Question about Dell Latitude D510 Notebook
Internal HDD hard error
My computer has been recently becoming extremely slow, and one day I sprayed air on it, to get rid of dust and dirt, and now my Dell Latitude D510 will not entirely start back up. It will show the Dell loading screen, then will say:
"Internal HDD HARD error!
Strike the F1 key to continue, F2 to rune the setup utility."
if I hit F1, it says:
"No bootable devices--strike F1 to retry boot, F2 for setup utility"
at the setup utility, in "Device Info," under "System," it says:
"Primary Hard Drive = {none}"
(also, when I was cleaning the computer with the air, I had taken off a few of the covers on the bottom of the computer, sprayed in them, and put them back on).
  • aravind2002 Jan 25, 2009
    I too have the same problem :(
  • Malisa Wade
    Malisa Wade Nov 19, 2013
    me too
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
By your description it is very likely your hard drive finally failed. You probably looking at total data loss unless you have made recently an backup of it. You will have to get a new HD and then you can install your OS and software.
Another more remote possibility is that when you opened some covers, you accidentally disturbed the HD connection causing this problem.
Just for clarification, was there a lot of dust inside ?
Hope this helps.
Posted on Jan 12, 2009
5 Suggested Answers
  • 13433 Answers
SOURCE: No bootable devices-strike F1 to retry boot,F2 for setup utillity
Is there a hard disk installed inside the computer? try reconnecting it.
The motherboard, the hard drive, or the connector could be faulty in this case.
Remember to unplug and remove battery if you open the laptop, the hard drive is in most cases in the bottom under a cover with few screws or in some dells its on the side with few screws and comes out from the side instead from the bottom.
Posted on May 22, 2009
bschilz
  • 2049 Answers
SOURCE: when i turn on the laptop computer, a message
Your BIOS is looking for a drive to "boot" from and does not see your harddrive or CD-rom.
You may have a harddrive failure or bad drive controller.
One way to see is to load your operating system disc in your CD-rom and see if the computer sees the drive and boots up. If it boots, try to locate your "C" drive. If you can't locate the harddrive, it's a good bet it's damaged.
If the CD-rom doesn't boot, it is most likely a bad drive controller or cable.
Posted on Dec 30, 2009
SOURCE: No boot device available
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Posted on Sep 25, 2008
rommelalilin
  • 2178 Answers
SOURCE: My Laptop is Dell Latitude D600 (A16) Everytime I
Check your BIOS, by pressing F2 and see if the hard drive is recognized. It should indicate the MFR next to the hard drive listing. If it's not there, then you might have a bad hard drive. If it is there, try re-installing the operating system with the set-up disk. You can also go to the Dell website, enter you service tag number, and get technical support for your particular laptop. It might have a recovery partition in the hard drive to recover to factory settings.
Posted on Oct 26, 2010
I have a Toshiba laptop with a Windows 7 operating system, a few years old. It recently started randomly shutting down - after 10 minutes or so of use, it would just go dead. It's also extremely slow,...
Hi.
the first thing i would check is to make sure there is no dirt or dust stopping the fan from running because if the fan is not running it will heat up and shut down or if the fan is running slow it will shut down.
and for running slow i would do a good clean up get rid off stuff thats not needed anymore.like music,pictures,the more your harddrive has on it the longer it will take to load and run.
Oct 21, 2017 | Toshiba Satellite L455-S5975 Series Laptop...
I have a 1TB western digital my passport essential HDD and i have used it for about 2 months. recently, it has become extremely slow to access files and perform operations on. i have tried running the...
HI,
First of all . formatting is not the solution for all. use any anti-virus software (Kaspersky) .Install it in your system and scan ur hard disk . if still have the problem then increase the page file size.
still u have doubt contact me.
Mar 22, 2011 | Western Digital My Passport Essential SE...
My passport 320GB hard drive is giving me an I/O error every time I plug it into my computer. Copying files from it is either extremely slow (for documents) or not happening at all (videos). I am currently...
1. This could be a "Power related problem".
While you transfer data from with your HDD, make sure your your netbook is connected with an external power supply (Charger/Adapter.).
If it doesnt solve your pproblem, try updating your USB Drivers/ Chipset drivers. (All the Ex-HDD have Hi-Speed USB 2.0 port, may be your MoBo doenst have the relevant drivers to support your HDD.)
If this doesnt solve your problem, try contacting the HDD Manufacturer Support or replace it after recovering your files.
Thanks.
