Question about Zenith Televison & Video
WHAT IS WRONG WITH A 2006 65 INCH TV WHEN THE LAMP COMES ON THEN IT CUTS OFF
LAMP IS NOT BLOWN BUT TV CUTS OFF
Have you checked to see the lamp cooling fan is working cause if it dosen't work then the tv will shut down when the lamp gets too hot
Posted on Dec 05, 2012
  • TODD FULMER Dec 07, 2012
    yes everything is working and i cleaned it
When cut on times out and cuts self off. some times comes on and the picture is good
The tv projection lamp been inside the tv like 1 1/2 or 2 years already and tv been on used daily like 4 or 5 hrs daily?Yes,the tv projection lamp life are ending.Replace the tv projection lamp.
Mar 18, 2011 | Sony KP-46WT520 46" Rear Projection...
I have a 2005 zenith 52 inch model# Z52SZ80 heres the problem i replaced the lamp and when you turn it on as soon as the picture comes up the lamp shuts off and the red lamp light blinks 8 times then...
This is a DLP tv wright?Problems with many DLP tvs after changing the tv projection lamp,tvs still have the same problems or make alots of cliking sound too.The board that call the Ballast baord is also is dead.The Ballast board only job is to ignite the tv projection lamp.
Mar 01, 2011 | Zenith Televison & Video
Samsung 50 inch tv blew last night burning smell at time not getting any picture just a clicking sound
It sounds like either the lamp has blown or the ballast for the lamp has blown. You can call 1-800-samsung for nearest service center.
Feb 23, 2010 | Samsung DLP HL-P5663W 56" TV
Win i turn the tv on the red light comes on and i can hear the tv like its comeing on but the green light comes on and cuts the tv off but it comes back on but it does the same thing
Your lamp could be burnt out. The tv will keep retrying to start for a few times then will shut down. remove the lamp and see if it looks burnt. When you replace it you will also have to reset the lamp timer. check your manual to see how to reset.
Feb 14, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
My tv will not turn on the power light comes on
After the power surge , the TV went on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur after power surge on a rear projection are a blown capacitor on power board, a component on ballast board has blown, or a fault on Digital board had occurred.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Sep 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV comes on and off
If it is Sony KDF-50E3000 TV then its symptoms of weak Lamp that requires replacement.
You can purchase required XL-2500 Lamp from Sony Accessories Store.
Always buy Sony Original Lamp for your TV and avoid aftermarket / cheap lamp.
Thanks.
Apr 27, 2009 | Sony KDF-50E3000 Television
Lg 42 inch projection tv has green light and orange light
It is a possibility, if the indicator lights are on it definitely means something is wrong in the light engine system, it could be your lamp, ballast, color wheel or dmd board, when it comes to LGs it's most probable that your lamp might go out. You can replaced it to see if it fixes your problem, if it doesn't, there's a chance it might be yoru ballast.
Apr 01, 2009 | LG RU-44SZ61D 44" TV
Tv comes on but no picture
try unplugging the tv (no electricity what so ever going into the tv) and just let it stand vertically for atleat 24-48hours then plug it in and try it out.
if that easy fix doen't work then you either have a blown fuse or and busted lamp. contact a professional and show them your warranty.
Mar 01, 2009 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Hewitt Packard high definition DLP tv Product #EX543AA#ABA need part, hp no longer carries them.
I have a brand new L2114a lamp for sale. I paid 299 plus shipping on ebay but it turned out to be the wrong one (despite what the manual says). I ordered the correct one I needed from HP. I am willing to part with it for 200. I can send pictures of the lamp and the box and the reciept. This is a BRAND NEW LAMP.
This lamp works in the following televisions and replaces the lamps listed below:
HP Pavilion md5020n 50-inch High Definition DLP TV L1735A
HP Pavilion md5820n 58-inch High Definition DLP TV L1736A
HP Pavilion md6580n 65-inch High Definition DLP TV L1737A
HP Pavilion md5880n 58-inch High Definition DLP TV L1798A
Jan 28, 2008 | Televison & Video
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
