Question about Dryers
I need a picture of the control board for a ge adora dryer
I replaced the control board on a ge adora dryer but when i push start the tub doesn't spin: did i miss a conection ?
You have to program you new board. I think you enter into the t01 mode and then select the number that corresponds to your model dryer. Here is a link for the manual that shows steps to replacing the control board.
http://www.applianceblog.com/manuals/31-9136_GEFDryer.pdf
Posted on Jan 18, 2013
  • 130 Answers
SOURCE: dryer wont start
its one of three things, check your thermal fuse on the back inside of the vent, the door switch or the start switch
Posted on Jan 29, 2009
  • 1122 Answers
SOURCE: GE Six Cycle Automatic Dryer just buzzes when I push start
most of the time when the syary button just busses it means the motor is gone,you can take it apart and clean and lube itmake sure nothing stuck in it,let me know if you need more help-mike
Posted on Mar 21, 2009
jumptrout51
  • 3361 Answers
SOURCE: Replacing Control Board on Frigidaire model LEQ1442ES0 Dryer
There should be screws on the back side of the top panel that come out. Then the panel will slide out so that you can access the front controls.
Posted on Aug 18, 2009
SOURCE: ge adora dryer #dhdvh52efoww has code E61 and does not work, how can i fix it
Turning off in the middle of cycle and code E62
Posted on Aug 25, 2009
SOURCE: Ge Adora Dryer, Worked great.
the dryer during its cycle squeaks and rumbles it sounds like some thing is not right.
Posted on Jan 03, 2010
I have a GE Adora dryer With Sensor Dry. Lights on panel On but start switch not terning Dryer on. What do I do?
here are some simple things you can try that might work, they are quick and cost free, but may have not effect, or may fix your issue. your issue could be the actual switch needs replacing or even the whole control board, but try first:
1. just unplug the dryer and wait 30 seconds and plug it back in and see if that 'resets' it.
2. unplug, hold down on button while plugging back in
may do nothing, but cannot hurt and certainly won't make it worse.
Jul 20, 2015 | GE Dryers
Ge adora dryer runs for 3 minutes and shuts off
Could be thermal fuse.... or control dial DW
Mar 20, 2014 | Dryers
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Stop button doesn't work on Amana NED7200TW Electric Dryer.
Check the door switch to see if it "clicks" when you push and release it. If it clicks, then the control board will need to be replaced. Here is the part you will need to order.
Nov 01, 2012 | Dryers
How do I remove the control panel on a ge adora dryer dhdvh52ef0ww
In the corners of the board there will be little white plastic pieces that you will need to squeeze together and push the board up from the bottom at the same time. They are called stand offs. If you break them don't worry ther can be purchased at any appliance store. I'm not saying break them off but if it happens don't worry too much. If you need to two of them will hold the boarding place no problem.
Sep 08, 2012 | Refrigerators
GE Adora Refrigerator. On the freezer side, water seems to be leaking from the top/back of the freezer. Not sure how it's happening, as it's usually frozen when I realize it. My housemate believes...
Hello
Check fill tube that puts water into ice maker. You may need to use hair dryer to thaw out. Look for a tube that comes out of back wall of freezer behind ice maker section. Make sure its there and pushed all the way in .This is a bad GE design. (could have fallen out)
hope this helps
Aug 16, 2011 | GE Adora (DSF25KGTBG) Side by Side...
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
Ge Adora dryer model#DHDVH52EFOWW started making a screeching noise in the middle of a cycle and does it again if I restart it.
remove door and check horse shoe shaped plastic guides located at the top of the door that the drum rides on for wear....replace if worn
Jan 03, 2011 | GE Adora DVM1850 Microwave Oven
My GE Adora side by side will only dispense crushed ice...the buttons seem to be working, as in the light comes on each button when pushed. But only crushed ice!
Turn off icemaker. Remove ice bin, empty it, rinse with warm water and leave to dry overnight.
If this did not help - check solenoid in the freezer behind the ice bin, make sure it's not stuck and has continuity. If all checked out ok, but still no cubed ice - control board or interface board may need replacement, and you'll need a professional to diagnose that.
Good luck,
Vlad
First Choice Appliance
Jun 02, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
GE Adora QuietPower II Replacement Rack Wheels?
Model number is on a sticker on the left wall of the dishwasher, just behind the door, about mid tub level. Post your full model number and I'll list your part number(s) for you.
Sep 06, 2008 | GE Adora GHDA656LSS Stainless Steel...
Dryers Logo
61 people viewed this question
Top Dryers Experts
