Question about Bosch HBN 452 / HBN 456 Electric Double Oven
Easy Off oven cleaner baked into Jenn Air oven
I used some Easy Off oven cleaner to remove a baked on spot in my oven. I didn't realize some had sprayed on the sides and therefore I did not clean it off and heated the oven to 400 degrees to cook later on. I can not get the baked on Easy Off off my there any solution to this?
SOURCE: bosch oven
looks as though youre circotherm element has blown (open circuit) you will need to remove oven and check with multimeter should read around 35-37 ohms on 2.5 kilowatt heater if open circuit will need replacing easy to do on most ovens and no too expensive around £30-£35 for element depends on model and output power.
hope this helps
Posted on Jan 18, 2008
  • 770 Answers
SOURCE: Easy Off Heavy Duty Oven Cleaner on Self Cleaning Oven
NO..wont hurt it as loong as you got it all out.. but plz remind her that this is a self cleaning oven....Which does not mean you have to clean it yourself !!! it should be fine.. tell her next time to run it thru a self clean cycle for at least 3.5 hours on the timer setting..
Posted on Jan 27, 2008
  • 338 Answers
SOURCE: Easy off ate all enamel off interior of oven
First off i must say that in your owners manuel it clearly states to not use any cleaning products inside the oven..
Second if the cleaner is now completely cleaned off then when put into the bake cycle it could possibly turn the cleaner into a toxic gas. I would not use the oven i would replace it.
Third having the enamel chip off is not a safety concern. it is merely cosmetic. however refer back to number 2.
Posted on Feb 13, 2009
  • 10865 Answers
SOURCE: hotpoint oven self cleaner mode; cant unlock the door
Hello. I want to help you. I can understand why you did what you did. Now though I want you to forget about the open cleaner and just set the self cleaner again and let it run its course. get back to me if it won't let you do that as there are other things you can do then.
Posted on May 20, 2009
  • 3361 Answers
SOURCE: How can I get cleaner off a non-self cleaning oven
Re-apply a fresh coating of cleaner. Let it work according to the directions,then wipe it out.
Posted on Nov 09, 2009
My old Jenn-Air W230 wall oven only gets to "warm" in the bake position - even at a temperature setting at 500 degrees. However the broil function works well. Could the problem be a bad thermostat o
the oven sensor could be bad,its a small rod inside the oven cavity near the top,or you could have a bake element with a "hot-spot" in it that can no longer pass enough current to properly heat the oven to the correct temperature setting(most elements with a hot spot will show a discolored area on the element where its been overly hot)this is the "hot-spot" it will soon break apart there
Nov 30, 2012 | Jenn-Air Ovens
How to clean oven model JSP46D P1BB
That model is self cleaning . So you have to remove the oven racks and press the button marked self clean. The self cleaning cycle will last anywhere from 2-4 hours . once the oven unlocks after the cycle is over you have to wipe the surface with a clean clothe. It is very important to never use regular oven cleaners (i.e. Easy Off ) in a self cleaning model. If you need to spot clean something without using the Self cleaning mode you can make a paste of baking soda and water and let it sit for an hour before wiping.
As far as the top is concern, use a mild soap and a dish cloth on an everyday basis. There is products specifically designed to clean the ceran tops (good brands are "Cerama Bryte" and "CookTop", they are available at any Wal Mart) you should use one of those cream cleaner at least once a week. If something is really baked on , you can use a razor blade ( same ones ones used to removed paint off windows) or a scotch brite pad ( the blue one only.. the yellow one is too abrasive)
Mar 14, 2011 | GE Ovens
Jenn Air W30400 wall oven does not heat.
Turn off the power to the oven.
Remove the racks.
Remove the BAKE element screws and carefully pull the element out.
Remove the wires from the element,being careful not to let the wires fall back into the oven cavity.
Use a volt meter set for continuity and touch the meter leads to the element terminals.
No reading is a bad element.
Replace the element.
If you do get a reading,the electronic control is bad.
Jul 16, 2010 | Jenn-Air Ovens
My jenn-air gas oven works when i put the broiler on but the oven will not come on
i would replace your bake ignitor, as an oven cycles the broil ignitor and bake ignitor on/off to preheat the oven.. if ur bake is not coming on i would replace it, hope this helps
Feb 12, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Jenn air touch panel on oven beeping and flashing
throw the jenn-air out.
purchase something from another company that cares about their products.
I have had the same issue, twice. my wife managed to melt the touch pad by baking and using the burner at the same time. this has happened to countless purchasers of jenn-air **** appliances. they should be sued and forced to fix their faulty design
Aug 29, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Older jenn air wall unit oven / turn knob
Yes, I just had same problem. The probe receptical is on the right inside wall of the oven. A little flapper door is secured by a single phillips screw. Remove this screw and the flapper door. Gently remove the receptical and its attached cable adapter. With your screw driver short the connector extension to the housing, just as the probe would. This should reset the meal temperature sensor. Try the bake and problem should be gone. If not permanently short this connection with a wire. You won't be able to use your probe, but the oven will work.
Feb 23, 2009 | Ovens
Jenn air bake element problem Model SVB46800w
At the family house we had an old counter top Jenn-air appliance and the connectors for the elements always burned until i put white sillicon grease on the contacts.This grease is intended to transfer the heat on transistors. Never had problem again.
Jul 29, 2008 | Jenn-Air Ovens
Using the ovens
It's not dumb, it's the oven. You simply hit bake, temperature and then bake again. Of course you have to choose whether to bake or convection bake and you choose this when you hit the first and last bake command.
Oct 19, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn air oven
I had the same problem. I went to the manual and it is very easy to fix. The oven control lockout was somehow set. To cnacel it just press the Cook Time and the Stop Time buttons at the same time for 4 seconds. The "off' will appear briefly and then disappear. It worked for me. Good Luck!
Aug 20, 2007 | Jenn-Air JJW8530C Expressions Collection...
Bosch HBN 452 / HBN 456 Electric Double Oven Logo
160 people viewed this question
Top Bosch Ovens Experts
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
