Question about LG LSC26905TT Side by Side Refrigerator
My ice machine not making ice
There is water but the machine is not making ice
    Problem Solver:
  • 7 Answers
Is there ice in the ice maker? If there is frozen ice in the ice maker, ice maker is probably faultily.
Ice Maker Repair
Posted on Dec 05, 2012
Water keeps running and the ice maker isn't making ice
The ice maker will not make ice with the water running in contently this keeps the water temp to high. Turn machine off, cut water supply off to machine, remove water inlet valve, ether take valve apart and rebuild it or replace the water inlet valve. Reassemble in reverse order and machine should make ice.
Jun 29, 2014 | GE Monogram ZDI15C Automatic Icemaker
Scottsman SCE170A-1B how can i have to make ice faster
The only way to make ice faster for this machine is done with cooler ambient room temperature and colder water temperature from supply water before it reaches water sump tray.
Jun 06, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman ice machine water runs continually never shuts off. It will make ice but really racks up water bill. It is as if the float never senses the reservoir is full. What is my problem?
OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
Jan 12, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
Ice machine making cloudy ice
ice maker may need cleaning, filter and/or scale collector changed. IF there is no water fiter you should add one.
Jan 23, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
My ice machine model f-450 mah makes ice but once it's full the water keeps running and runs out of the machine how do I fix this?
Make sure the plug in the water tray is secure and not allowing water to drip out. Check to make sure the float turns off the flow water once up to level.
Mar 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have a model # f-450 mah ice machine. After the bin gets full of ice it stops making the ice but the water continues to run and runs out of the machine. Any ideas on how to stop this?
Sounds like the water valve is stuck. Probably needs replacing. Turn off water after machine shuts down and see if water stops. If it does, water valve is most likely the issue.
KM-500MAH water keeps cycling thru when in ice making mode.
if this is a water cooled machine, the head pressure flow controller need to be replace/adjusted.
Jul 12, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Ice machine quit making ice
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 12, 2008 | GALAXY Microsystems 25.4 cu. ft....
Ice Maker Model F450MAF make less ice.
water valve is leaking. repair valve or replace.
May 22, 2008 | Hoshizaki Freezer Commercial Ice Machines...
LG LSC26905TT Side by Side Refrigerator Logo
306 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
