Question about Brother DCP-8020 Laser Printer
I have a Brother DCP 8020 Multi printer. Im getting machine error code A6. After replacing the fuser
This is what is written in my service manual for Error Code A6:
Error code 6A
Print Unable 6A
Turn the power off and then back on again.
Fuser unit failure (The side thermistor does not detect 60degreesC within the specified time.)
Posted on Dec 05, 2012
Mix-it-up
  • 832 Answers
SOURCE: machine error A7 ( brother dcp 115c )
Did you change the scanner cover? This happens when a wrong cis type is installed. The rom data has to be set again (this can only be done by service personal)
Posted on Nov 10, 2007
Soulvisitor
  • 1113 Answers
SOURCE: I need total reset for a Brother dcp 115c
Your print head is stuffed. More expensive than new machine, Release your frustration with this unit by placing neatly in bin!
4F
The head drive voltage has
dropped from the high to
low level in an abnormally
short period.
why
Piezoelectric (PZT)
ceramic actuator
defective (Cracks or
rare short)
Posted on Feb 07, 2008
SOURCE: Replace Fuser Reset
For the MFC 8860, I turned off the printer. I help down menu. I turned on the computer. It entered Maintenance mode. I typed in 88 (Parts Replacement.) I scrolled to the fuser, clicked ok. Then, I turned off the printer. When I turned the printer on, it said that I needed to replace my laser. I then turned the printer off, help down menu, turned the printer on, typed in 88 at the maintenance menu (parts replacement), scrolled down to laser, and hit ok. I then turned the printer on and off, and poof, now it works. I find it quite unscrupulous that I had a replace PF Kit1, replace Fuser, and replace laser messages all within one hour...
Posted on Dec 15, 2008
jtuminaro
  • 56 Answers
SOURCE: Replace Fuser error will not go away
With in 2 seconds you have to hit Menu,*,2,8,6,4
Continue even though you hear the 3 beeps.
When it does into maint mode press 88
That is parts counter reset
Scroll to the part and hit ok.
Press 99 to exit Maint mode
Posted on Jan 15, 2009
  • 215 Answers
SOURCE: Brother printer dcp-330c error 46
press "menu" "black start" and "up arrow 4 times". that gets you into maint. mode to be able to reset purge counter. next enter code "80" by pressing up/down arrows and pressing "ok". press "black start" several times until you see "purge count". now press "2783" and "ok" to reset purge count. then press "black start" about three more times or until you see flushing count. again, press "2783" and "ok" to reset. now hit "stop/clear" a couple of times and press "99" to exit or use arrows to get to "99" . at this point, you may have to press "ok" to get out of maint. mode, but i think once you press 99 it backs out automatically. next time this comes up however, you will need to have your ink absorber box and flushing box replaced.
hth,
razors
Posted on Mar 30, 2009
Machine error 50
On a Brother printer Error 50 typically means that the Fuser is malfunctioning.
Turn the printer off for about 5 minutes. Then turn the printer back on and wait for about 10 minutes. If after 10 minutes the printer doe not recover, you will need to replace the fuser unit. May be more economical to replace the whole printer.
Jun 30, 2014 | Brother Dcp-J125 Compact A4 Colour Inkjet...
Machine code 5a
a 5a error code means that The machine does not work due to a paper jam or some sensor problem. here is a list of error codes for the dcp-j125 printer.
Error Code Cause Solution 30,31,32,33,34,35,36
37,38,39,3C,3F The machine does not work due to a paper jam. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) 40,42,43,44 The internal temperature is too high. Unplug the machine from the AC outlet and if possible cool the room where the machine is located. 46 The ink absorber pad is full and needs replacing. Please contact Brother Customer Service from "Contact Us". 48 There is a problem on the print head, Please contact Brother Customer Service from "Contact Us". 49 The internal temperature is too low. Unplug the machine from the AC outlet and if possible warm the room where the machine is located. 4F There is a problem on the print head. Please contact Brother Customer Service from "Contact Us". 50,51,52,57,5A,5B,5C
5D,5E The machine does not work due to a paper jam or some sensor problem. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us". 8F There is a problem on the paper feed motor. Please contact Brother Customer Service from "Contact Us". A5,A6,A7,A8,AF There is a problem on the scanner. Please contact Brother Customer Service from "Contact Us". E2,E3 There is a problem on the main PCB. Please contact Brother Customer Service from "Contact Us".
Jan 07, 2014 | Office Equipment & Supplies
BROTHER DCP 8020 ERROR 6A
A Brother MFC-8840D reported an Error 6A on the panel after a short power-outage that occurred. Calling Brother indicated that the error reflects that.
To clear the error, the procedure is as follows:
1. Turn off printer
2. Hold down MENU button on front panel and turn on power while continuing to hold.
3. Release button after 5 seconds (after the Please Wait message)
4. If error still occurs:
5. Press 91
6. If error still occurs:
7. Press 99
This should clear the error.
Good luck
Please rate FIXYA
Apr 07, 2011 | Brother DCP-8020 Laser Printer
Error code 50
Error Code E50. This printer error code flashes when the fuser unit of your Brother multifunction printer gets damaged. When this happens, it is a signal that you must replace your printer's fuser unit
Mar 15, 2011 | Brother Multi-Function Center MFC-240C...
Brother DCP1200 Machine Error 76
This refers to a error with the fuser temperature you need it repaired by a service technician. Parts can be as little as $15 for the thermistor sensor or as much as $100 for a new fuser.
Jan 04, 2010 | Brother DCP-1200 Laser Printer
Trouble shooting clean unable 50
Alright, i have to tell you, this is a really bad post. You gave me nothing for information. But from what information i can gather, it could be error number 50. on a brother DCP-145C. Heres the problem with brother printers. They are cheap to buy initially, but break and can't be fixed easily without being a "Certified brother technician".
Either way. I think you have to replace the logic board on the unit, possibly. Possibly check the connections and use sand paper and undo some connections sand the copper, and put them back in. Logic board will likely run you over a hundred, if you need to replace the fuser, thats over 100 again. Expensive repair. If it had been an HP printer, i could have explained it thoroughly, i'm sorry i can't be of more help.
Sep 20, 2009 | Brother Multi-Function Center MFC-240C...
Brother 7020 printer "fuser error"
The fuser has failed and needs to be replaced. If it is still under warranty Brother may cover it. If not you will have to take it to a Brother Authorized service center. It may be possible to find a used one on Ebay, even if its just for parts. Some of these smaller machines require extensive dissassembly to replace the fuser and shouldn't be attempted by a novice.
Mar 19, 2008 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-8020 Laser Printer Logo
333 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
