fan next to the compressor is running. If the top of the compressor is too hot to keep your hand on top the problem may be the=> 4356738 Start Relay also found here=> 4356738 Start Relay Here is a link to the repair parts list=> EVL201NXRQ00 Repair Parts List You can see the parts listed on page 5 and 6 of the above parts list. Hopefully this is the only problem causing your freezer to stop freezing as well. If the 4356738 Start Relay is defective it will cause the problems by not allowing the compressor to run or start very well also cause the top of the compressor to overheat. You may also need to change the=> 8210224 Capacitor also found here=> 8210224 Capacitor And the=> 2-34286-021 Overload also found here=> 2-34286-021 Overload Feel the top of the compressor first and let me know the results and we will go from there, Thanks Sea Breeze
Posted on Dec 05, 2012
5 Suggested Answers
  • 27 Answers
SOURCE: Refrig/freezer not cooling/freezing
your gonna have to let thr fridge defrost buy shutting it down because it soundsm like you have either a build up of ice it the vents in the back of the frezzer unit also check to see if you can hear the fan working in the frezzer if not that would be you main problem
Posted on Jul 26, 2009
  • 1531 Answers
SOURCE: freezer control is on the highest setting and the
you may have a bad compressor.also need to check the evaporator fan and see if it is turning. do you have any kind of frost build up on the back wall that you can see.the fan is located behind the rear panel in the back of the freezer if you your it running you may have a bad compressor
Posted on Sep 24, 2009
  • 1218 Answers
SOURCE: Keep a refrigerator/freezer in garage. The
Good day,
Yes. Domestic appliances will not work properly below approx 55 degrees.
The freezer suffers most simply because the machine runs rarely at 55 degrees and degrades as the temp goes lower.
They are designed to balance properly when in an environment where people live. Ideally 70 to 90 degrees Fahrenheit.
The machine is not broken.
Moving it inside, is the only solution.
Thank for using Fixya
Posted on Jan 04, 2010
heatman101
  • 43501 Answers
SOURCE: Freezer starting to defrost
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 02, 2010
Frigidaire upright FFU17f9gw3 temperture light is on and food is starting to thaw. I put alot of freezer jam in freezer yesterday
If the control is "ON" and the compressor is not running, you will need a start relay... Make sure you didn't accidentally turn it off by pushing food against the control knob!
Jun 06, 2016 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Top shel and top door shelfs are not freezing food solid ... Bottom freezes , all food on top portion thaws
you may have ab ad fan inside the cooler and all of the cold air is staying at the bottom. Also there may be bad insulation at the top and there may be warm air up there.
Jan 11, 2016 | Amana 20.1 cu. ft. Frost Free Upright...
Power failure for 21hours think freezer thawed then froze would food still be edible & safe
Hi
Food are not that bad after defrosting that long and again frozen. It also depends on how good you know your food as the taste might differ.
Feb 20, 2014 | Freezers
Magic chef freezer model mcuf88w won't freeze
When you thawed it, did you remove ice from it using a metal object. That may have damaged the coils when would allow freon to leak out. This is too coincidental to be a problem itself with the compressor. The t'stat might be the problem. Try turning it off at the t'stat for a few minutes, then turn back on to the normal setting. Keep door closed for 30 minutes and check the inside and see if the walls are freezing. If not, you may have a compressor problem, or t'stat, or relay switch problem.
Feb 04, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
Not cool enough to freeze the food
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps.
Regards.
May 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My danby 3.6 chest frezzer has stoped working, it was freezing fine yesterday, now its not even keeping cold
I hope this helps........
Good luck.
Apr 14, 2011 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezer not freezing .. It's cold..
Take care.
Apr 12, 2011 | Northland Panel Ready Upright Built In...
Freezer stopped freezing. food started getting soft on top. power light on. green light off. tapped it , green light on. less than 1 yr old.
Good luck.
Mar 02, 2011 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
I have a Frigidaire refrigerator with a top mount freezer, no ice maker. I have noticed that in really cold weather, the unit becomes less efficient, and in extreme cases, stuff in the freezer begins to...
When it gets very cold the gas (freon) in the refrigeration system shrinks....because the properties that make cold also work against you in this case...when the gas shrinks in volume it then does not work properly anymore...the hot gas does not turn back into a liquid but stays as a gas and because of that it does not cool when going through the expansion device...ie. cap tube or expansion valve. If you were to keep it in the cold all the time you could add a bit of charge to make it work, but then if you move it to warm or the weather warms... now you are over charged... just one of those "no win" deals...
They don't make these things to run in extreme environmental changes..they like it a consistent temp. all the time...
Heatman101
Jan 12, 2010 | Freezers
Freezers Logo
119 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
AJMAL KHAN
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
