Question about Kitchen Ranges
Maytag MER 6755AAS Electric Range. Bottom oven bake element caught fire and burned into pieces. Replaced with 74004107 Factory part. Still doesnt work. Broiler doesnt work either. Top oven works fine. Thanks.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
First, pull the temp. sensor and check it with a multi-meter. It should read around 1100 Ohms at room temp. Post back the results.
Posted on Dec 05, 2012
Testimonial: "10 stars out of ten "
  • 17 more comments
  • Alex Simonton Dec 05, 2012
    Thanks guys. will do after wife finishes with dinner.
  • Alex Simonton Dec 06, 2012
    1073 Ohms
    1073 Ohms
  • Richard Roth
    Richard Roth Dec 06, 2012
    OK, thats good. You probably have a fried hi-limit thermostat located on the back of the unit. It should read closed for continuity. Here is the part to order in case you find it bad.http://bit.ly/VFoMlt Here is a diagram of the unit. Here is a diagram of the unit. The thermostat is number 16.http://cdn.appliancepartspros.com/images...
  • Alex Simonton Dec 07, 2012
    Ok. will check. I can hear the relays clicking on and off. does that sound rightr
  • Richard Roth
    Richard Roth Dec 07, 2012
    Yes, that sounds about right but the thermostat may be holding it back.
  • Alex Simonton Dec 08, 2012
    Ok Richard its reads 0.00. Can I bypass the thermostat to see if the oven will come on?
    As you can tell im not in a big hurry.
  • Richard Roth
    Richard Roth Dec 08, 2012
    Yes, just for testing purposes.
    yeah thats what I mean, then I can order the part if its bad. Thank you!
    I will let you know something here in a few minutes
    Ok. It didnt work. The stat controls both ovens. Unpluged neither work. Bypassed the top oven works but the bottom doesnt. It throws a code H3 133./
    I couldnt see the code while plugging it in, my wife saw it or I would have told you sooner.
    H3 133 ( no dot or backslash )
  • Richard Roth
    That H3 133 display does not appear to be an error code. It looks like a version number for the control board. That control board in the range is designated as an H3 type and the 133 could be the software version for that control board.
    Thanks Richard. H3 is a control, 231.00 worth. I guess AHS will have to replace that one. Thanks for your help-You get 10 stars out of 10!!
  • Richard Roth
    Wow! Sorry I wasn't able to help you better. Anyways, you and yours have a great holiday!
    You too Richard. Ill let you know what the issue was. They will be here Wed.
  • Alex Simonton Dec 18, 2012
    Hello Richard, Sears came out yesterday and did everything you told me to do. I didnt let on that I knew anything. It was the control.So if H3 flashes on the board the control needs to be replaced.Once again thanks for your help.
3 Suggested Answers
  • 1073 Answers
SOURCE: Oven fire
wrong call ge@ 100-851-6200 and they will help you have the model number handy before you call
Posted on Apr 21, 2008
SOURCE: electric range broiler element popped and burnt
Did you replace burnt fuse/tripped breaker?
Posted on Apr 09, 2009
Oven element burned through into half, what do i do?
Here is that element to order. There is also a video on that same page to show you how to make the repair.
GE WB44T10011 Oven Bake Element AppliancePartsPros com
Apr 03, 2014 | GE JBP82 Electric Kitchen Range
How do i change the lower heating element in my oven?
74004107 - ELEMENT, BAKE (LOWER)
disconnect unit from power.
remove screws from lower element.
slide old element straight back slowly towards you so the wires follow it through the holes.
as you disconnect the wires from the old element either give them a bit of a bend so they do not slide back through the hole and get lost or immediately hook them onto the new element that you could sit below the old element for transferal of wires.
make sure wires are attached securely and reinstall.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Bake element doesnt work everything else does
hi there,
the bake element can melt for various reasons, however, i think that you problem lies somewhere else.
here is the service manual. have a look through it and let me know if i can be of more help.
http://www.servicematters.com/maytag_library/docs/16010107.pdf
Sep 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Oven fire
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
Feb 02, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER5755QAS Electric Oven
part number 12001656 needs replacement. This is the sensor. I have had it replaced twice now and Maytag doesnt care
Dec 08, 2007 | Maytag MER6772 Gemini Electric Kitchen...
funny same thing just happened to me and it all seams to be the bottom element of the same ovens around the same year, I bought mine in 99 also, I keep my oven very clean becasue i know the dangers it may cause, I think this is a major problem and it needs to be addressed.
Aug 19, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
170 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