Deepak Verma.
Nov 26, 2010 | Western Digital 320GB MyBook External USB...
The file transfer speed for my external hard drive is extremely slow...as in it takes days to transfer a few gigs. In addition, it takes forever for the computer to read the hard drive. It was not always...
Fist clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
Try replacinng all leads that are attached to your external hard drive
then try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
Sep 07, 2010 | Western Digital My Book Essential Edition...
The CD-Rom wont read any disk that i put in the drive
There may be two issues.
1.It may be a software issue or 2.It may be a hardware issue
If it is a software issues,your CD ROM would be detected in Bios. please follow these steps.
http://support.microsoft.com/kb/314060
if it does not fix the problems, please clean boot the startup and services of the computer by following the link given below.
http://support.microsoft.com/kb/331796
or scan your computer by malwarebytes. http://www.malwarebytes.org/
I hope this would fix the CD ROM software problem.
However, if it is not fixed, it might be a hardware issue, please contact your local hardware technician.
Mar 23, 2010 | Acer Aspire 3000 Notebook
Everytime i turn on my a835 it says lens error and shuts itself off. what do i do to fix this problem
Hi Dear,
This might be due to Hard ware problem. The lens of your camera might be getting stuck at some point.
Please do not try to fix this on your own as the problem might become complex.
Please show this to your nearest service center.
If you need more information please do write to us again.
Have nice day.
Nov 09, 2009 | General Electric A835 Digital Camera
Since recently i notice am hearing the sound of the fan on the laptop spinning louder than usual. the computer these days is very hot all over. the heat that comes off it is extremely hot.
i think ur system fan cable need resolder. for this it cann't run freely or the other things for many dust in ur fan it can run freely. so check these if everything are ok then plz change ur system fan. u computer shut down bcoz when ur processor doesn't get sufficiant air then it become so hot and ur pc will off. its so dangerious.
Aug 08, 2009 | Everex StepNote XT5000T Notebook
Dissambling acer 5570 laptop
Before you go through complete disassembly, you might want to just 'blow' the dust out. Its much easier, less prone to error, and achieves the same result; All you'll need is an air compressor with a spray nozzle attached, and a minimum 25-30lbs pressure.
Steps:
Turn off the computer, and unplug the power cord.
Remove any removable cover - memory, wifi/mini-pci, hard drive, and pull out the battery.
Place the laptop, closed, upside down on a table or work surface, and hold the end of the air compressor's spray nozzle first against the fan vents while spraying air into the laptop casing. (You should see a cloud of dust burst out)
If there are more fane vents(there usually are), blow out each one in turn.
Hold the nozzle four inches or so away from the memory access, and blow air into the casing. Do the same for hard drive panel, and any other open vent or panel.
Close the hdd, memory, and wifi panels, and any other open panel, turn the laptop upright and open the screen.
Holding the air nozzle a few inches(four-six) above the laptop, carefully spray the keyboard(too close, and you risk blowing out the rubber pads that lift the keys).
Finally, wait a few minutes for any condensation to evaporate, and you're ready to go.
Feb 10, 2009 | Acer Computers & Internet
Advance Bios Set up (CPU frequency (MHz) setting)
Your computer is telling you there is a problem with either the memory or the interface between the motherboard and the memory. There is a utility you can use called memtest. I would run that and see if you get errors. Often it is easier to simply try a different piece of memory in the slot, because even if you detect errors it could be due to the interface and not the memory itself.
But the first thing you should try is power off the computer, remove the cover, blow all the dust from inside the case, remove the memory and blow all dust from the memory sticks and slots, then put it back together and try again. This is free and solves the problem about 20% of the time.
Good luck.
Jan 11, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
How to move contents from computer default hard drive to external iOmega hard drive, to make computer faster
There is a program on the xp cd called Fastwiz- it will save all your profile data for you. Unfortunately it's REALLY slow and you would be better doing it by hand. If you want to do it by hand you will need to copy all the data in the Documents and settings folder for all the profiles, plus any other data that you will need to reload the drivers. I recommend saving the e-machines drivers directory.
Wiping and reloading the operating system is the best way to resolve problems with a slow system, and a faster bigger newer hard drive is a good idea too. E-machines have a tendency to just die after a year- be aware that you get what you pay for. Also adding more ram to this system will help too.
Dec 02, 2007 | Iomega HDD External Desktop (32660) 80 GB...
Dell Latitude D510 Notebook Logo
2,363 people viewed this question
Alun Cox
